| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
(Thread Starter) | Not Ranked : 0 score I wanted to make a consolidated thread of people that are running BT's on the stock block, since I am considering doing this in the near future. It seems like our rods fly out of the engine because of high load/torque at low rpms. So, our motors may handle BT builds well as long as you don't run excessive boost at <3-3.5k rpm. I know there are at least a handful of people running BT's on the stock block so far with success - so can we log these? Please post your builds, dynos, tuning/tuners used, how long you've been running them, problems you've experienced, what made you part out (if you did), advice, etc. Calling these people: user name - car model - turbo model - tuning solution - dyno/timeslips - build/info links ----------------------------------------------------------------- Current Builds: GT2871
GT3076
Other:
----------------------------------------------------------------- Past Builds:
----------------------------------------------------------------- Blown Motors:
| The Following 16 Users Say Thank You to xcoldricex For This Useful Post: | -cj- (07-10-2010), AZSPEED3 (07-12-2010), BUNGEEZZ (07-12-2010), charlesfist (07-11-2010), Dre (07-12-2010), Fagwagon (07-12-2010), gsrtype1 (07-10-2010), holeinmypocket (07-12-2010), jayspeed3 (07-11-2010), manelscout4life (07-12-2010), MS3-a(sore)ASS-rex (07-10-2010), mxlplx71 (06-21-2012), SilverDemon (07-12-2010), Snyeed (07-10-2010), wette460 (04-22-2011), zx2man (07-13-2010) |
Groans: 224
| Not Ranked : 0 score Good idea making this thread, hopefully I'll be able to post my own build experience soon. Until then, I plan to gain all the knowledge from you guys that I can. Bet of luck to all of you!
| The Following 2 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post: | Dre (07-12-2010), xcoldricex (07-10-2010) |
![]() Join Date: Jun 2010 Location: Wade Lebron & Bosh county
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I think a big turbo would help us out because of the added turbo lag would make it near imposable to get out of vac before 3000 rpm. so the stress that the stock turbo was putting on at 2300/2500 rpm is eliminated. |
![]() Join Date: Mar 2008 Location: Virginia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 456
| Not Ranked : 0 score Mine is somewhere...GT2871r stock block. 21.5psi, cautious boost below 3k rpm.
__________________ '06 Black Cherry Mica Speed6 Since 2-26-07 | 0-60: 3.87s | CPE CAI, SU MM, Synapse BPV, Magnaflow 2.5" CBE, MDS DashHawk, TWM SS Stage 1, TT Front MM, TT Rear Diff Mount, SU StiffDiff, Whiteline RSB, BC Coilovers, mrlilguy CDFP, CPE Catted DP, HKS Twin Power Ignition System, RAYS Gram Lights 57 Maximum Time Attack, CPE TIP, Denso 2Step Colder Spark Plugs, COBB Shifter Weight, SPC Ball Joints, VTCS, BS, & EGR Delete, VentPod w/VEI Boost Guage, Saikou Michi CC, Labonte ISG-S3 (not installed), GT2871r, DNP manifold, Tial 44mm EWG, Cobb AP, TT Liquid to Air Intercooler, DMH 3" exhaust cutout. |
| The Following User Says Thank You to Smoker6 For This Useful Post: | xcoldricex (07-10-2010) |
| Not Ranked : 0 score stock block, stock clutch, stock trans 0.82 a/r t3 3071 http://www.mazdaspeedforum.org/forum/foru...sb-dyno-59440/ 450 awhp 527 awtq (corrected, see link above for all info on the dyno). I've tuned with both AP and SB... Just keep your head screwed on when tuning and make sure you know what your doing. IMO there were some serious fueling flaws in the ecu that contributed to many of the blown motors. Couple that with a knock happy motor at 5500 rpm and a deaf knock sensor at 5700 rpm, and it's easy to see how detonation could be common. So when your tuning / modding for power, just take proper precautions to avoid detonation, and baby step your way up to your final tune, and don't touch timing above 5700 rpm without using a dyno. I honestly think my motor would last a long time at this power level, but only time will tell i guess. Only problems i've had thus far is a crack happy exh manifold from a long ass dump tube. Oh and, i still stand by my thoughts that a bigger turbo (read efficient turbo) is SAFER for your block than a over worked stock k04, for obvious reasons.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com Last edited by djuosnteisn; 07-10-2010 at 03:29 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 7 Users Say Thank You to djuosnteisn For This Useful Post: | BUNGEEZZ (07-12-2010), Dano (07-11-2010), Dre (07-12-2010), Fobio (07-10-2010), MS3-a(sore)ASS-rex (07-12-2010), wette460 (04-22-2011), xcoldricex (07-10-2010) |
(Thread Starter) | Not Ranked : 0 score wow there are a lot more people than i thought - updated OP. |
![]() Join Date: May 2009 Location: N Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 523
Groans: 77
| Not Ranked : 0 score i don't have a thread but i have this setup for a few months now, ~7k miles.
