Like Tree8Likes
  • 1 Post By Raider
  • 2 Post By atvfreek
  • 1 Post By TiGraySpeed6
  • 1 Post By rfinkle2
  • 1 Post By EmPeEs6
  • 2 Post By Speeden6
 Old 06-21-2012, 05:16 AM   #1
EmPeEs6's Avatar
Posts: 642   (View Stats)
EmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the world
Default Terrible response with BNR S3!
Hi together,
I just installed a BNR Stage 3 on my Mazdaspeed6.
It has a very good high end performance but takes an extremely long time to spool up -
it seems that this thing wakes up around 3k and real high boost pressure is reached far beyond 3500 rpm.
I'm hitting my boost targets of ~20.3 psi from 4 - 6k with WGDC values of max. 63, so in principal the turbocharger is working as expected, but what could be the reason for the very late spooling? My WOT-load values are very low as well (<1.9 at 3.5k/intake air temps of ~100°F).
Just for your information: I still have the stock intake system (except for the tip) and no fmic!
Best regards from Germany!
EmPeEs6 is offline   Reply With Quote
 Old 06-21-2012, 05:21 AM   #2
You will be asked for datalogs to get help, as well as a full mods list.
TiGraySpeed6 likes this.
The Following 8 Users Say Thank You to Raider For This Useful Post:
ASHMS3 (06-21-2012), atvfreek (06-21-2012), Downmented (06-21-2012), Jonny Quest (06-22-2012), lilred (06-21-2012), shawn19 (07-17-2012), SofaKingAwesome (06-21-2012), themytb (06-21-2012)
 Old 06-21-2012, 05:43 AM   #3
atvfreek's Avatar
Posts: 7,787   (View Stats)
Going wot at 2500 you should have 20+psi at 3200-3400 rpms. You may need to make load table adjustments, wgdc adjustments, or wastagete/load dynamics adjustments. As raider said, post some logs and we can check it out.
TiGraySpeed6 and rfinkle2 like this.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 5 Users Say Thank You to atvfreek For This Useful Post:
BobbleHead (06-22-2012), Bucker (07-19-2012), ckMS3 (06-21-2012), helmetface (06-21-2012), Lex (07-16-2012)
 Old 06-21-2012, 07:15 AM   #4
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Good question
with technical answers that appear beyond your skill level
I know we just met, and this is crazy
but donate maybe
Jonny Quest likes this.
340hp / 371tq
The Following 19 Users Say Thank You to TiGraySpeed6 For This Useful Post:
atvfreek (06-21-2012), BobbleHead (06-22-2012), Boost_creep (06-21-2012), Bucker (07-19-2012), ccspeed3 (06-21-2012), ckMS3 (06-21-2012), dereeek (06-21-2012), lilred (06-21-2012), manelscout4life (06-21-2012), MS3-a(sore)ASS-rex (06-21-2012), Noodlesincup (06-21-2012), PapaSmurf (07-16-2012), Raider (06-21-2012), rfinkle2 (06-21-2012), Roddiy (07-01-2012), SarcasticOne (06-22-2012), tddvrrn (07-16-2012), themytb (06-21-2012), uncorked11 (06-21-2012)
 Old 06-21-2012, 07:18 AM   #5
In addition to the above, are you running a 3 port boost control solenoid?
atvfreek (06-21-2012), themytb (06-21-2012)
 Old 06-21-2012, 07:21 AM   #6
ckMS3's Avatar
Posts: 1,112   (View Stats)
You still haz stock intake? Upgrade that shit! Also post some logs
348tq/367whp -21.5 psi
The Following 2 Users Say Thank You to ckMS3 For This Useful Post:
rfinkle2 (06-21-2012), speed23 (06-21-2012)
 Old 06-21-2012, 07:44 AM   #7
+4 we need
atvfreek (06-21-2012), BobbleHead (06-22-2012), ckMS3 (06-21-2012)
 Old 06-21-2012, 08:06 AM   #8
EmPeEs6's Avatar
Yes, I forgot to mention that I'm running a Grimmspeed in 3 port mode.
The wgdc start values are high enough - my boost dynamics maps are stock, and since I'm boost tuning, I (almost) don't care about the load maps ;-)
Other mods: SU tmic, water inj., racepipe, cb, tip, k&n air filter, hpfp-upgrade, forge bov, itv22 plugs.
Concerning intake mods: I'm going to install a Corksport sri + cold air box although this won't be much beneficial in conjunction with the current hot summer temps.
I will post some data logs this evening.
alphasaur likes this.
 Old 06-21-2012, 08:11 AM   #9
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
too much restriction on the intake and you need a tune, bad.
my 3071 hated having such a small intake (cobb intake + PG TIP) I can't imagine how the heck you're running on stock intake. Just too slow to spool.
p057 is offline   Reply With Quote
 Old 06-21-2012, 08:14 AM   #10
again, suggest:
-post map
-post maf cal and WOT logs
-compile list of related mods into single post so folks do not need to search your stuff
-donate, as detailed answer is obviously worth more than your time to search, learn & extrapolate from existing information.
Heck, you've already been told where to begin looking.
and no, I won't pester over & over. I just think it's a cheap price for what folks charge quite a bit to do professionally that is being asked for for free.
340hp / 371tq
 Old 06-21-2012, 09:19 AM   #11
A larger intake and exhaust will certainly help. The BNR is a fast spooling turbo, your WGDC should be 100% up to 3000 RPM.
