 Old 08-21-2011, 06:35 PM   #1
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Default Steedspeed angled T3 - coolant lines getting in the way?
I'm putting on a FP HTA3076 with a steedspeed T3. It has a 4" inlet - but i'm pretty sure i've seen other people with the same inlet side. the hard coolant line and one of the soft lines are all up in the way of the inlet when trying to get the cp-e turbo inlet pipe on.... did anyone else run into this problem? it doesn't seem the hardline has enough play in it - but i haven't recruited another person to pull down on it while i try to slip on the pipe yet - just wondering if someone came up with a solution.
 Old 08-21-2011, 06:48 PM   #2
mason's Avatar
Posts: 946   (View Stats)
LOL! yes! force it on! pull off supports and massage it on there, i fit 3.5 piping in there.
The Following User Says Thank You to mason For This Useful Post:
xcoldricex (08-21-2011)
 Old 08-21-2011, 06:53 PM   #3
ILL3ST
xcoldricex's Avatar
oh nice.
pull it off what supports? it's not attached to the turbo anymore and it's screwed down in front at the starter.
 Old 08-21-2011, 06:56 PM   #4
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
you dont really NEED to take things off, just manhandle it on
 Old 08-21-2011, 07:06 PM   #5
SilverDemon's Avatar
Posts: 3,034   (View Stats)
Yeah, man.. I ran into the same problem. I cut the hard pipe and extended it using -12 braided hose.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following User Says Thank You to SilverDemon For This Useful Post:
 Old 08-21-2011, 07:36 PM   #6
ILL3ST
xcoldricex's Avatar
happen to have any pics of this? did you take the whole pipe off - weld two -12 fittings on the ends and just have a -12 piece of hose in the middle or something?
i'm surprised most of you just manhandle it on - wouldn't it end up potentially cutting or at least crushing the silicone inlet?
The Following User Says Thank You to xcoldricex For This Useful Post:
SilverDemon (08-22-2011)
 Old 08-22-2011, 06:08 AM   #7
There is many different ways to get there. I cut the pipe just before the bends (where it goes over the transmission). Then, found 3/4" JIC steel fittings from a hydraulic fitting supply house and drilled them out to the correct size (just a slip fit over the pipe is all you need). Braze them onto the coolant lines, I purchased 2, 45* -12 AN fittings and made up a hose to connect the 2 ends of the pipe. The end of the pipe that is closest to the starter has a bracket welded to the pipe. On the end by the turbo I used a rubber lined clamp, drilled and tapped a mounting hole in a gusset on the transmission case.
I thought I had pics of this, but I cannot locate them right now. If you decide to just cut the hard pipe a slip a piece of 3/4" hose over the end, please put some silicone sealant on the pipe, and double clamp the hose.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 08-21-2011, 08:09 PM   #8
mason's Avatar
it pushed in on the silicone a lil bit. i will tackle this later with my build, due to i need car up and running at the moment. but honestly i did not like it, i looked at everyway possible to fix it and seems you have to cut it and extend it! with rubber hose or -AN.
 Old 08-22-2011, 09:40 AM   #9
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Honestly you should be able to just bend it out of the way, but if you cant there is no reason you shouldnt be able to replace the entire thing with a rubber hose and some fittings from home depot.
2006 Mazdaspeed 6
xcoldricex (08-22-2011)
 Old 08-22-2011, 09:46 AM   #10
ILL3ST
xcoldricex's Avatar
well the hardline has the mount at the starter and has the tee off for the turbo coolant line - so that's probably why people don't replace it all with rubber.
 Old 08-22-2011, 10:04 AM   #11
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Man handle it, the two ATP drops in I did we also had to man handle the whale dick on.
860whp/677wtq
2.7 V6 Ecoboost
 Old 08-22-2011, 10:18 AM   #12
801MS3's Avatar
Posts: 453   (View Stats)
801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world
Groans: 30
It is a pain in the ass.. yours looks closer to the hard line that mine was.. But i had to have one person underneth the car pulling down on the soft line while i forced the inlet on.. Its a pain..
p.s Glad to see you putting this thing on your car!
Interested to see how the FP turbo performs on the ms3!
Good luck
08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS:
465whp 468 wtq Best e.t 11.9 Best trap 123mph
801MS3 is offline   Reply With Quote
 Old 08-22-2011, 07:50 PM   #13
ILL3ST
xcoldricex's Avatar
yeah i think i will probably try to fix it - don't want to be unable to put on the inlet without help. might do the rubber hose route though.
 Old 08-27-2011, 07:03 PM   #14
ILL3ST
xcoldricex's Avatar
so i cut the hardline in half and had my local race fab shop - Thompson Racing Fabrication - weld a bead on both ends so the hose won't slip off when clamped.
I first tried aeroquip -12an hose (aqp socketlless) with clamps - but i guess it's too stiff to seal against the pipe (since it's designed for their push on fittings). sad because it was really nice hose and made the bends well for the soft line that's in the way. so i'm replacing it with regular heater hose with a unicoil to make the bend.
i'll post pictures up when i'm done
another note to people using this manifold - the turbo sits lower with this manifold so you need to extend your IC piping for the cold side. I have the turboxs fmic with the a 90 deg welded onto the end of the top cold pipe. it's about 3.5" too short so i'm going to have TRF weld a section on.
Last edited by xcoldricex; 08-27-2011 at 07:03 PM. Reason: MSF Database - Automerged Doublepost
saitek (08-27-2011)
Coolant boiling over exhaust in coolant bcmurphy87 MazdaSpeed 6 - Engine, Transmission & Driveline 12 12-15-2010 02:39 PM
Angled CEL fix for catless DP Addikted To Boost MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 07-22-2010 07:35 AM
Hotchkis Rear Sway Bar Clunking Only When Angled Bump ms3brendan MazdaSpeed 3/6 - Suspension & Brakes 24 07-13-2010 10:36 AM
Stock turbo oil and coolant lines 06Speed6 MazdaSpeed 3/6 - Turbo Induction 16 02-06-2010 10:22 AM
Page generated in 0.34058 seconds with 26 queries