__________________ 2008.5 MAZDASPEED3 GT TRUE RED ***GONE*** ![]() 2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19 |
| The Following User Says Thank You to dizzin9 For This Useful Post: | xcoldricex (07-12-2010) |
![]() haha just keeeeding.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following User Says Thank You to djuosnteisn For This Useful Post: | Dano (07-11-2010) |
Groans: 77
__________________ 2008.5 MAZDASPEED3 GT TRUE RED ***GONE*** ![]() 2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19 | |
| The Following 4 Users Say Thank You to dizzin9 For This Useful Post: |
| Not Ranked : 0 score now ur talkin! I just joined the BT crowd with about 1K miles on mine and I agree toatlly with what DJ says about a more efficient BT with just a lil more lag is all goodness for the MZR. I mean if the motor is already knock happy, why push a K04 into the flame thrower zone all the time. I guess that's why everyone runs WMI hahahah Anyway here are a few logs and things I had to overcome with my build. BT installed - setup questions Edit: Stock block with 33K miles with mods in sig ATP flanged, IWG, 2871, 14PSI WGA, w stock exmaini and NO Creep Self tuned with AP Full spool, currently 20PSI, by 3K RPM and it doesn't stop pullin...period. hit 7.2K rev limit numerous times cuz I am used to the K04 drop off in power....nonexistent with the 28 and it hits RL in a blip. I can't say enough about the power band. I tuned my K04 to not come on until 3K which was already 1K RPM of wasted power for it. Now I can use the full power range of the GT28. I have the 28 start spooling around 2750 and by 3K it is at my target boost and I run it to 7K where I shift and there is absolutely no drop in power. This turbo is what the car should have come with IMO. Not too big and not too small. This is my DD car and I am extremely happy with the results.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 07-11-2010 at 03:32 PM. |
| The Following 4 Users Say Thank You to Dano For This Useful Post: |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| Not Ranked : 0 score i just received my rr kit i need to get a 3076r ordered and im good to go. Ill likely do this on the stock block for now. I have all the parts to build my motor including flywheel,clutch but need to save to get the work done. Keep my fingers crossed and hope it holds together. |
| The Following User Says Thank You to NJSPEED3 For This Useful Post: | djuosnteisn (07-10-2010) |
![]() Join Date: Feb 2009 Location: Salt Lake City, Utah
Rep Power: 427 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 626
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score great thread, quick and easy reference to find information on the people running BT.