Without more information it's hard to tell if this is a hardware issue or a tuning issue.
atvfreek (06-21-2012), BigjohnB20 (06-21-2012), rfinkle2 (06-21-2012), TiGraySpeed6 (06-21-2012)
 Old 06-21-2012, 09:31 AM   #12
BigjohnB20's Avatar
Posts: 779   (View Stats)
BigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the world
Seems fairly straight forward to me...
Stock intake, stock primarly cat, no real tune. What did you expect. Open up the breathing a little for that turbo and get a real tune and you will be quite pleased I imagine.
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
BigjohnB20 is offline   Reply With Quote
 Old 06-21-2012, 11:28 AM   #13
Speeden6's Avatar
Posts: 598   (View Stats)
Speeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the world
OP, your BNR S3 just doesnt seem to work for you, ill gladly take it off your hands at a discount cause its used of course, but ill give it a proper home!
410ms3 and alphasaur like this.
2007 MS6 -
CPE TMIC, CS HPFP Internals, CS Stage 2 Intake and Inlet, Turbo Smart 50/50 BPV / BOV, Catless DP
2006 Acura TL Fully bolted and Running Nitrous! 330WHP SOLD
SOLD 1992 Corrado VR6
268 Cams, air intake, cat back, upgrade plugs and wires, coilovers.
SOLD
2001 Audi Allroad
SOLD
2006 MS6 -
CAI, TIP, ETS TMIC, AutoTech Internals, TBE catless, E85 30%,
19PSI, Cobb AP, RMM, K04, HKS SSQ4 VTA,
TUNED BY LEX FOR 330 AWHP / 380 TQ
Custom tune by
The habits we form today are the ones that Define us tomorrow
Speeden6 is offline   Reply With Quote
The Following User Says Thank You to Speeden6 For This Useful Post:
lilred (06-21-2012)
 Old 06-21-2012, 11:38 AM   #14
Oliverms3's Avatar
Posts: 1,632   (View Stats)
Oliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the world
NO DP.... bottle necking that bitch
2010 BM MS3 - Cobb AP||3gal corn||Autotech Internals||ETS TMIC||Forge BPV||Denso Iridium ITV22||TurboXS DP||ARK exhaust||CP-E Nano SRI||PG TIP||JBR RMM||JBR PMM||TRZ TMM||NRG ETD||DDM 55w 5000k HIDs and DDM 35w 3000k HID fogs||JB Heavy Knob||JB SSP||ST Coilovers w/ Eibach rear Camber Kit(made by SPC)||17x9 +28 Drag DR31 (track) RPF1 18x8 +35 (DD)||HKS TT Type 0||Clarion EQ||MB Quarts speakers||Pioneer amps and 10" Competition Sub.
346hp 392lbs of sexyness
Oliverms3 is offline   Reply With Quote
 Old 06-22-2012, 01:59 AM   #15
EmPeEs6's Avatar
Thank's Lex - this was exactly the problem!
Since I used to run a wgdc start value of 35 at 3k rpm resulting in 20.3 psi with my upgraded k04,
I thought that the BNR would spool up early enough to produce at least 17.4 psi at this revs and wgdc.
I increased the value to 55 (and also the one for 2500 slightly) and now the car runs much better!
Concerning the "very helpful" comments like "you need a proper tune...": I'm just beginning to tune the BNR and there are almost no experiences
with this turbocharger in Germany, so this process will take some time!
 Old 06-22-2012, 02:34 AM   #16
Resident Baus
duappleganger's Avatar
Posts: 504   (View Stats)
duappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the world
Groans: 34
Groaned at 56 Times in 18 Posts
WAS SPIELST DU AN DAS FAHRZEUG TUNE? WIR BRAUCHEN DATEN UM IHNEN!
2011 Black Mica MS3
FREEKTUNE (On hold 'til EWG) ATP GTX3071R IWG (soon to be EWG) Full Race exhaust manifold CP-e whale peen + 3.25 in. intake
COBB EBCS + Downpipe + BPV + AP Stage 2 Corksport CBE + Brake Pads Ultimate FMIC NGK Iridium IX @ .28 DDM HID 6000k
Autotech CDFP Internals JBarone EGR delete, TB + IM gaskets, SSP + Shift Anchors, 88D RMM, 70D passenger + tranny mount, RSB, and OCC
HTP battery box TSW Nurburgrings 18x8.5 MBR w/ Michelin Pilot Super Sports 235x40x18 +45 Goodridge SS Brake Lines
Installation TBD: H&R springs + Koni yellow shocks + struts
duappleganger is offline   Reply With Quote
 Old 07-01-2012, 09:22 AM   #17
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
Genaurechts
 Old 07-16-2012, 05:52 PM   #18
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Mine spools up just fine.
OP you don't want full boost until about 3500 rpm's, it will help save your engine.
Pickles Tune in progress
Terrible Gas Mileage - Please Help DRS211 CX-7 > Issues & Troubleshooting 43 09-16-2013 08:30 PM
Terrible, Horrible, No Good, Very Bad gas mileage CaptainCrunch MazdaSpeed 3/6 - Troubleshoot/Diagnostics 22 09-28-2012 07:09 PM
terrible decision with lights leads to $$ tooslow10 Exterior 42 11-15-2011 05:49 PM
Terrible Radio reception dcphantom MazdaSpeed 3/6 - Car Audio & Electronics 4 06-04-2009 07:31 PM
Page generated in 0.38196 seconds with 33 queries
