  • 1 Post By Doucems6
 Old 04-14-2013, 11:29 PM   #1
Doucems6's Avatar
Posts: 62   (View Stats)
Doucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond repute
Default stage 1 to bnr s3 full support
Finally decided to pull the pin on the bnr s3, and got around to installing it last weekend. We clocked about 25 hours for the entire project. It included auto-tech hpfp, brake change, m2 catless dp, full custom fmic ( fit,fab,weld and painted piping), grimspeed ebcs, ets catback , and the bnr stage 3. (custom egr delete, ported im ,valve cleaning pre build).
Here's a few pics of the ordeal, didn't get into to much detail with the photos because of the weekend time crunch as this is my dd. I used a stg 2 cpe nano+tip+ic+93 oct. With abilors tuning and perms bt 101 intergated in the tune, it Fired up first couple of cranks ran perfect. idles perfect and low throttle conditions are spot on. wot im experiencing what i believe to be spark blow out around the higher rpms and got pretty lean on me. Waiting to install the new plugs at .026 gap. and go from there.
Still waiting on a few other pieces 3.5" wp, wmi, and the 3 bar map sensor, battery relocation and of course a proper tune from who better then the freek!
Here's a copy of my tune if anyone could spare their input it would be greatly appreciated!
BNR stage 3 *cpe sri * sure TIP* sure TIG * Cobb ap * autotech hpfp * PNP IM vtcs delete *custom fmic 2.5" piping * optima red top trunk mounted *egr block off * moroso occ * ets cat-back * bosch 3 bar map sensor * turbosmart bov (recirc) * 3" m2 catless dp* grimmspeed 3 port ebcs* sure ssp* solid shifter bushings * ss brake lines * stoptech slotted rotors w/ oem pads* ngk 1 step colder plugs * mt 90 tranny & diff oil * front & rear strut tower bars * badge-less grill * evo x wheels * 225/40/18 nitto invo's * triple gauge pod autometer gauges*
*** Freak tuned ***
21psi
best 1/4mile----13.5 @ 104 mph 1500' above sea level
Doucems6 is offline   Reply With Quote
The Following 11 Users Say Thank You to Doucems6 For This Useful Post:
Axel907 (04-16-2013), AZSPEED3 (04-20-2013), Code Monkey (04-20-2013), Davy180 (04-20-2013), Dralphy (04-20-2013), Jeremy3eb (04-20-2013), mczimer (04-20-2013), meelo88 (05-07-2013), Menace1 (04-25-2013), Micha (04-14-2013), turboKart (04-14-2013)
 Old 04-14-2013, 11:47 PM   #2
turboKart's Avatar
Posts: 321   (View Stats)
turboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the world
Groaned at 8 Times in 4 Posts
Nice pic layout - for your log, to find out why AFR is where it is, I'd think it would be good if you can log injector data too, but my only real input is that pic of the reflection of the babe in the pipe is way fucking cool.
http://www.mazdaspeedforum.org/forum/foru...-26-09_262.jpg
'09 MGM MS3 - 'MaZcedes'
* Cobb A/P * CP/e S2 RMM * Autotech/6oost3d/McMaster-Carr HPFP Internals * JBR PowerPath SRI/TIP * ATP Catless DP * Cobb XLE BPV * Bilstein B8 Sprint Shocks * JBR 32mm Rear Sway Bar *
STRATIFIED...proper - ZFZMF!
turboKart is offline   Reply With Quote
The Following User Says Thank You to turboKart For This Useful Post:
Doucems6 (04-15-2013)
 Old 04-15-2013, 12:10 AM   #3
Doucems6's Avatar
Thanks I'll take another log after i get the new plugs installed! And that is actually a 21mm socket its called socket art! lol
*** Freak tuned ***
21psi
 Old 04-18-2013, 02:50 PM   #4
mczimer's Avatar
Posts: 1,249   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
Those are some good looking welds and cuts...share?!
mczimer is offline   Reply With Quote
The Following User Says Thank You to mczimer For This Useful Post:
Doucems6 (04-20-2013)
 Old 04-20-2013, 11:59 AM   #5
Doucems6's Avatar
Thanks, my friend and I took our time making sure everything was going to be perfect fit and weld wise ( clearance for shifter weight, reuse of the stock windshield washer tank, fog light housing, horn). Both of us combined also have more than 20 years in oil field fabrication.
I'm a pressure vessel welder for the refinery's and hes a oil rig hydraulic fabricator. We had no choice but to do a good job! Were not about doing rework. The whole intercooler set up was designed to be 3 pieces (minimum connections to reduce boost leaks, but still fully removable). If you have any questions i'd be happy to answer and supply more pictures!
*** Freak tuned ***
21psi
 Old 04-20-2013, 01:25 PM   #6
mczimer's Avatar
You have this routing WITH the OEM washer tank in place?? PICS!
 Old 04-20-2013, 01:51 PM   #7
AZSPEED3's Avatar
Posts: 3,148   (View Stats)
Groans: 65
Very nice setup you got. Like the custom ic you made, very nicely made.
The Following User Says Thank You to AZSPEED3 For This Useful Post:
 Old 04-20-2013, 03:27 PM   #8
Doucems6's Avatar
Hopefully by the end of the day! Were working on it right now, pics soon after. Oem tank in driver side fender well area. Might have to do some senor surgery, but tank should fit.
