 Old 05-10-2011, 08:12 PM   #1
jayspeed's Avatar
Posts: 7   (View Stats)
jayspeed will become famous soon enough
Default Stock Boost controler with big turbo??
I can use my stock boost controler with my gt 3076??
jayspeed is offline   Reply With Quote
 Old 05-10-2011, 08:17 PM   #2
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
You can, but a lot of people get the Grimmspeed EBCS for better control. You can run MBC if you just want peak boost tuning. I'm gonna run MBC with BT.
2007 CTS-V - Trying to sell
dougefresh_ (05-13-2011)
 Old 05-13-2011, 04:05 PM   #3
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
You can also get the Perrin Pro EBCS. You run the after market ebcs (Perrin or Grim) in 'interrupt mode.' It reacts much faster than the stock bleed set up, and allows more control, but requires tuning (but you'll need that anyways). Here's more info than you'll want to know, including some links to Perrin's site that breaks down how iwg + ewg work w/ an ebcs in interrupt mode vs bleed (Ignore the splicing part as they now plug n play for MS3/6):
http://www.mazdaspeedforum.org/forum/foru...plicing-58098/
 Old 05-14-2011, 08:39 PM   #4
essejkcamraw's Avatar
Posts: 922   (View Stats)
what are you using to tune? i think AP users find it easier to use a EBCS where as cpe standback users use a MBC. i think cobb acutally suggest using a ebcs with the AP.
im drunk an could be full of shit though.
From built & Big turbo to Miata Gheys
The Following User Says Thank You to essejkcamraw For This Useful Post:
rigor (05-14-2011)
 Old 05-10-2011, 10:10 PM   #5
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
i don't think it works very well, i could be wrong but if it does
i sure fucked up lol
at 104000 2 bent rods
tuned by nishan
 Old 05-10-2011, 10:12 PM   #6
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
donate
 Old 05-11-2011, 10:09 AM   #7
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
im using grimspeed
06 Speed6 GT- Sold
 Old 05-11-2011, 07:28 PM   #8
zx2man's Avatar
Posts: 1,356   (View Stats)
zx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the world
Yeah I just learned today that u "can"...but its prefered to run the grimmspeed 3port, if your not going mbc.
So I got a question...Looking at my stock bcs vacuum routing, this is what I see. 1 line from bcs to turbo inlet, and 2nd line running from bcs to k04 wg. But there is a 3rd line running out of the bottom nipple of the k04 wg, going somewhere underneath the turbo inlet, what line is this??
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO*
zx2man is offline   Reply With Quote
 Old 05-11-2011, 08:03 PM   #9
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
The bottom hose is connects the turbo to the WGAand is the boost source... I use the hose on my bpv for a boost source for my 2871. and the top hose goes to the bc which as you know regulates the boost, but it always bleeds some boost.
Originally Posted by MattJackson86 View Post
So what are the benefits of upgrading to this EBCS? Any reason not to run this even if your not BT yet? I mean for $100...
I ran it on my ko4. It helped me hit higher boost... The problem is (from what I was told) is that the turbo is still working its ass off... It doesn't make the turbo more efficient... I guess you could do the same with an adjustable WGA... This is how I understand it anyway.
Last edited by Ckmazdaspeed3; 05-11-2011 at 08:03 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
MattJackson86 (05-12-2011), zx2man (05-11-2011)
 Old 05-11-2011, 07:46 PM   #10
MattJackson86's Avatar
Posts: 1,407   (View Stats)
MattJackson86 is offline   Reply With Quote
 Old 05-11-2011, 08:21 PM   #11
zx2man's Avatar
yeah with stock k04 just stick with the stock bcs. Our k04 is pretty small turbo,which is good and bad. Its good cause its fast response which makes a turbo awesome for daily driving, BUT it runs out of steam after 5500. Mazda wanted a dailydriver hatch that had good midrange response for the typical fuck. But alot of us are not typical fucks, were young dumb full of cum and wanna go FASTER.
But it also means the turbo makes power rather easily at lower psi levels. I made 291 whp @ 17 psi tune that tapers to 15 psi by redline. Gsr1type made 300+ whp on 16 psi tune via Jake through Cp-e SB....good tuner produce good results. And the stock bcs will be just fine.
Once you start craving more power, and go bt, then thats the time to upgrade your boost controller.
ckmazdaspeed3- Yeah Im going to Tee off my bpv line and use that as my boost source, then run a line from my turbo inlet to Grimmspeed, and another line from ewg to Grimmspeed, then drive it down to Surgeline and if Tim wants to change shit, go for it..but that should be good enough to hobble my car down for a tune LOL
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
COBB RSB
The Following 4 Users Say Thank You to zx2man For This Useful Post:
Ckmazdaspeed3 (05-11-2011), emag remrofni (05-11-2011), essejkcamraw (05-14-2011), MattJackson86 (05-12-2011)
 Old 05-11-2011, 08:33 PM   #12
Groans: 134
Yeah, I read somewhere (I think either Danos BT thread or boost tuning thread) Dustin saying that the way I have it set up and the way you are planning on setting it up is not true three port. I am not EWG, so I'm not sure how they work, but I am under the impression that they habe two nipples like the ko4 WGA and you set up true three port differently... But like you said, you will let Tim do what he thinks is best, and I'm sure that is the best plan... Kinda wish I went EWG.
 Old 05-11-2011, 11:01 PM   #13
driver311's Avatar
Posts: 1,769   (View Stats)
Im running the stock solenoid right now controlling my 3071r to the beat of 18psi. So it can be done.
Mazdaspeed
Stock turbo boost capabilities manofhonor24 MazdaSpeed 3/6 - Turbo Induction 26 04-07-2017 05:28 PM
Stock turbo boost dkspeed MazdaSpeed 3/6 - Turbo Induction 3 07-10-2009 05:02 PM
how much boost can your stock turbo hold? johnac08 MazdaSpeed 3/6 - Turbo Induction 16 03-18-2009 01:12 PM
Boost Controler Question speed3 MazdaSpeed 3/6 - Turbo Induction 8 04-15-2008 07:11 PM
Boost Controler Question speed3 MazdaSpeed 3/6 - Turbo Induction 13 04-02-2008 06:09 PM
Page generated in 0.33310 seconds with 30 queries