__________________ 417whp 428tq 12.037@117.2mph |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 358
Groaned at 49 Times in 36 Posts
| Not Ranked : 0 score SUP BITCHEZZZZZZZZZZZ
__________________ Mazdaspeed6,2006, 46k miles. COBB AP* Gt3076, 19psi. CPE dp (catless), Dnp Mani 38-EWG, CorkSport Dual CB, CPE BIG MAF SRI, Big Turbo Inlet, CPE Fuel Pump, HKS SSQ Black out edition, Ported stock intake Mani, Intake mani spacer (PT), 2 step colder plugs, FMIC Custom 3.5 inch core, Meth (PT), OCC, BSD, TTFMM, CPE Rear Diff, CPE engine Mount, H&R Springs, Whiteline Rear Sway Bar, Stage 1 short shifter kit Base+bushings, Rotora Break Rotors All 4 (Slotted), Techna fit Brake Lines, Ebc red Stuff pads All 4, Enkei PF01 18's Wrapped in 245/40/18 Falkanzzzz ... Stock clutch until i get some funds. I HAZ THE FASTEZ CAR ALIVE!!!!!!!!!!!! REDBULL FTW |
| The Following User Says Thank You to BUNGEEZZ For This Useful Post: | xcoldricex (07-10-2010) |
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,310
Groans: 102
| Not Ranked : 0 score GT3071r yo.
__________________ |
| The Following 2 Users Say Thank You to gsrtype1 For This Useful Post: | djuosnteisn (07-10-2010), xcoldricex (07-10-2010) |
(Thread Starter) | Not Ranked : 0 score more details please! also are most of these people running ATP turbos? |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score i know of another running blow through MAF and gt35r |
| The Following 2 Users Say Thank You to Deadman For This Useful Post: | djuosnteisn (07-11-2010), xcoldricex (07-11-2010) |
(Thread Starter) | Not Ranked : 0 score please give more information guys - how long you've been running them, tuning, atp vs. t3, impressions/dynos, etc. that information is what will make this thread useful. links to build threads if you have them too so i don't have to search through your post history ![]() also any stock block BT popped motors in recent history? i can't think of any. |
| Neutral : +1 score I've been running a 3071 for quite a while now, probably close to a year. And i'm not very "easy" on my car. When i drive it, i drive it hard. It's not dd, but it's also not pampered in anyway. I ran originally with an atp hotside and stock exh mani. Then i had creep so i blocked iwg and went with a pg mani ewg setup. Both those setups were tuned with AP, and i think i made like 38X corrected with the pg mani. Then i went t3 0.82 hotside, and switch to cp-e SB cause i had fueling (load) issues with AP. I also upgraded the exh mani to a DCR one off mani with 2" runners. This last setups was wrapped up like 2 weeks ago, and aside from the lil headaches here and there, my car is amazing. That's when i started making 450awhp and a whopping 540awtq. As far as tuning goes. It's pretty simple, always start from a safe point, and take baby steps toward your final goal. Be patient. Shit will go wrong, just take your time and you'll get it ironed out. Also, it's alot more work when you change alot at once, and sometimes makes the troubleshooting more difficult. Shit i still have like 3 current issues with my car i still have to iron out, but all in due time And it still runs fucking amazing right now! So happy with it hahahaha. Hopefully it doesn't blow up too soon.
| The Following 2 Users Say Thank You to djuosnteisn For This Useful Post: | Dano (07-12-2010), xcoldricex (07-11-2010) |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score wtf? did i miss these 450/540 dynos?! thanks for the very informative posts dustin. just curious - have you tried your old tunes with the load cap removed? wondering if cobb's fix really allows AP users to make more power. i'm setup to run both the AP and the SB/PNP with flashes. i started out with flashes way back with an SST, but never turned up boost. the SST crapped out on me right before I was going to turn up boost with the AP. I think it'd be useful to really show what tuning solution is capable of making more power. I was going to try both if the AP can calibrate to a larger MAF size. |
| The Following User Says Thank You to xcoldricex For This Useful Post: | MS3-a(sore)ASS-rex (07-12-2010) |
![]() | | #20 | ![]() |
But honestly, since i've gone SB, i don't think i'd want to go back to an AP. SB is just so much faster and easier to tune with. Only like 3 tables to play with, and you can make tweaks real time. Until AP offers something similar, i wouldn't even consider it. In fact i was just tuning my buddy's car last friday with an AP, and it sucked cause we had to pull over, turn the car off, flash the car, turn it on, do a pull, bla bla bla. I'm also curious to see if the AP can turn out some #'s too! I mean it kinda does on some cars, like brian's. His power and mine uncorrected are pretty damn similar (my torque is still outrageous). But i guarantee if he brought his car up to my elevation, it'd be pretty damn sobering for him. He'd effectively be losing 2.5psi, which is a considerable amount of power. Even anthony knows now from when he was here. It's hard to make high hp #'s at 5500 ft hahaha. My dyno thread is in the dyno section, called "car's no longer acting a fool".
