Like Tree12Likes
 Old 03-19-2013, 07:34 PM   #81
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
Originally Posted by madspd6 View Post
did you forget to put the pcv back in? haha
Oops I forgot the picture. Let me add that in here
Edit nvm its there.
Here it is again
Performance:
Stratified Tune in progress
 Old 03-19-2013, 07:56 PM   #82
IamJamen's Avatar
Posts: 789   (View Stats)
Default Re: Stock Motor GT2871R
There's a whole thread in the CorkSport section about their v1 OCC fails. CS exchanged my early OCC for their updated unit which now features a welded top and no glue.
The Following User Says Thank You to IamJamen For This Useful Post:
Swinger13 (03-19-2013)
 Old 03-19-2013, 08:16 PM   #83
Swinger13's Avatar
Groans: 53
Yeah I heard about that. If I were to re do my OCC set up again with this catch can, I wouldn't connect from the PCV -> OCC -> IM.
It would be PCV -> OCC -> Turbo Inlet.
This way there would be a constant vacuum and no boost to blow ANY catch can.
I will be hammering corksport about this...
Performance:
 Old 03-19-2013, 08:19 PM   #84
IamJamen's Avatar
CS recommends PCV & VC to a T connector > OCC > TIP with their kit which is the way I have it set up. Here are my last two drains:
 Old 03-19-2013, 08:22 PM   #85
Bob-o's Avatar
Posts: 1,312   (View Stats)
Holy shit!! The top for real blew out.
Do you know what would have caused that? You should contact CS and see what they say
 Old 03-19-2013, 08:23 PM   #86
Dmurray06's Avatar
Posts: 3,279   (View Stats)
CS recommends PCV & VC to a T connector > OCC > TIP with their kit which is the way I have it set up. Here are the my last two drains:
How many miles?
 Old 03-19-2013, 08:24 PM   #87
IamJamen's Avatar
Originally Posted by Dmurray06 View Post
How many miles?
500 and 600.
The Following 2 Users Say Thank You to IamJamen For This Useful Post:
Dmurray06 (03-19-2013), Swinger13 (03-19-2013)
 Old 03-19-2013, 08:26 PM   #88
Dmurray06's Avatar
500 and 600.
Jesus...that's a lot for such few miles. Yea @Swinger13; I had the first version OCC BNIB. Emailed Corksport, and they are exchanging it straight across for the welded version. 0 cost to me.
 Old 03-19-2013, 08:26 PM   #89
Swinger13's Avatar
Groans: 53
just boost lol. The lid is only held down with glue and the lid doesn't appear to be cracked or anything. Under vacuum it's fine because in theory it should be holding the top down.
I be boostin...
but hey I'm glad this is the problem and not my motor; there is always worse things that can happen...
Performance:
 Old 03-19-2013, 08:40 PM   #90
IamJamen's Avatar
Jesus...that's a lot for such miles.
Those are the only times I have drained the can. Besides that, I think Michigan winter and my short commute have something to do with it.
I be boostin...
Don't tell CS that you didn't have a check valve between your OCC and intake manifold. They could cite improper installation and void your waranty.
Last edited by IamJamen; 03-19-2013 at 08:40 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-19-2013, 08:42 PM   #91
Bob-o's Avatar
I be boostin...
Thats a good way to look at things, and its a very good thing this was the issue and not your motor itself. Hopefully this will be remedied soon, and your current can gets replaced with something a little stronger
 Old 03-19-2013, 08:45 PM   #92
Swinger13's Avatar
Groans: 53
so you assume I didn't have it on? you're not helping my case lol
Performance:
 Old 03-20-2013, 04:31 PM   #93
AustinK's Avatar
Posts: 175   (View Stats)
AustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the world
Hey swinger, thought I would drop in and check out the build, looks fantastic!
AustinK is offline   Reply With Quote
The Following User Says Thank You to AustinK For This Useful Post:
Swinger13 (03-20-2013)
 Old 03-20-2013, 05:16 PM   #94
Swinger13's Avatar
Groans: 53
Thanks. So far everything has been successful (other than the OCC but that's nothing to whine about).
Performance:
 Old 03-20-2013, 07:54 PM   #95
Swinger13's Avatar
Groans: 53
Ok I have all the pieces now for the turbo install. Got the helihose I need to route the BPV to the inlet.
I'm so confused as to what is needed for putting in the turbo as far as oil and coolant lines go. I was under the impression that you can use the factory lines but I'm not sure to be honest.
