 Old 08-27-2011, 07:03 PM   #1
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
so i cut the hardline in half and had my local race fab shop - Thompson Racing Fabrication - weld a bead on both ends so the hose won't slip off when clamped.
I first tried aeroquip -12an hose (aqp socketlless) with clamps - but i guess it's too stiff to seal against the pipe (since it's designed for their push on fittings). sad because it was really nice hose and made the bends well for the soft line that's in the way. so i'm replacing it with regular heater hose with a unicoil to make the bend.
i'll post pictures up when i'm done
another note to people using this manifold - the turbo sits lower with this manifold so you need to extend your IC piping for the cold side. I have the turboxs fmic with the a 90 deg welded onto the end of the top cold pipe. it's about 3.5" too short so i'm going to have TRF weld a section on.
Last edited by xcoldricex; 08-27-2011 at 07:03 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to xcoldricex For This Useful Post:
saitek (08-27-2011)
Coolant boiling over exhaust in coolant bcmurphy87 MazdaSpeed 6 - Engine, Transmission & Driveline 12 12-15-2010 02:39 PM
Angled CEL fix for catless DP Addikted To Boost MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 07-22-2010 07:35 AM
Hotchkis Rear Sway Bar Clunking Only When Angled Bump ms3brendan MazdaSpeed 3/6 - Suspension & Brakes 24 07-13-2010 10:36 AM
Stock turbo oil and coolant lines 06Speed6 MazdaSpeed 3/6 - Turbo Induction 16 02-06-2010 10:22 AM
Page generated in 0.23662 seconds with 21 queries
