Like Tree18Likes
 Old 08-06-2014, 07:44 PM   #1
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
Default SweBuild [SP63 Engine GTX3076 EWG]
Hi guys!
It's been a long wait but i can finally make my own big turbo thread! And what an asskicker of a kit i will be installing!!
If i had known that it would take cpe almost 2 years to complete the MS6 Atmosphere kit and ship it out i would have gone a different route... But I hung in there and it has finally arrived!
For now i will stay stock block but in the future i'm aiming at a forged block, maby from the god of disi building (Freek). @Lex; will handle the tuning! I will use oem BSC coupled with Boost Dial to control boost.
I will keep the TMIC and see how it performs. I think a meth kit will help alot to bring bats down to acceptable level. A custom FMIC might be on my list later on.
For those of you that don't know what the CP-E Atmosphere Turbo Kit includes; Here's a list:
  • Tial V-Band Turbo (GTX3076 .82AR was my choice)
  • Tial MVR 1 Bar Wastegate with hardware
  • CP-E V-Band Manifold
  • Speed6 DownScream Downpipe (catless)
  • CP-E XcelXL Intake (3,25" ID MAF) + Nviscid Big Turbo TIP (3" ID)
  • 2,5" and 2,25-2,5" couplers for turbo->intercooler (i will not use these)
  • CNC Lathed Oil Feeder Block-Side Adapter
  • Custom CNC -8 Sump Female Block Oil Drain Flange
  • CP-E -8AN Male Turbo Oil Drain Flange
  • Oil Feed Turbo-Side Restictor Fitting
  • Tial 300+355 V-Band Clamps
  • Hose Clamps
  • 16" Steel braided -6AN Coolant line Banjo Hose End
  • 20" Steel braided -8AN Coolant line -8AN Straight Hose End
  • 24" Steel braided -4AN Oil feed line /w two -4AN 90* Hose Ends
  • 3.75" Black Push-Lock -8AN Oil return line /w two 45* Hose Ends
  • -8AN Male Banjo Fitting
  • -8AN to -8 Sump Adapter Fitting
  • .71" OD Copper crush washer
  • .80" OD Copper crush washers
  • O2 Bung Cap
  • Oil Drain Gaskets
  • 2.75" T-Bolt Clamps
  • M8-1.25x20mm SHCS Bolts
Some pornpics:
GTX3076 & CPE Mani
DownScream Downpipe
K04 is out!
This is where i'm at right now! I need to remove the alternator to get to the oil feed bolt and remove the whole thing. It's replaced completely with a new line and fittings
Here's the new oil feed
Much more pics to come when the parts are installed
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
The Following 17 Users Say Thank You to SpeedRebirth For This Useful Post:
brandonf (08-24-2015), Bulgsta (09-15-2014), Cheapspeed (08-06-2014), Code Monkey (08-06-2014), Dralphy (07-29-2015), Easter Bunny (08-07-2014), ESA (08-14-2014), gsrtype1 (05-12-2016), ItsNox (08-10-2014), Lex (08-07-2014), magicka (08-07-2014), Mauro_Penguin (08-06-2014), Pointless (08-07-2014), Poohster (08-12-2014), Pu Manchu (08-06-2014), speedfreak44 (05-15-2015), thems3driver (08-06-2014)
 Old 08-06-2014, 08:08 PM   #2
So this is the adapter that bolts to the block for the oil return line....
Easter Bunny (08-07-2014), impossible (07-30-2016), Mauro_Penguin (08-06-2014), Poohster (08-12-2014), SpeedRebirth (08-07-2014)
 Old 08-06-2014, 09:21 PM   #3
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
hopefully you saved the money you'll need for the engine rebuild in 3.... 2.... 1....
94 M
MS6
IS350
The Following User Says Thank You to Pu Manchu For This Useful Post:
 Old 08-07-2014, 02:12 AM   #4
Groans: 33
That's the one! Cpe would sell alot of these if they offered them separately
The chance of blowing up isn't any greater than guys with 2867 turbos, it's all in the tune
Mazdaspeed6 -06
290 AWHP / K04
The Following 8 Users Say Thank You to SpeedRebirth For This Useful Post:
802MS3 (08-07-2014), anavrinIV (08-07-2014), Code Monkey (08-07-2014), Easter Bunny (08-07-2014), impossible (05-10-2016), Lex (08-07-2014), Poohster (08-12-2014), SarcasticOne (08-12-2014)
 Old 08-07-2014, 05:19 PM   #5
Pu Manchu's Avatar
Groans: 546
the difference is the headroom you've given yourself.... we all inevitably get bored and want more
94 M
MS6
IS350
 Old 08-09-2014, 07:31 PM   #6
Groans: 33
Turbo, manifold, downpipe, wastegate and intake is installed!