Can anyone give me more information on this? I would like to use the factory lines lol...
@Voltwings; @Lex; @06Speed6; @PartiAudiMazdarati; <----users that have given me positive feedback/suggestions in this thread (thank you)...
Performance:
The Following 2 Users Say Thank You to Swinger13 For This Useful Post:
Fail_6 (03-22-2013), Voltwings (03-20-2013)
 Old 03-20-2013, 08:20 PM   #96
Voltwings's Avatar
Posts: 3,713   (View Stats)
You use the factory oil feed but need a new banjo bolt for it, as well as a new oil return. You use one factory coolant line ... I believe the return, but need a new feed. You need a new coolant line that comes off the egr box, whichever that is, feed or return. Edge will sell you the kit for like $200.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 03-20-2013, 09:44 PM   #97
Swinger13's Avatar
Groans: 53
My turbo comes with banjo bolts. Here's some pics to make sure these are the right ones...
The red circle is the oil feed and the green is the coolant (feed/return)?
The coolant bolt(s) and line
The oil drain, feed, banjo bolt for the feed, and gasket for the drain.
So what do I need??? lol
Performance:
 Old 03-20-2013, 11:45 PM   #98
Voltwings's Avatar
Attachment 99297
Attachment 99295Attachment 99296
Attachment 99301Attachment 99300Attachment 99299Attachment 99298
Looks like you have everything sir, slap that bitch on!
Past:
-Sold-
-Sold-
Current:
Swinger13 (03-21-2013)
 Old 03-21-2013, 12:03 AM   #99
Swinger13's Avatar
Groans: 53
I hope you're right lol. It's just so misleading when everyone else says you need this and that on top of your turbo even though on the ATP site (and from common knowledge) that this turbo is a direct bolt on piece.
Performance:
 Old 03-21-2013, 12:18 AM   #100
Voltwings's Avatar
I've you've been reading the BNR install threads that might be what's throwing you off. I installed my turbo with nothing other than what came in the box.
Past:
-Sold-
-Sold-
Current:
 Old 03-22-2013, 09:06 AM   #101
Fail_6's Avatar
Posts: 2,305   (View Stats)
Fail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the world
I used the factory lines to an extent, but had to modify a couple. The coolant feed (line connecting to EGR) was an aftermarket braided piece that extends from the rear of the turbo to the connection on the egr.
The oil feed and the coolant return just need to be bent into place. Be VERY careful with the oil feed though, it takes some slight effort to bend, but you don't want to give too much effort and break it.
Oil return will be the biggest bitch, I had to unbolt from the block, and manually cut the top portion that fit the K04 and hose clamp on the return that fit the turbo. Sounds jerry rigged, but in practice, it's worked without issue 10k+ daily driving, several hundred pulls and even a dyno or two.
Turbo should've came with the banjo bolts as well, though you can order one if necessary for I believe under $10
2006 Black Mica MS6 GT
FreekBuilt Longblock, Manley 9.5:1, Manley H Beams, BW S300SX 6268 1.00 A/R, Dual Tial 38mm MVR EWG, Twinscroll Tubular Top Mount, EGR Delete, Labontes Stage 2 Meth Kit w/ D10, Grimmspeed 3 port EBCS, 3 Bar Map Sensor w/ Matt Jackson Harness, PERM 4" Intake, Cp-E HPFP, CX Racing FMIC, HKS SSQV V3, NGK IX 6510's, Toyota Injector Seals, PERM Catless 3" Turboback w/ dual Magnaflow Magnapaks, PERM Top Mount Valve Cover, PNP Intake Mani, BSD, ACT ZX4-HDG6, Bilstein HD Shocks, H & R Springs, Stoptech Slotted Rotors w/ API Ceramic Pads, JBR Heavy Shift Knob
Stock motor w/ GT2871r:
380 awhp, 375 awtq @ 24 psi (e85 only)
- 13.1 @ 110, 2.1 60 ft
Fail_6 is offline   Reply With Quote
 Old 03-22-2013, 10:25 AM   #102
Swinger13's Avatar
Groans: 53
I have all the banjo bolts. The coolant feed line I have. So it sounds like I'll be able to survive. There's an auto parts store in town that I'd be able to grt that stuff if need be so I should be good.
Performance:
Fail_6 (03-22-2013)
 Old 03-24-2013, 02:42 PM   #103
Swinger13's Avatar
Groans: 53
Ok those with a big turbo...hows the easiest was to put this thing in as far as making room goes (removing the manifold, hoses, downpipe, etc...)?