*** Freak tuned ***
21psi
 Old 04-20-2013, 07:49 PM   #9
mczimer's Avatar
Can't wait to see how you will manage to get it to fit. I have a custom FMIC job next weekend, so this would be amazing
 Old 04-21-2013, 11:38 PM   #10
Doucems6's Avatar
It was a bit of a pain in the ass but we fabbed up three brackets that could be utilized, on the body. 2 of the bolts/nuts were from the tank itself (these were used on the 2 larger brackets made from 1/4 x 2" flatbar).
The 3rd small triangular bracket was made as a resting point on a factory bolt. We basically built a jumper harness for the pump, and low fluid level sensor. and just ran them in a new loom zip tied along the other larger loom across the rad. into its new location. We also notched out a small piece just under the intake so that the bottle would sit upright.
I know its kind of a vague how to but im hoping the pictures will help it make sense!
Keep in mind this is on a speed 6 and highly depends on the routing of the fmic cold piping, we didnt use the tradtional route under the intake we actually notched out some of the plastic rad support to keep the radious as tight as possible.
I take no responsibility on anybody else's out come! But i will be happy to help out and take more pics/explaining.
Code Monkey likes this.
*** Freak tuned ***
21psi
The Following 6 Users Say Thank You to Doucems6 For This Useful Post:
big angry bird (04-24-2013), Code Monkey (04-22-2013), mczimer (04-22-2013), Menace1 (04-25-2013), TiGraySpeed6 (04-22-2013), turboKart (04-22-2013)
 Old 04-22-2013, 10:51 AM   #11
mczimer's Avatar
Bad a**! I had no idea the OEm tank would fit there....
@TiGraySpeed6;
The Following 2 Users Say Thank You to mczimer For This Useful Post:
Doucems6 (04-22-2013), TiGraySpeed6 (04-22-2013)
 Old 04-22-2013, 12:15 PM   #12
Doucems6's Avatar
@TiGraySpeed6;
Thanks! Just depends on keeping that tight radius on the cold pipe! To save as much space as possible.
Let me know if you need anymore pics when you do yo
ur fmic!
*** Freak tuned ***
21psi
 Old 04-22-2013, 12:23 PM   #13
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
That's a pretty nifty idea for the washer tank!
I've been debating what or how I was gonna mount something, and this should fit the bill rather nicely & the price is right too
340hp / 371tq
 Old 04-22-2013, 12:29 PM   #14
6Y MAZDA's Avatar
Posts: 1,775   (View Stats)
That's awesome. I never even thought of utilizing that big ass empty space over there to relocate the washerfluid tank. Great work.
1996 Miata
The Following User Says Thank You to 6Y MAZDA For This Useful Post:
 Old 04-22-2013, 05:53 PM   #15
mczimer's Avatar
ur fmic!
Did you "have to" modify the tank or the hoses/connector to get it into the driver side?
Are the bracket mounting points preexisting or did you make the holes there, just to verify what I see!
 Old 04-25-2013, 06:58 AM   #16
Doucems6's Avatar
Hey sorry for not getting back to you sooner I know you have your install coming up the only part of the system we modified was the stock sensors for the pump, and low fluid level. Not sure if you can see from the photos but there's 4 connectors on the passenger side next to the orginal tank placement. One is for the foglights, one is side markers. There other two are pump and low level.
Cut those two run enough wire so they will reach the new location. Be sure to double check they are the right ones before cut. Splice the wires solder and shink wrap them.
All the fluid lines will work, just follow them under the winshield and reroute them.
Its not as complex as it may seem. Baseline is your just relocating.
You need shink wrap, wire 4 . Pos and ground for each sensor. Length may vary.
And 2 x 1/4 flat bar to fab you new brackets!
*** Freak tuned ***
21psi
The Following 2 Users Say Thank You to Doucems6 For This Useful Post:
mczimer (04-25-2013), TiGraySpeed6 (04-25-2013)
 Old 04-25-2013, 10:31 AM   #17
mczimer's Avatar
Sweet, thank you. Got all my parts yesterday, so the weekend shall be fun!
Doucems6 (04-25-2013), TiGraySpeed6 (04-25-2013)
 Old 04-25-2013, 04:23 PM   #18
Doucems6's Avatar
Awesome be sure to post some pics when its all complete! I'll be on the look out to see how it went!
*** Freak tuned ***
21psi
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/stage-1-bnr-s3-full-support-142930/
Oh_yea : DIY FMIC for $220 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-20-2013 12:44 PM
Oh_yea : DIY FMIC for $220 - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-13-2013 06:50 PM
Oh_yea : DIY FMIC for $220 - Page 4 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-13-2013 06:48 PM
Oh_yea : DIY FMIC for $232 - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum Post #12 Pingback 04-22-2013 05:06 PM
Stage 2... Not hitting full boost 2010Speed3 2010 MS3 - Troubleshoot/Diagnostics 27 06-14-2018 07:47 PM
What do I need for full stage 2? 2012Mazdaspeed3 2010 MS3 - Big Turbo Builds 11 03-15-2012 04:23 AM
Volvo buys full-page ads to pledge support for distracted driving legislation Haltech Automotive News 0 09-30-2009 04:30 PM
Page generated in 0.41022 seconds with 26 queries
