![]() Join Date: Jun 2010 Location: Williamsburg,VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 11 Times in 3 Posts
(Thread Starter) | Not Ranked : 0 score Ok, so I have tried to figure out where in the world this KR is coming from. It is so effing frustrating. I have changed the mounting location of the CAI, changed the weight of the engine oil, checked all mounts, made sure all piping is secure and not rubbing or banging against any other metal parts. The only other thing that I can possibly think of is the fuel injectors moving and clanking around in the engine. Does that sound crazy? There is a bigger turbo now so the engine is working much harder including the injectors. I wonder if the seals are wearing now which is causing clanking. All mounts are solid and the rods are forged. What do you all think? |
![]() Join Date: Dec 2010 Location: Albuquerque, NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,614
Groaned at 9 Times in 5 Posts
Mods, logs?
__________________ 2009 MazdaSpeed 3 Spy Hunter Smoke Screen Mod Cobb AP (Custom Tune), ATP GTX3076 28PSi, CP Forged Pistons .020 Over, Pauter Forged Rods, Bore and Hone Block .020 Over, CP-E DISI Injector Seals, ARP Head Studs, MZR Cometic Head Gasket, ACT Stage 2 Heavy Duty Clutch,Cobb SRI Intake, JBR TIG, JBR TB Gasket, JBR 88 Duro Transmission Mount, JBR EGR Delete , JBR TB Coolant Bypass, CP-E Big Turbo TIP, KMD HPFP Internals, Street Unit TurboSmart Dual Port BOV, CorkSport TMIC, CorkSport DP, CorkSport Test Pipe, CorkSport CBE, CPE Single Guage Pod, DashHawk, Prosport Boost Gauge, Devils Own Progressive Methanol Injection Kit 80/20 with D07 Nozzle, E85 Tune 50/50, JBR DogBone 88 Duro Rear Motor Mount, CorkSport Mid Chassis Brace, JBR Stage 2 Short Shift Plate, H&R Springs, 18x8 Drag DR38 +47, Eibach 5mm Spacers, 235/40 18 Brisgestone RE760. | |
| The Following User Says Thank You to RayRay For This Useful Post: | skiptowncat (01-10-2012) |
![]() Join Date: Jul 2011 Location: Plantation, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,748
Groans: 97
| Not Ranked : 0 score Every time Ive heard of seals going supposedly they sound like popcorn poppin.
__________________ TEAM LUXURY ![]() |
(Thread Starter) | Not Ranked : 0 score Its so hard to hear the injectors while driving cuz the car is so loud. Mods are - GT3076R, Cobb AP, Wiseco pistons, K1 Rods, upgraded FP, FMIC, C-pe CAI, Catless turbo back exhaust, colder plugs and solid mounts. Tuned by P-Tuning. |
| The Following User Says Thank You to rorys speed For This Useful Post: | RayRay (01-09-2012) |
| Not Ranked : 0 score What kind of KR? WOT or PT? What values? Gonna post logs? What fuel? When was the rebuild done? By who? what does "P-Tuning" say about the KR? Have they made map changes to try & address the issue?
| Not Ranked : 0 score sounds like seals 100% if you have eliminated everything else. Try a little e85 and see if that helps with the knock. |
![]() Join Date: Jan 2009 Location: Baltimore, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,896
| Not Ranked : 0 score ^ This is a really good way to check if it's the tune or if its just from something clanking around the same frequency as knock. Just 1 gallon on a fill up shouldn't require any tuning changes or MAF cal.