| The Following User Says Thank You to djuosnteisn For This Useful Post: | Dano (07-12-2010) |
![]() | | #21 | ![]() |
| Not Ranked : 0 score haters gonna hate.... I love spending 4 minutes of "quality" time with my car while flashing a new map. And you can't run both the CPE flashes and AP. Swap SB and AP yes, but not with flashes which is where the powa is unlocked so there is no way to do a back to back test. I would suspect CPE currently has the advantage.
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score i've had the flashes and just loaded an AP map on top of it - i think it'd just disable the flashes though since it's flashing the whole thing... but i never had any compatibility problems (AP not working when I originally had flashes - I just saved my SB flashed ECU to the AP) yeah, i read that thread - i was experiencing the same stuttering/bucking recently on the stock turbo. I haven't had it since I transferred the map to the no load cap ATR and raised the load limits though. |
| The Following 2 Users Say Thank You to xcoldricex For This Useful Post: | Dano (07-12-2010), djuosnteisn (07-12-2010) |
![]() | | #23 | ![]() |
| Not Ranked : 0 score hum...interesting. I guess you just over wrote the flashes. so if you wanted to spend some coin you could tune to your best with the AP, dyno, then send the ECU off to CP-E get the flashes then tune with the SB and see where you ended up. Edit: hahahah i forgot about DJs lil pac man demo on the dyno. good stuff!
![]() | | #24 | ![]() |
![]() | | #25 | ![]() |
| Not Ranked : 0 score My car was NOT a happy camper at that time.
| The Following User Says Thank You to djuosnteisn For This Useful Post: | BUNGEEZZ (07-12-2010) |
![]() | | #26 | ![]() |
| Not Ranked : 0 score I WANT TO SEE DYNO!!!!!!!!!! MR DJ!!! MAKE MOVESS!!!
![]() | | #27 | ![]() |
| Not Ranked : 0 score All my dyno stuff is in the dyno section. If your saying you wanted to see my pac-man unhappy dyno, it was called, "cars acting a fool".
