Like Tree36Likes
 Old 04-05-2012, 11:26 PM   #41
Originally Posted by thehead View Post
Well, I got my turbo, exhaust mani and bt inlet today so I'll be installing it all at once rather than just the exhaust mani. pics!
I'm a little frustrated at this whole process with edgeautosport, they've been more than helpful but the names on my packages were spelled wrong, normally this wouldn't be an issue but I'm on a military base and it makes it a ridiculous pain to try and get my packages. My turbo inlet was here for a month because cp-e had the wrong name. I'm still trying to locate my bigmaf.
Sorry about that, let me know how we can get it fixed.
thehead likes this.
Death-From-A-Mile (04-05-2012), thehead (04-06-2012)
 Old 04-07-2012, 03:28 PM   #42
thehead's Avatar
Posts: 1,141   (View Stats)
thehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the world
Groans: 143
edited first post with install pics so far.
2016 BMW M235i
[Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles
Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals
Electrical - GS EBC - Cobb AP Richtune in progress
Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's
Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40.
thehead is offline   Reply With Quote
 Old 04-08-2012, 10:34 AM   #43
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
this is the intercooler i went with 28x8x3.5 eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
same price.
nice build so far
The Following User Says Thank You to crazyp For This Useful Post:
thehead (04-08-2012)
 Old 04-08-2012, 11:35 AM   #44
thehead's Avatar
Groans: 143
same price.
nice build so far
yeah, that looks similiar to the tr8 treadstone core, which is what I ended up switching to because I wasn't getting good cooling with the ebay one. have you installed it yet?
2016 BMW M235i
 Old 04-08-2012, 02:51 PM   #45
crazyp's Avatar
Groans: 68
its been on my build since day 1
thehead (04-11-2012)
 Old 04-09-2012, 01:09 PM   #46
Karmat's Avatar
Posts: 1,179   (View Stats)
Anyone have pictures of how much cutting is necessary to fit the TR8 properly?
2002 Corvette Z06 (Black)
 Old 04-09-2012, 01:36 PM   #47
thehead's Avatar
Groans: 143
for me, I had to cut the width of the intercooler and half way up, The crash bar is shaped like a "C" not like a bar, so I cut the bottom part off. I may be taking my front bumper off again on Wednesday, if I do I'll take a picture.
2016 BMW M235i
 Old 04-10-2012, 06:37 PM   #48
thehead's Avatar
Groans: 143
Updated OP with pictures of exhaust manifold in and more notes. need a stubby wrench to finish tightening mani to turbo nut and finish up intake stuff.
Question.. For the ebc vacuum line from the turbo housing, since the gtx3071r doesn't have one like the k04 does, should I just drill a hold into the bt inlet and put in the nipple provided? Also, how do I tune the ebc and set it up :S
2016 BMW M235i
 Old 04-10-2012, 06:45 PM   #49
crazyp's Avatar
Groans: 68
Id rather drill the hot pipe for a boost source or t off the mani. I run MBC so can't help you on the ebc
thehead (04-10-2012)
 Old 04-11-2012, 06:40 AM   #50
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Boost source - you can use a quick tap-
FTG-QuickTap-CompHSG : atpturbo.com
Pic compliments of @dougefresh_
gilometrico07 likes this.
340hp / 371tq
dougefresh_ (04-11-2012), thehead (04-11-2012)
 Old 04-11-2012, 05:59 PM   #51
thehead's Avatar
Groans: 143
Finished with the install of everything just need some tuning. Is there a base bt map at all? I have a modified map currently with -30% wgdc and lower boost levels for now, but yeah. I need to get on the perm list.
Also uploaded more pictures to op.
Pretty crazy though, this turbo sounds so much different than the stock turbo, its higher pitched like a jet engine, I like it
2016 BMW M235i
The Following User Says Thank You to thehead For This Useful Post:
Karmat (04-11-2012)
 Old 04-11-2012, 07:57 PM   #52
Karmat's Avatar
The bumper splitter fits underneath all that?
 Old 04-11-2012, 10:19 PM   #53
thehead's Avatar
Groans: 143
It just fits, however, the functionality of it is questionable, your best bet would be to cut the crash bar all the way, or check with @Alpha for his crash bar solution he mentioned in an earlier post in this thread. I know once I put the front mount on, my intake temperatures went up quite a bit which could be because the lower spoiler isn't able to bring enough air into the engine bay as it use to.
2016 BMW M235i
 Old 04-12-2012, 08:48 AM   #54
Alpha's Avatar
Posts: 3,711   (View Stats)
Thumbs up
My Full-Race FMIC is the beez kneez. The bar I have on the car now is thick and strong, but they decided to make it almost three times as thick/strong for the production kits. I'm fortunate enough to be getting one of those as a replacement very soon.
We modified the stock splitter a bit to maintain it with the kit, for cooling purposes, and it turned out great.