I just want to make sure that the wastegate is properly setup, so i need some feedback on what ports to use and what should be connected to them!
I have the Boost Dial connected to the lower port on the wastegate, is this the correct way? I've read/seen that some have 2 hoses connected to the EWG. And some even leave the top port vented
This is the diagram i'm following and it's all connected like this. All i need to know is what ports should be used on the EWG
Lastly, how hard can we drive without needing watercooling on the EWG?
More installpics coming when this is sorted
Mazdaspeed6 -06
290 AWHP / K04
Lex (08-12-2014)
 Old 08-11-2014, 08:12 PM   #7
I looked into this a bit for my build. From what I've seen people only really water cool it if the wastegate is sitting very close to or is hidden under the mani tubing. With the Cp-e mani I think it sits far away enough to not need water cooling.
SpeedRebirth (08-12-2014)
 Old 08-12-2014, 08:50 AM   #8
Poohster's Avatar
Posts: 353   (View Stats)
I'm so jealous!!!!. That oil return return is what I am looking for. Too bad CPe decided not to sell components separately. GL with the build.
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline   Reply With Quote
The Following User Says Thank You to Poohster For This Useful Post:
SpeedRebirth (08-14-2014)
 Old 08-12-2014, 08:57 AM   #9
The way you have it setup is correct. Make sure there are no other lower air ports open on the wastegate.
 Old 08-14-2014, 06:53 PM   #10
Groans: 33
I did hook the ewg/bcs up the right way the first time so no drama there Thanks for the reassurance lex!
Everything is installed and the car has been driven about 600km. I still have the bad boostleak that i had before i even installed this kit. So air is leaking somewhere, injector seals maby? Cracked intake mani? Suggestions? Im trying to get an apointment to get a real leaktest done, prefeably with smoke so i can see where it's escaping.
Now, time for all the juicy pics from the install I have alot more so if there's something you would like to see from a better angle just say the word
Turbine side! Tial housing is as pretty as it gets =)
CP-E EWG Mani is what everyone needs
3,25" MAF + 3" TIP
Tial EWG kit
Best looking downpipe i've seen
Oil return, block side
Turbo and mani are being married, it was beautiful!
Time to install
Almost everything is out!
I dropped everything in at the same time
Porn? =)
Feed and return
Downpipe is in!
And EWG connected, first to the downpipe and then to the mani. You need a friend to lift/twist/push the downpipe to get the perfect alignment
Heater hose extended
Intake is in!
Code Monkey and ItsNox like this.
Mazdaspeed6 -06
290 AWHP / K04
The Following 6 Users Say Thank You to SpeedRebirth For This Useful Post:
Code Monkey (08-14-2014), Dralphy (07-29-2015), ESA (08-14-2014), ItsNox (08-16-2014), magicka (08-15-2014), Poohster (08-15-2014)
 Old 08-14-2014, 07:30 PM   #11
Looks tits! Can't wait to see what it can do on a good tune!
 Old 09-14-2014, 07:55 PM   #12
Poohster's Avatar
Any updates after the tuning?
 Old 09-18-2014, 02:45 PM   #13
Groans: 33
I'm still on the baseline tune. Had a leak that took a while to fix. Sent logs to alex a week ago so now i'm waiting for revision 1.1! Exciting stuff!!
Logged 4th gear and i'm pretty happy with the result, 300awhp on spring pressure Boost is usually around 20-22 psi to redline! 20 psi at ~4k rpm is pretty neat considering it's delayed in the tune
Gotta love that manifold! =)
300awhp with 8* timing... it's just the beginning Ran 20* with k04
Mazdaspeed6 -06
290 AWHP / K04
The Following 4 Users Say Thank You to SpeedRebirth For This Useful Post:
Code Monkey (09-18-2014), Lex (09-23-2014), magicka (09-18-2014), Poohster (09-18-2014)
 Old 09-18-2014, 08:16 PM   #14
igve2shtz's Avatar
Posts: 72   (View Stats)
igve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant future
Sweet Jesus that is a good looking turbo kit.