__________________ 2006 Mazdaspeed6 GT BCM SpeedPerf6rmanc3 10.6:1 Pistons, PI Fuel Kit, PnP Head, 75mm TB, Pinned Cams/Keyed Crank, 11mm H11 Head Studs \\ PT&E PT6266 CEA BB S-Comp. \\ Manley H+ Rods \\ JMF V2 PI Intake Mani w/ Bosch 1000cc Injectors Squash Performance Top Hat w/ Dual DW300 Pumps \\ AEM FPR \\ Split Second AIC1 \\ CP-e LRT Ex. Mani, SAFEseals, RDM, EGRD \\ SURE TMM, PMM, Juggernaut, Anchors \\ TiAL MVR, Q \\ Bosch 4 Bar MAP HTP 4" Intake \\ Autotech HPFP Internals \\ ATP Catless DP \\ ACT HD 6-Puck w/ Streetlite FW \\ Cobb AP \\ Treadstone TR10 \\ Magnaflow CBE \\ MSD Dashhawk \\ JBR SSP, BSD, RMM Stratified EBCS \\ Corksport SS Braided Clutch Line \\ H&R Coilovers \\ SPC BJs \\ Rotora Drilled/Slotted Rotors \\ H2 Ceramic Pads \\ Enkei EKM3 7.5+45 \\ VG Sharkfin \\ RHO-Plate Most powerful MS6 720/584 @42psi E42 9Oct13 Tuned by NISHAN ![]() |
| The Following User Says Thank You to psychophyr For This Useful Post: | EdgeAutosport.com (01-10-2012) |
| Not Ranked : 0 score You could have a noisier engine because it is forged. Describe under what conditions KR is happening and post a log to show this. Also make sure the car is fully warmed up when looking at KR.
![]() Join Date: Aug 2011 Location: Columbus, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 68
| Not Ranked : 0 score Did you check your VVT chain/actuator? I had a thread about mine causing fake KR when I wasnt at WOT, I had to have the timing chain replaced bec of it not being heat treated property - caused it to stretch over time. EASY WAY TO TELL: after your car is warmed up (letting it run for @ least 10 mins) turn car off, remove cap where timing chain is and see if it has any give, it should be pretty tight - if it has some give to it - it could be loose causingresearch my thread "knock knock whose there"....thats just my .02 lol
__________________ The Money Pit: 2011 MS3 - Mica Black - Tech Package - Cobb SRI, TIH, AP, Hella horns, CP-E Stage II RMM, JBR OCC, SSB, ATP Catless DP, UR catback exhaust, Autotech HPFP Internals, Turbo Smart Kompact bpv, Sure Shortcut, DIY clutch travel mod, DMM tuning HID 4300K fogs, & Freek tuned! zoom zoom bitches... |
| The Following 2 Users Say Thank You to thomas_cory2000 For This Useful Post: | psychophyr (01-10-2012), rfinkle2 (01-10-2012) |
| Not Ranked : 0 score Thanked for name of thread lol
![]() Join Date: Jan 2011 Location: Woodbridge VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 262
| Not Ranked : 0 score this thread is fucking useless without a progress report... solve it?
__________________ [SIGPIC][/SIGPIC]--2010 BM MS3-- Treadstone tr8 fmic core with 2.5" piping ## self made 3.5" MAF ## Gtx3076 .82 a/r t-3/vband hotside ## RaceRoots EWG exh mani/3" vband ## RaceRoots tubular DP ## TIAL MVR EWG ## UR Catback ## Sure shortshifter plate ## Sure R3 rmm ## Eagle Rods ## Custom SP63 10.5:1 .020 over pistons ## balanced rotating assy ## ARP head and main studs ## Autotech internals ## Accessport ## 3bar map sensor ## vtcs delete ## EGR delete ## Balance shaft delete ## Hallman MBC ## HKS SSQV 4 BOV ## NGK iridium spark plugs ## Cusco OCC ## Aquamist HFS-4 Methanol injection with 2 gallon Howerton Engineering tank ## D2 coilovers ## Nextmod lip kit ## SPC rear camber arms ## Wedsport SA-15r 18x9.5 et +23 ## 225/45/18 NITTO Motivo tires ## chinese HIDs ## JB shift knob ## 35% tinted ## still RichTuning... |
| The Following User Says Thank You to drummermike58 For This Useful Post: | Fail_6 (03-07-2014) |
| knock retard after maf cal??? | greenespeed | MazdaSpeed 3/6 - ECU Computer Tuning | 10 | 10-31-2011 06:45 PM |
| knock retard after e85 mix | Mac21 | 2010 MS3 - Fuel, Nitrous & Water Injection | 11 | 10-05-2011 09:21 PM |
| knock retard at wot | Swearingen | MazdaSpeed 3/6 - ECU Computer Tuning | 14 | 04-22-2010 09:02 AM |
| knock retard | yang_jackson | MazdaSpeed 3 - Engine, Transmission & Driveline | 26 | 05-13-2009 04:55 PM |
| Knock retard.. gone | Doc | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 11-06-2008 11:45 AM |