![]() | | #28 | ![]() |
![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 4725 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
| Not Ranked : 0 score ATP GT 2871 Stock Block 15psi fully bolted PnP stock intake mani DNP Exhaust mani Tune before load cap and Large MAF housing 345whp and 340wtqu Starting a new tune from scratch since CP-E's load cut flash was done Building a motor here > Short Block Is Done
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. |
| The Following 4 Users Say Thank You to SilverDemon For This Useful Post: |
![]() | | #29 | ![]() |
![]() Join Date: Sep 2008 Location: Soledad, CA
Rep Power: 445 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 393
Groaned at 5 Times in 2 Posts
| The Following 2 Users Say Thank You to 11cruzito11 For This Useful Post: | djuosnteisn (07-12-2010), SilverDemon (07-12-2010) |
![]() | | #30 | ![]() |
| The Following User Says Thank You to SilverDemon For This Useful Post: | djuosnteisn (07-12-2010) |
![]() | | #31 | ![]() |
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
| The Following 3 Users Say Thank You to Dano For This Useful Post: |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score just some more background on jlefebvre123's motor
![]() | | #33 | ![]() |
![]() Join Date: Apr 2009 Location: Albuquerque, NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,220
Groaned at 38 Times in 10 Posts
| Not Ranked : 0 score 2006 ms6 atp gt3071r dnp mani ewg'd dnp mani (sitting in garage) tial 44mm ewg (sitting in garage) atp dp dtuned fmic (sitting in garage) magnaflow cbe (sitting in garage) cpe big tip/xl xcel sri cpe fp sb plus all flashes no dyno as all parts havent been installed. DJ was my mentor on this whole build and i'm pretty damn satisfied with the car. Just installed cpe fp on saturday and have yet to turn up the boost on it but should be pushing 21-22psi after tonight assuming tuning goes well. |
| The Following 3 Users Say Thank You to spoonher For This Useful Post: |
![]() | | #34 | ![]() |
| The Following User Says Thank You to xcoldricex For This Useful Post: | djuosnteisn (07-12-2010) |
![]() | | #35 | ![]() |
| The Following 2 Users Say Thank You to spoonher For This Useful Post: | djuosnteisn (07-12-2010), xcoldricex (07-12-2010) |
![]() | | #36 | ![]() |
Groans: 78
| Not Ranked : 0 score <3
__________________ [Precision 5557 T4 flanged Journal Bearing Turbo][Race Roots Ceramic Coated T4 Manifold][Race Roots 3" V-Band Catless Downpipe][Race Roots Under-Car FMIC kit][CXracing 18"x31"x3" IC Core][Tial 44mm EWG With 0.9Bar Spring][Cobb AP][Full Str33tunit Mount Set][Madvillain 4" Inlet/Intake][Cp-e xcelXL Maf Housing][Devilsown Meth Injection Kit][HKS Ignition Amplifier][Cp-e Catback Exhaust][HKS bov][PTP IM Spacer][Whoosh EGR Delete][AEM Digital Boost Gauge][Matt Damond OCC Kit][Trunk Mounted Optima Battery with KnuKonceptz Kit][Madvillain ECU box][TWM Short Shifter][BC Coilovers][Cobb Rear Sway Bar][Falken Azenis rt615's][Eibach Pro 25mm Spacers] |
| The Following User Says Thank You to madvillain For This Useful Post: | djuosnteisn (07-13-2010) |
![]() | | #37 | ![]() |
| The Following 3 Users Say Thank You to djuosnteisn For This Useful Post: |
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score is your iwg ported? i saw a definitive answer regarding atp's "fixed" turbos - if they are actually fixed or not. |
| The Following User Says Thank You to xcoldricex For This Useful Post: | SilverDemon (07-12-2010) |
![]() | | #39 | ![]() |
| Not Ranked : 0 score I did my own port job on my 2871, I get just a tad of creep on the top end. This will be switched over to an ewg when the build is done...
| The Following 2 Users Say Thank You to SilverDemon For This Useful Post: | djuosnteisn (07-12-2010), xcoldricex (07-12-2010) |
![]() | | #40 | ![]() |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/stock-block-bt-build-threads-61143/ | ||||
| MattJackson86's Bookmarks on Delicious | This thread | Refback | 07-23-2010 11:35 PM | |
| How many ppl running BT's with stock block? | SpeedSixxx | MazdaSpeed 3/6 - Turbo Induction | 20 | 11-08-2009 12:30 PM |
| engine build with stock compression | Jessed87 | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 06-12-2009 11:55 PM |
| Safe Horsepower on stock engine build? | cl45music | MazdaSpeed 3 - Engine, Transmission & Driveline | 36 | 02-17-2009 07:27 AM |
| Need Help, what size are the threads of the stock 02 sensors? | Lymerock | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 12-15-2008 08:36 AM |
| So...Turbo/motor limits on stock block & internals? | 94jedi | MazdaSpeed 3/6 - Turbo Induction | 26 | 05-31-2008 08:01 AM |