2006 MS6 Velocity Red Mica
SP63 built motor - SP63 9.5:1 Pistons - Manley Rods - JBR TRU-3" intake - BNR S3 - ETS 3.25" TMIC - Cobb XLE BPV - SP63 IM Port n' Polish - JBR TB TIG - JBR IM TIG - 3 Bar PnP (RPM) MAP - Autotech HPFP Internals - cp-e SafeSeals - NGK Plugs - Streetlite Flywheel - ACT 6 Puck Clutch - GrimmSpeed EBC - BSD - cp-e Catted Downpipe - Magnaflow CBE - cp-e RDM - cp-e Motor Mount - BC Coilovers - 215/45/18 Kuhmo 4x All-Season - Cobb Accessport V2- Prosport Premium Boost Gauge - Vent Pod - Dashhawk - Audiolink iPod Adapter
igve2shtz is offline   Reply With Quote
The Following User Says Thank You to igve2shtz For This Useful Post:
SpeedRebirth (09-18-2014)
 Old 09-23-2014, 02:52 PM   #15
cocoanton's Avatar
Posts: 168   (View Stats)
cocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the world
Shit dude, missed this. Love the kit. Can't wait to see it person. Lets just hope I get to see it before she blows
cocoanton is offline   Reply With Quote
The Following User Says Thank You to cocoanton For This Useful Post:
SpeedRebirth (09-23-2014)
 Old 09-26-2014, 01:18 PM   #16
Groans: 33
Nothing's gonna blow here but my girlfriend
Received revision 1.1 today from alex, and here are the results:
Same boost (spring pressure lol), timing increased to 13.5 at redline, load target is 2.4, flows 380-400 g/s at 6k+ rpm
Mazdaspeed6 -06
290 AWHP / K04
 Old 09-26-2014, 01:28 PM   #17
Looks great but there is no way you are running 36 psi of boost?
 Old 09-26-2014, 01:34 PM   #18
Police - Grammarhead
Vansquish's Avatar
Something has to be wrong with that graph. If you're running 36psi of boost, you should be at something at or above 500awhp, not 331...
DAMN YOU!!!
Code Monkey (09-26-2014)
 Old 09-26-2014, 02:34 PM   #19
Groans: 33
Haha, im using versatune and it logs atmosheric pressure. So 36 - 14.5 = 21.5
Mazdaspeed6 -06
290 AWHP / K04
The Following 3 Users Say Thank You to SpeedRebirth For This Useful Post:
Code Monkey (09-26-2014), Snip (09-27-2014), Vansquish (09-28-2014)
 Old 09-26-2014, 03:40 PM   #20
ffz
ffz's Avatar
Posts: 82   (View Stats)
ffz has a reputation beyond reputeffz has a reputation beyond reputeffz has a reputation beyond reputeffz has a reputation beyond reputeffz has a reputation beyond reputeffz has a reputation beyond reputeffz has a reputation beyond reputeffz has a reputation beyond reputeffz has a reputation beyond reputeffz has a reputation beyond reputeffz has a reputation beyond repute
Can't wait to get my CPE manifold and turbo.
Looks good Johan, fingers crossed the block stays 'safe'.
Chris (the one with all the meth)
Sent from my GT-N7105 using Tapatalk
Precision 5862 - Tial 44mm EWG - Kozmic Dump Tube - Kozmic Downpipe - CPE Exhaust Manifold - Kozmic Primary EGR Delete - JBR Secondary EGR Delete - Grimmspeed 3 Port EBCS - Mishimoto R-Line FMIC Core - HDI Intercooler Pipework (Modified) - JMF Intake Manifold w/Port Injected Meth - AEM Oil Temp Gauge - AEM Meth Flow Gauge - AEM Multi-input Meth Controller - Devil's Own Meth Pump - Bosch 3.5bar MAP - HTP 4" Intake - HTP 51r Battery Tray - Kozmic OCC - Autotech HPFP Internals - JBR BSD Delete and Oil Pan Baffle - Manley Connecting Rods - Wiseco Pistons - Forged by myself
KW V3 Coilovers - Corksport Adjustable Camber Plates - Corksport RARB - SPC Rear Camber Arms - Stoptech Discs (F/R) - Ferodo DS2500 Brake Pads (F) - EBC Yellow Stuff Brake Pads (R) - Ultra Racing Upper Brace (F) - JBR 88a REM - JBR 88a Transmission Mount - Eibach 10mm Spacers
ffz is offline   Reply With Quote
The Following 2 Users Say Thank You to ffz For This Useful Post:
SpeedRebirth (09-26-2014), Vansquish (09-28-2014)
 Old 11-02-2014, 08:52 AM   #21
Bulgsta's Avatar
Posts: 120   (View Stats)
Bulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond repute
no ewg vent to atmosphere?
great build. any updates after tunning a little more?