Hope that helps. The MS3s have always had a ton of FMIC options, but the 6ers always got the shaft... Not anymore!
thehead likes this.
The Following 3 Users Say Thank You to Alpha For This Useful Post:
dot584 (04-12-2012), Fail_6 (06-02-2012), thehead (04-12-2012)
 Old 05-07-2012, 06:14 AM   #55
thehead's Avatar
Groans: 143
Alrighty, so my transmission got rebuilt last week, I was hoping to put the mazda 6 diesel gears in there for that taller gear ratio but this is my only car so I didn't want to experiment on it since its not proven to work long term yet. While that was getting rebuilt I had the clutch and flywheel pulled to check the wear on them and it was bad.
This is why you don't let friends drive your car.
I replaced the ACT street clutch and fidenza flywheel with a resurfaced stock flywheel from Tech/Sales@EM and got a spec stage 3+ clutch from @StreetUnitMark . I also got a prosport boost gauge to replace the really old one I was using. i also got a 3bar map sensor and the Sure 3" MAF housing from @StreetUnitMark
2016 BMW M235i
TiGraySpeed6 (05-07-2012)
 Old 05-07-2012, 06:35 AM   #56
Looking forward to hearing your opinions on the flywheel now that you
re going back to OEM from the Fidenza on your DD...
Happy to have the weight back?
340hp / 371tq
 Old 05-07-2012, 07:31 AM   #57
ScarMS3's Avatar
Posts: 2,088   (View Stats)
Groans: 97
is it moving under its own power again.....need track times now.
 Old 05-07-2012, 07:34 AM   #58
thehead's Avatar
Groans: 143
i'll be picking it up today. I still have to tune it, I'm going to Minnesota for a week on wednesday so I'll be doin maf cals when I get back.
2016 BMW M235i
 Old 05-07-2012, 06:19 PM   #59
thehead's Avatar
Groans: 143
So upon driving my car home, its pretty crazy, my clutch pedal feels like a normal car's clutch pedal now rather than taking like 75lbs of force to push down. however, third gear takes a lot of effort to take out of gear, not really sure what the deal with that is, I'm goina take it back tomorrow and see what they say, they gave me a 6 month no questions asked warranty.
2016 BMW M235i
 Old 05-07-2012, 06:26 PM   #60
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
If it's only one gear, sounds like they might have messed up the rebuild. Could be synchros.
2007 CTS-V - Trying to sell
 Old 05-08-2012, 10:34 AM   #61
thehead's Avatar
Groans: 143
So we found out what it was, the shift weight was hitting my intercooler piping clamp, easy fix, yay!
TiGraySpeed6 likes this.
2016 BMW M235i
The Following 2 Users Say Thank You to thehead For This Useful Post:
Seatime3 (05-08-2012), TiGraySpeed6 (05-08-2012)
 Old 05-09-2012, 10:58 AM   #62
thehead's Avatar
Groans: 143
So I've been trying some tuning, this wgdc stuff is a bitch, I'm still trying to figure it out but I'm not making boost very quickly and I have no leaks.
let me know if I'm royally fucking this up, I think my wgdc is fairly conservative, I've been working my way up and going off of other wgdc's people are using. boost targets are 24psi from 3k-6k rpm 1750ish commanded fp.
2016 BMW M235i
 Old 05-09-2012, 05:30 PM   #63
bmylez's Avatar
Groans: 31
Sounds like you need to do the dreaded WGA arm preload.
 Old 05-09-2012, 05:34 PM   #64
thehead's Avatar
Groans: 143
Yeah, thats what im afraid of, i increased wgdc to 70 til 3k and it didnt help at all, damit all to hell
2016 BMW M235i
 Old 05-09-2012, 05:54 PM   #65
bmylez's Avatar
Groans: 31
Unless the ebcs isn't plugged in or is malfunctioning entirely, it's the WGA preload.
thehead (05-09-2012)
 Old 05-09-2012, 07:42 PM   #66
Realgib3's Avatar
Posts: 2,443   (View Stats)
Ugh... looks like the preload to me too. Good luck man.
 Old 05-17-2012, 07:40 AM   #67
thehead's Avatar
Groans: 143
Gah, I'm really tempted just to go ewg now, tack weld the iwg shut, and throw in a screamer pipe... Only thing is, I'd have to know the iwg is shut before I can weld it, it should be since it was shut pretty good when I installed it with no vacuum/boost applied to it. Thoughts?
2016 BMW M235i
 Old 05-18-2012, 06:51 AM   #68
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
I used a grimmspeed iwg block off bracket for a 18g... It cost about 20 bucks and I was able to do all the work with the turbo still on the car.... Just a thought
2008 MS3 gt
470hp/463tq on GT35r at 29psi
thehead (05-18-2012)
 Old 06-02-2012, 02:13 PM   #69
thehead's Avatar
Groans: 143
So I'm finally getting some boost built, I'm coarse tuning the wgdc today and I'll probably fine tune it tonight, looks like the logs cut out at 22.8 psi so I'll keep her at 22 lbs til I get my new map sensor in. I'll post some logs later.
