Like Tree5Likes
 Old 05-23-2013, 04:43 PM   #41
Sum1UDidntC's Avatar
Posts: 157   (View Stats)
Sum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond repute
sorry to thread jack here but would you be able to substitute a new oem block for lets say a CP-E stage 3 block and not have any of these same issues of getting rebuilt vs new? im a CP-E fanboy obviously and if I was to get built then I would probably go with the CP-E block with the 90mm bore and I would try to do all the labor myself (not sure if you need anything else besides the block and stuff that comes with it).
2011 Black Mica MazdaSPEED3 // CS SRI // CS TIP // HKS SSQV-IV VTA w/ CP-E flange // CP-E FMIC // CP-E Triton CBE // CP-E Catted DP // CP-E HPFP // CP-E Stage 2 RMM // COBB AP With Lex Tunes // JBR SSP // JBR 88DM TMM //JBR 80DM PMM // JBR custom cylindrical shift knob // JBR SSB's // Rally Armor Mudflaps // ISC Coilovers and front end links // Denso ITV-22's // SPC Camber Arms // Michelin Pilot SuperSports // STRATIFIED LEX TUNED FTMFW
Mustang Dyno Results:
301WHP 334WTQ on 35% E85
282WHP 325WTQ on 92oct
Sum1UDidntC is offline   Reply With Quote
 Old 05-23-2013, 06:15 PM   #42
Matrix311's Avatar
Posts: 2,133   (View Stats)
Excellent question, i have been wondering the same thing going the CPE route. Can you buy the block with their rods and pistons already installed and everything balanced so its pretty much bolt in with our car?
 Old 05-23-2013, 06:24 PM   #43
Andjo's Avatar
Posts: 937   (View Stats)
Andjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the world
For coolant I run 60%water and I live in Houston. In the summer I see oil temps around 190-200 and coolant temps around 180-190. You don't want to run more than 70% water due to corrosion and deposits.
GT3076 and supporting mods with Kozmic Motorsports Built motor and tune
FUTURE MODS: 6266 with V-Band everything
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
2013 TROLL CHAMPION "DYLANFYHN"
Andjo is offline   Reply With Quote
 Old 05-24-2013, 01:11 PM   #44
Voltwings's Avatar
Posts: 3,713   (View Stats)
Are you measuring oil temp off a filter sandwhich plate?
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 05-24-2013, 04:21 PM   #45
Andjo's Avatar
Yes. Its the same as the engine temp on the ap with my car.
 Old 05-28-2013, 05:22 PM   #46
Matrix311's Avatar
bump anyone know about this?
Sent from my Transformer TF101 using Tapatalk 2
 Old 05-28-2013, 06:10 PM   #47
theurgy's Avatar
Posts: 2,580   (View Stats)
Have you asked CP-e possibly?
The Following User Says Thank You to theurgy For This Useful Post:
chuckms6 (05-28-2013)
 Old 05-28-2013, 06:15 PM   #48
maddocx240's Avatar
Posts: 823   (View Stats)
I remember when I was in the 240sx scene and my boy wanted to build his sr20 motor. So we went to a well known engine builder in the area and spoke to him about doing the work. He asked if there anything was anything wrong with motor, and my boy said no. He asked if he was building a car to run at the track? My boy said no. The builder told him leave the car alone then. If it ain't broke, don't fix it. As long as you don't try and exceed the motors Limitations then its fine for a street car. If the car was made for turbo from the factory then it can take some abuse. So save your money! Just like lex said I've known many people with built motors whos cars are never running, always some b.s, lol..
The Following User Says Thank You to maddocx240 For This Useful Post:
 Old 05-29-2013, 07:26 PM   #49
Matrix311's Avatar
Yep I decided to not build. Going to drop in an sbc clutch and ride the engine out. I'm happy with the 400whp I'm at.
Sent from my SCH-I535 using Tapatalk 2
The Following 2 Users Say Thank You to Matrix311 For This Useful Post:
Dahouse702 (05-29-2013), DoMiNic (05-31-2013)
 Old 05-29-2013, 07:50 PM   #50
Fatpig78's Avatar
Posts: 127   (View Stats)
Fatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond repute
thanks for the advice, i was thinking if i should rebuild soon at 90k with stage one parts or not. Ill do a compression check sometime to see if any seals are shot.
07 Cosmic Blue Mica MS3 GT:
Cobb AP, Torq R3 Street; Sure CounterWeight; Corksport CAI/TIP; Cobb Shift Knob on Stratified extension w/ TWM shortshifter; Corksport Internals; Custom straight 3 inch catback exhaust by RPM
Fatpig78 is offline   Reply With Quote
 Old 05-30-2013, 10:17 AM   #51
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Jesus. "Staged" engine internals. What the fuck is the world coming to?
Andjo (05-30-2013), chuckms6 (05-30-2013)
 Old 05-30-2013, 11:22 AM   #52
chuckms6's Avatar
Posts: 1,618   (View Stats)
I'm not sure, but this is probably stage 1 of the end...
Sent from my SAMSUNG-SGH-I727
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
The Following 3 Users Say Thank You to chuckms6 For This Useful Post:
fivefingerdeathpunch (05-30-2013), psychophyr (05-30-2013), silvapain (05-30-2013)
 Old 05-30-2013, 11:41 AM   #53
Andjo's Avatar
Guess its the good, better or best of engine building.
 Old 05-30-2013, 12:02 PM   #54
chuckms6's Avatar
the only difference is the pistons iirc
 Old 05-30-2013, 12:20 PM   #55
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
I guess I have a stage .75 then. lol
Carrillo rods, PU pistons, BSD...everything else OEM except for the "aftermarket" ring gaps.
atvfreek (05-30-2013), silvapain (05-30-2013)
 Old 05-30-2013, 12:29 PM   #56
0.78 Dan, the ring gaps are worth 0.02 stages.
atvfreek and wake2011 like this.
The Following 8 Users Say Thank You to Lex For This Useful Post:
Andjo (05-30-2013), atvfreek (05-30-2013), chuckms6 (05-30-2013), Dano (05-30-2013), kladuscan (05-30-2013), silvapain (05-30-2013), theurgy (05-30-2013), wake2011 (07-21-2013)
Video: How the Chevy Corvette ALMS engines are built Haltech Automotive News 0 03-20-2011 10:30 AM
Four-cylinder engines power 65.4% of cars built in 2010 Haltech Automotive News 0 02-02-2011 08:40 AM
Chrysler will build Fiat 500 engines in Michigan Haltech Automotive News 0 12-17-2009 12:00 PM
Chrysler will build Fiat 500 engines in Michigan Haltech Automotive News 0 12-17-2009 11:20 AM
GM will build Volt engines in Michigan Haltech Automotive News 0 09-25-2008 09:30 AM
Page generated in 0.37122 seconds with 30 queries