2007 Mazdaspeed 6
GTX3076 - CPE- EX-mani w/ 44mm EWG - CPE Safe Seals - COBB APv3 - COBB Shifter Weight - DO Stage 2 Meth - PnP Intake Mani - Catless TBE - Corksport FMIC - Corksport Rear Diff Mount - Corksport OCC - AWR RRM, TMM, PMM - TT Front Engine Mount - TT Front Diff Mount - HTP 3.5 " - GFB 50/50 - AT internals - GrimSpeed ECBS - 3 Bar Map - Perm PCV plate - JBR BSD w/ baffle - JBR TIGS - Sure Shortcut - Tower Strut Bar - EGR Delete - EGR Valve Deleted - Shifter Bushings - H&R Springs - Koni Yellow Shocks - Stoptech D&S rotors - EBC Pads - Stainless Steel Brake Lines - Denso ITV 22 - Whiteline RSB - Guardian Angel
Bulgsta is offline   Reply With Quote
 Old 11-09-2014, 06:34 AM   #22
Jackis's Avatar
Posts: 428   (View Stats)
Jackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the world
God kvall!
How is it going there with the build?
Just a quick tip - I am sure you didn't forget to put tial valve seat in when installing, didn't you? Because your boost buildup seems to be quite late, but that could be just my false opinion.
Ha det!
cocoanton likes this.
Does your MS3 start when it's -30C (-22F)?
Forged, bolted, tuned, gtx30/tial/ewg. Thanks.
Jackis is offline   Reply With Quote
The Following User Says Thank You to Jackis For This Useful Post:
cocoanton (11-09-2014)
 Old 05-12-2015, 04:19 AM   #23
Jackis's Avatar
Updates?
 Old 05-15-2015, 08:39 PM   #24
Groans: 33
Long time no see...
Ran into some issues with the coolant return hose, it touched the mani so it started leaking at 2 places (CPE should include a 60 degree AN fitting instead of a stright one) which forced me to uninstall the whole kit to replace the hose/fitting and clock the coldside to a better angle. This took alot of time since the car was 155 miles away from where i live.
Where the fitting/hose touched the mani melting the inside of the hose, spewing coolant all over the chra
New fitting, much better!
New fitting and hose, chra cleaned up and coldside clocked
Next project was to install the newly acquired FMIC kit from HDI in australia. It's a complete kit with relocation brackets for washer bottle and such.
Mockup
Passenger side
Core installed behind crashbar
Washer bottle and PS cooler relocated. Wires and hose extended
Hotpipe installed! This kit comes with special clamps that holds the two pieces together. There are also two o-rings to make it seal properly
Coldside with BPV. Very hard to install at first but after a few adjustments it came in rather easy. BPV connection on ic pipe was too long so had to cut it down a bit
All done!!
Another kit I installed during the taredown of the turbokit was the HTP Battery Relocation kit. I chose the biggest cable and also Circuit Breaker
Battery terminal; GA was relocated to the left side after this pic was taken
So after all this work I started logging today for the first time in 6 months! Pulled really nice all the way to 5-6k rpm where I encountered load cut because boost reached 22.5 psi, 400 g/s flow and 2.7 load.
BATs with tmic was usually 105F at 6k rpm, now it's down to 64!! That's a pretty good improvement =) Ambient temp was about 46
So tuning should start again pretty soon, just need the load cut gone to actually be able to do a full WOT log.
These are my load cut logs, numbers should be taken with a grain of salt. Need to verify them with a couple of clean wots. Same tune landed me at 330awhp last year before I installed the fmic (VD is in post #13 )
Jackis and Code Monkey like this.