Performance:
 Old 03-24-2013, 02:46 PM   #104
chuckms6's Avatar
Posts: 1,618   (View Stats)
Remove the cowl
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
The Following User Says Thank You to chuckms6 For This Useful Post:
Swinger13 (03-24-2013)
 Old 03-24-2013, 02:57 PM   #105
Tabasco69's Avatar
Posts: 554   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
they fucking GLUED the occ lid on?....wtf a small pressure spike could and evidently would blow the top off..,.I'm sorry but this is just common sense, it is not rocket science.....who ever call it was at CS to do that should no longer have a job.
425whp/395ftlbs - GTX3071R .82a/r- 20psi- 92 octane pump fuel
Tabasco69 is offline   Reply With Quote
The Following User Says Thank You to Tabasco69 For This Useful Post:
DoMiNic (05-08-2013)
 Old 03-24-2013, 03:18 PM   #106
chuckms6's Avatar
The way the instructions had it installed it should never see pressure. A quality control issue allowed the glue to accumulate in the ports and allow it to build pressure and blow the top off. They are all recalled and welded now
 Old 03-24-2013, 03:29 PM   #107
Swinger13's Avatar
Groans: 53
New can is on the way
Performance:
chuckms6 (03-24-2013), Dmurray06 (03-24-2013)
 Old 03-30-2013, 09:32 AM   #108
Swinger13's Avatar
Groans: 53
UPDATE.
I did get my catch can from corksport (not yet installed but I plan to today or tomorrow).
Also, I ordered a set of AWR motor mounts from protege garage and shipping is taking ridiculously long. The order history on their website said the package shipped on march 4th. I emailed ken at PG, got the tracking info and found that the package was only electronically processed on MARCH 19TH!!!! It's march 30th now and I still do not have it here; shipping was 75 bucks too lol. I ended up bitching and got my shipping costs refunded
On a brighter side, I did help @Bob-o; install his gtx3071R EWG on Thursday and Friday. I now have a great understanding as to what will be needed to drop in my gt2871r. ALL the factory feed lines should work and I know how to tweak the lines properly if need be. We ended up tweaking the coolant drain (the one that routes into the coolant hose and not the EGR. We basically turned the line around so the end of the hardline was almost hitting the block and bent it under heat to point straight down.
Comparison
The underside and the ghetto rigged coolant line lol. Just kidding it actually looks really solid and absolutely no leaks.
All feed/drain lines are in
All systems go !!!!
Bob-o likes this.
Performance:
The Following 3 Users Say Thank You to Swinger13 For This Useful Post:
Bob-o (03-30-2013), Dmurray06 (03-30-2013), Fail_6 (04-05-2013)
 Old 04-03-2013, 07:55 PM   #109
Swinger13's Avatar
Groans: 53
Okay so I installed the new catch can routing back to my intake and all is well
Also decided to dip my wheels as the original rattle can paint job was chipping and fading
Now I also looked under my car around the turbo area and realized that I won't be able to do anything there because my damn transfer case is in the way. Kinda thought about it and I could make more room if I completely remove the downpipe and disconnect the driveshaft.
Anyone that has done an ms6 BT swap chime in on this??? @PartiAudiMazdarati; how did you work around doing the swap and getting to the lines going to the turbo? I my first idea was to just disconnect a lot of the hoses around the driver side of the turbo, exhaust manifold removal, and downpipe removal as well.
Performance:
 Old 04-04-2013, 10:47 PM   #110
Fail_6's Avatar
Attachment 101506Attachment 101507
I disconnected the motor mount, and jacked up the engine. Allows you to more freely move the motor, specifically forward and back, which will come in handy when mounting turbo to the mani. I did not have to disconnect the driveshaft though; only took out the dp. That will give you more than enough room to work. Driveshaft is only in the way if you're trying to direct a dump tube for a wastegate or something. Disconnect the o2 sensors and zip tie them so they don't get damaged, and you should have a large path of space looking straight down through the engine to the ground.