Had a scary moment today that made me realize I need to adjust wgdc in smaller increments... don't groan me too hard for that..
2016 BMW M235i
 Old 06-02-2012, 03:19 PM   #70
thehead's Avatar
Groans: 143
slowly getting the wgdc dialed in, oooh yeah... this would be so much faster if I had a laptop, lol.
I do have a question if I lower the initial wgdc, would it spool up faster. I wasn't sure because it would be less load on the engine, not really sure if its better just to send all the exhaust to the turbo or not.
2016 BMW M235i
 Old 06-02-2012, 08:31 PM   #71
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Just FYI,
You probably have an easy 500 RPMs of earlier spool left in the tune...
This is what I am getting with a ported IM with no VTCS (which slows spool an easy 2-300 RPMS):
The Following 7 Users Say Thank You to cld12pk2go For This Useful Post:
802MS3 (06-06-2012), atvfreek (06-02-2012), cshunter (07-31-2013), helmetface (06-02-2012), rghispanic88 (06-09-2012), SarcasticOne (06-03-2012), thehead (06-03-2012)
 Old 06-02-2012, 08:45 PM   #72
atvfreek's Avatar
Posts: 7,787   (View Stats)
All of the GTX's I've tuned hit 20+ by 3400, so you are getting there. What does your vvt table look like?
EDIT: also looks like a little bit of an oscillating boost curve. Are you using the load dynamics or load error comp tables. If so what are those values.
Sorry if these have all been answered. A little late to the thread
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 06-03-2012, 12:45 PM   #73
thehead's Avatar
Groans: 143
my vvt table is whatever the stage 2 tune uses, not sure what to do with that, I haven't done anything with the error values, I don't understand what they do :p
2016 BMW M235i
 Old 06-03-2012, 04:59 PM   #74
thehead's Avatar
Groans: 143
Well son of a bitch, launched and something made a breaking sound. My rear end is making a clicking noise. Anyone know what that would be? Broken driveshaft maybe?
2016 BMW M235i
 Old 06-03-2012, 05:03 PM   #75
crazyp's Avatar
Groans: 68
could be an axle. I'm always paranoid about that so the first thing I do after starting the car is turn off DSC and turn on the meth.
 Old 06-03-2012, 05:08 PM   #76
thehead's Avatar
Groans: 143
Hmm, just checked the driveshafts from the outside the look good. Thinking its the diff . How much are one of those?
2016 BMW M235i
 Old 06-03-2012, 06:13 PM   #77
lulz @Raider
burn813's Avatar
Pull up one click on the ebrake and test results lol
2008 MS3 gt
 Old 06-03-2012, 06:53 PM   #78
thehead's Avatar
Groans: 143
Does that make it fwd?
2016 BMW M235i
 Old 06-04-2012, 06:48 PM   #79
thehead's Avatar
Groans: 143
Meh, its something internal I'm pretty sure, just started my second part of a-school so my time is goina be limited, but man, I did a ton of tuning this past weekend, and the car pulls soo hard, I love it. well, not so much anymore, I'll be putting my car up on a lift tomorrow and see if I can spot any obvious damage, and I'll check the fluid for metal. does anyone know what the rear diff gear ratio is, i seem to remember someone saying its the same as whats in the rx-8's. But I was looking and there are a ton of different ones they use. @06Speed6
2016 BMW M235i
 Old 06-04-2012, 07:01 PM   #80
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
The rear diff *should* be 1:1 but I dont know that for sure and the coupler should slip some so its near impossible to determine that way. I have a back half if a rear axle in the storage unit, there is no way I can guarantee that it isnt junk, I bought it on ebay for $250+shipping a couple years ago and havent done anything with it. Supposidly the gearset is rx-8 spec, but I dont know if that just means the the gearset will swap into a rx-8 axle or that the diff is a direct swap or what. I havent even opened that thing up to look.
Fyi the coupler is the likely weak point and the outer case of the actual coupler can break open.
2006 Mazdaspeed 6
Last edited by 06Speed6; 06-04-2012 at 07:01 PM. Reason: MSF Database - Automerged Doublepost
thehead (06-04-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/thehead-s-gtx3071r-front-mount-intercooler-cp-106908/
speedperf6rmanc3 - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-19-2014 04:40 PM
GenPU GTX3071r build stang9779 2010 MS3 - Big Turbo Builds 519 04-05-2012 09:13 PM
what exhaust mani to get ?? jracer MazdaSpeed 6 - Engine, Transmission & Driveline 18 12-02-2009 12:00 AM
Page generated in 0.59015 seconds with 33 queries