Mazdaspeed6 -06
290 AWHP / K04
Code Monkey (05-15-2015), Jackis (05-16-2015), jdmage_mx5 (05-15-2015), Poohster (05-16-2015)
 Old 06-22-2015, 11:11 PM   #25
Groans: 33
So I got a new tune flashed this weekend with increased timing from 4500 rpm and up. Also afr and load targets were adjusted. One thing that may affect VD numbers is that my tires are almost bald (1-2mm thread left). New tires will arrive this week. Will log again after that and see how the numbers are affected.
Anyhow, my reaction when loading VD was hoooly shiet!
23 psi, 16* timing at 6k rpm. Remember, these are awd numbers...
Mazdaspeed6 -06
290 AWHP / K04
The Following 5 Users Say Thank You to SpeedRebirth For This Useful Post:
cocoanton (06-23-2015), Code Monkey (06-23-2015), dan7225 (06-23-2015), Easter Bunny (06-29-2015), lnumbp (07-21-2015)
 Old 06-29-2015, 08:25 AM   #26
Jackis's Avatar
What gasoline are you using? You said you had 20 degrees with K04 and now you are having 16 degrees with GTX30R, I do not see any meth in your pictures, so looks like your fuel does really hold fine!
 Old 06-29-2015, 09:11 AM   #27
Groans: 33
EU95 + 25% E85
Took a look at by K04 tune and it was 19* at 6500 rpm and 2.0 load.
Timing on current tune is about 2* lower than K04 numbers:
Code:
RPM	5000	5500	6000	6500
K04	15,6	15,6	17,5	18,9
GTX3076	11,1	13,1	15	17,1
I don't have any meth kit yet but i plan on getting one after I build the block, which will happen sometime this fall. I have no idea how close to maxed out my injectors are, but i'm not getting any fuel cuts.
I have a few options for the build:
* SP63 long block with ported head
* Freektune build with used long block or a completely new one + ported (long waittime)
* David Hastie build from the UK, he has built about 9 disi engines, none of them are over 450whp though, but i believe it would hold fine since the same components would be used no matter who builds it.
Question, how much power gain are people seeing with SP63 Stage 2 cams? SP63 says it's not needed unless you go for 600-800whp. My plan is to max out my turbokit which would be somewhere around 450-520awhp (it's an extremely efficient setup). And if S2 cams would net a 20whp gain then i would absolutely go for that
Mazdaspeed6 -06
290 AWHP / K04
Jackis (06-30-2015)
 Old 07-21-2015, 05:45 PM   #28
Groans: 33
Finally got the SPC Ball Joints installed!
So now I atleast have some camber! Hated that mazda made it none-adjustable and with positive angle.
My guess is I now have about -1.5, need to get it aligned soon!
Also flashed a new map with some small adjustments to AFR at around 4k rpm, was a bit lean there. Think spool will be improved at 3k rpm too.
Will probably not see any performance gain from now on. I'm pretty much maxed out on the stock fueling and rods. Torque is about 360awtq which is 405whp for you FWD guys.
Next up is taking logs and send to @Lex; and hoping the SPC stuff holds up! =)
Mazdaspeed6 -06
290 AWHP / K04
cocoanton (07-22-2015), Code Monkey (07-21-2015), Poohster (07-21-2015), Snyeed (07-25-2015)
 Old 07-29-2015, 05:37 PM   #29
Groans: 33
Just picked up a 4" @Justin@Freektune; intake! That thing is a monster
Need to get a maf cal sent to me to be able to use it. It also deletes the BPV recirc so from now on im going VTA with my turbosmart bpv
Nom nom nom!!! ID is 3,8"
Mazdaspeed6 -06
290 AWHP / K04
cocoanton (07-30-2015), Code Monkey (07-29-2015), nekret (07-29-2015), TRBLSM (07-30-2015)
 Old 08-03-2015, 04:04 PM   #30
irissanen's Avatar
Posts: 89   (View Stats)
irissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond repute
EU95 + 25% E85
Code:
Hello there neighbor!
I find that post of yours very interesting. Have you actually logged your ignition advance during a pull? 19 degrees at 6500 rpm sounds really high. Are you sure you are hitting 2.0 load there? Would you mind sharing the whole timing table for your K04 setup just to compare to mine?
Thanks!
irissanen is offline   Reply With Quote
The Following User Says Thank You to irissanen For This Useful Post:
SpeedRebirth (08-04-2015)
 Old 08-04-2015, 01:06 AM   #31
Groans: 33
Timing is always logged when taking wot logs And yeah, I've seen 19+ at redline. I can upload a log after work.