1 tip is to mount the oil return first. Make sure it's postioned properly. If not, it will be damn near impossible to line it up straight, and then mount the turbo to the mani, and the mani to the block. Once the oil return and feed is done, the coolant lines are relatively flexible (in my case) so shouldn't be too much work. Also drain the coolant fluid. Make your life easier. Check my thread if necessary, there's some pics
http://www.mazdaspeedforum.org/forum/foru...nstall-114544/
The Following 2 Users Say Thank You to Fail_6 For This Useful Post:
Mistersix (04-05-2013), Swinger13 (04-04-2013)
 Old 04-05-2013, 05:47 AM   #111
Mistersix's Avatar
Posts: 2,585   (View Stats)
Didn't get to read your thread yet parti. Does one have to remove the mani to swap in a BNR?
The Following User Says Thank You to Mistersix For This Useful Post:
Fail_6 (04-05-2013)
 Old 04-05-2013, 08:29 AM   #112
IamJamen's Avatar
Nope, @TiGraySpeed6 installed his BNRs3 without taking out his exhaust manifold.
Install notes from TiGraySpeed6
The Following 3 Users Say Thank You to IamJamen For This Useful Post:
Fail_6 (04-05-2013), Mistersix (04-06-2013), TiGraySpeed6 (04-05-2013)
 Old 04-05-2013, 09:11 AM   #113
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Yup, left the IM in place, and if I had to do it all over again I'd still leave it in place.
Very do-able with the IM still in.
340hp / 371tq
 Old 04-05-2013, 09:42 AM   #114
Fail_6's Avatar
Correct, mani removal is not needed sir :-)
dot584 likes this.
 Old 04-06-2013, 06:25 AM   #115
Mistersix's Avatar
Awesome-ness. Thats one less gasket to buy.
Fail_6 (04-06-2013)
 Old 04-06-2013, 03:22 PM   #116
Swinger13's Avatar
Groans: 53
Gots me motor mounts! AWR 88 duro all the way around. That's how you shake dat ass...
Now I was dissapointed with the rear motor mount a little. When you receive something in the mail you buy brand new you expect it to look good. There were deep scratches/paint chips on it BNIB. Not that this will affect anything but WTF?
On a side note, i did notice that the holes for the bolts are 2 different inner diameters. I cant be 100 percent but I think both bolts are the same? Can someone comment on this? @Mistersix; I see you have AWR's in you sig....
Performance:
Javi (04-24-2013)
 Old 04-06-2013, 03:31 PM   #117
Swinger13's Avatar
Groans: 53
Even with a GT28?
Performance:
 Old 04-06-2013, 06:57 PM   #118
madspd6's Avatar
Posts: 1,009   (View Stats)
madspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the world
Groans: 31
Even with a GT28?
gt28 is about bnr size. it could be done but i personally think more room is a good thing. Who knows, he might be really small... perhaps a midget.
Velocity Red Mica 06 Speed6 (ricer) #834
Some shitty; s300sx fmw turbo, home made fmic setup, home made 4" Intake, 3.5 blowthrough maf, home made downpipe, poorly self tuned. More motor mounts then necessary.
Gay and coated white enkei rpf1s with stupid 245/45 tires. Pointless drilled and slotted rotors. Clunky coilovers. Ricer lips and lights.
madspd6 is offline   Reply With Quote
The Following User Says Thank You to madspd6 For This Useful Post:
Fail_6 (04-07-2013)
 Old 04-06-2013, 09:45 PM   #119
Mistersix's Avatar
@Swinger13; If i recall correctly they indeed are different size's. It only goes in one way so there's no way to fuck it up. But this was over 5 years ago when i installed mine so... grain of salt, if you will.
Swinger13 (04-06-2013)
 Old 04-06-2013, 09:50 PM   #120
madspd6's Avatar
Groans: 31
yeah the bolt to the car is smaller then the bolt to the motor.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/stock-motor-gt2871r-139264/
BattleProject ? View topic - 2006 Mazdaspeed 6 This thread Refback 10-07-2013 09:34 PM
New member MS6 BT - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 05-17-2013 12:00 PM
BT stock motor ms3/6 miledge zx2man MazdaSpeed 3/6 - Big Turbo Builds 15 06-30-2011 09:59 PM
Rear Stock motor mount mod 86AmishMs3 MazdaSpeed 3 - Engine, Transmission & Driveline 13 07-27-2010 03:07 AM
Highest RPM stock motor can be rev'd to... ?? all4bspinnin MazdaSpeed 6 - Engine, Transmission & Driveline 17 08-31-2009 02:49 PM
Motor Mounts in stock? TheDoc Mazdaspeed3/6 General Discussion 1 07-09-2008 12:50 PM
Page generated in 0.66943 seconds with 32 queries