Load is very much dependent on your maf cal and other variables, but I think I saw about 2.4 at 3 - 3.5k rpm and then slowly decreasing to ~ 2 at redline.
Will hopefully be able to take more logs today so I can install the 4" intake on next revision
Mazdaspeed6 -06
290 AWHP / K04
 Old 08-04-2015, 08:00 AM   #32
Jackis's Avatar
Yeah, do not forget the magic formula: Load = MAF_Readings * 38.9 / RPM
So basically 2.0 at 7K is equal to 360g/s of metered air, which is the airflow of maxxed out GTX2867 or for GT3071.
2.0 at 6500 equals to 334g/s at that point, which is still too high for K04, it usually could get to 320g/s only when it/s -15/-20 celsius outside.
I suppose you had 2.0 load at 6000 only, which equals to 308g/s. Then the load curve is falling hiperbolically, as the airflow is amxxed out and couldn't be improved either with K04.
 Old 08-04-2015, 01:22 PM   #33
Groans: 33
Attached a K04 log where I had 19.5 timing at 6200 rpm (14-01-03 #11 WOT4)
Here's the K04 timing from 4000-6500 rpm
Did a 4th gear pull today with the new map with adjusted fueling at 4k rpm to stabilize AFR a bit (WOT - 2015-08-04 140650)
This is with the NEW tires which should render a more accurate power curve in VD.
Encountered quite a bit of KR this time, that's why my AFRs go rich after 5100 rpm
Mazdaspeed6 -06
290 AWHP / K04
NCspecV81 (08-05-2015)
 Old 08-05-2015, 07:05 PM   #34
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Is that boost right? Nevermind looked at the log. Reading in Absolute. Carry on.
2013 CWP and Stock
 Old 09-22-2015, 07:47 PM   #35
Groans: 33
Testfitting the new Freektune 4" intake and it's awesome! SP63 engine will arrive in a few weeks so it's time to get serious
Mazdaspeed6 -06
290 AWHP / K04
Code Monkey (09-22-2015), ItsNox (09-29-2015), mxlplx71 (09-22-2015)
 Old 09-22-2015, 09:39 PM   #36
Is this intake supported in any way near the MAF or filter, or does it just wobble around?
 Old 09-23-2015, 07:12 AM   #37
Groans: 33
There are no brackets or anything like that. only thing it rests on a little is the heater hose near the turbo, mine is extended. We'll see next year if it is solid enough. Not a problem for me though, I would just make a bracket with some rubber bushings if needed.
Mazdaspeed6 -06
290 AWHP / K04
Code Monkey (09-23-2015)
 Old 09-29-2015, 06:50 AM   #38
Jackis's Avatar
Do not forget putting some cover or shield between a/c fan and your air filter.
We discovered very rough idle when A/C fan started spinning. It really pushed air and screwed MAF readings a lot, and on 4inch even 900idle rpm goes somewhere around 0.96 volts, so after we did a small test with a sheet of paper, putting it between a/c fan and air filter, and idle became steady as fuck - so we realized how sensitive our MAF sensor is!96553.jpg
The Following 5 Users Say Thank You to Jackis For This Useful Post:
cocoanton (09-29-2015), Code Monkey (09-29-2015), ItsNox (09-29-2015), SpeedRebirth (09-29-2015), Voltwings (10-13-2015)
 Old 10-13-2015, 12:39 PM   #39
Groans: 33
Thanks for the heads up! I'll probably make a custom shield at work when the ime comes. Gotta install a new engine first
So! I picked up this beauty a few days ago! SP63 built longblock
Mazdaspeed6 -06
290 AWHP / K04
cocoanton (10-14-2015), Code Monkey (10-13-2015), Hammology (10-16-2015), Jackis (10-20-2015), Poohster (10-13-2015), TRBLSM (10-14-2015)
 Old 11-01-2015, 05:44 PM   #40
Groans: 33
Started the taredown a while ago and this is how far i've come so far.
Need to research what to do next so that I can remove the front end
Jackis likes this.
Mazdaspeed6 -06
290 AWHP / K04
BLKSTIG (11-02-2015)
GTX3076 with Built Engine in Australia shaneski 2010 MS3 - Big Turbo Builds 12 11-02-2015 07:27 PM
Page generated in 0.66636 seconds with 34 queries
