 Old 07-08-2010, 10:49 PM   #1
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Default Top mount turbo setups
Fuck working on turbo in the stock location.
I'm limited in the turbo size i can run... I honestly don't even think a 3076 would fit, cause the 3071 is already kissing the head. My back is killing me, and my knees hurt from standing with them locked while i snake wrap my left hand through all four runners and spend 45 minutes trying to start one stupid bolt. I'm tired of having to put a pry bar in my compressor outlet to pull the turbo around (cause yes, it's that tight of a fit) to thread in one more 45 minute bolt. And I'm not happy with having to pull the mani just to take the turbo out, which is something i'm gonna want to do a lot more in the future as i experiment with different setups.
I'm just tired of this shit.
I want a setup that takes just a couple hours to work on, cause god knows, with a highly modified car, there's always something to work on.
So i wanted to get some thoughts from you guys of what considerations to take.
Like should i place the turbo right above the head like su mark & ssinstaller? Should i wrap my mani off to the driver's side like DCR-ish & vivid and put the turbo where the battery used to be?
What is the best type of line to use to replace the coolant and oil feeds/returns?
I got a call from my machinist today, and my new motor is almost finished. So as soon as i get it, i'm gonna assemble the long block and use it as my test jig for this new setup, and i'm just gonna build everything myself. I think my stainless steel skills are good enough at this point. But i wanted to get the BT community's opinion of things to consider while designing.
List so far:
- Easy as shit to work on. Easy to reach all exh mani bolts, and turbo -> mani flange bolts, plus oil & coolant feed & return.
- T3
- V-band from collector to turbo flange, just like the original DCR concept, so changing flange options is easy.
- Recirc'd dump tube, cause running a long ass dump tube puts alot of strain on the mani IMO. And i wouldn't mind quiet for a while.
- Possible 2-piece down pipe? Both with a flex section? how bad do flex sections hurt flow? This also would let me run a tapered 3.5" v-band in the future if i ever wanted to.
- Lot's of bracing to relieve / distribute stress on welds on the mani.
What gauge tubing should i use? I have a bunch of 2" pipe here already, and it's 1/16" wall (almost 14 gauge). It feels just as thick as any of the mani's i've run thus far, if not thicker.
Let the ideas roll. I want this to be the last turbo setup i have to do on this car
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
The Following 36 Users Say Thank You to djuosnteisn For This Useful Post:
AJ713 (12-26-2010), Alpha (02-18-2011), BUNGEEZZ (07-13-2010), Chriscote (07-22-2010), cld12pk2go (07-15-2010), danesti (07-09-2010), Dano (07-10-2010), DSIT995 (07-09-2010), Fobio (07-09-2010), FreeFlyFreak (07-09-2010), gtarman77787 (07-09-2010), holeinmypocket (07-09-2010), I Love Brownies (12-10-2010), JacksonMS30 (01-17-2011), Jessed87 (07-22-2010), jmhinkle (07-14-2010), jwilkins88 (01-30-2011), karl-hungus (07-23-2010), KeysMS3 (07-15-2010), kgb (07-09-2010), MarkyMark (07-09-2010), MATT DAMOND (07-10-2010), mazda.speed3 (07-12-2010), MPSdriver (07-15-2010), MS3-a(sore)ASS-rex (07-09-2010), myzoomzoom3 (07-12-2010), RayRayBauder (07-13-2010), Realgib3 (07-09-2010), rigor (07-09-2010), SilverDemon (07-09-2010), spd6guy90 (07-09-2010), Speed3eak (12-28-2010), spnkr21 (07-10-2010), spoolin00 (12-01-2010), the_caruch (07-09-2010), xcoldricex (07-09-2010)
 Old 07-08-2010, 11:04 PM   #2
idaners7's Avatar
Posts: 55   (View Stats)
idaners7 has a spectacular aura aboutidaners7 has a spectacular aura about
Groaned at 24 Times in 3 Posts
so what turbo is good to get on my ms3
idaners7 is offline   Reply With Quote
The Following 21 Users Say NO Thank You to idaners7 For This Un-useful Post:
 Old 07-08-2010, 11:06 PM   #3
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
Call creative man, that's who made sumark and ssinstaller's mani and downpipe, shit is sexy, and a decent price if I remember correctly. I know how you feel though man, I bet its a real bitch with that dcr manifold, you have a lot longer, more entangled runners than mine. I think I will have permanent knee damage from bending over this fucking car every week trying to screw with something behind the block.
The Following 2 Users Say Thank You to madvillain For This Useful Post:
djuosnteisn (07-08-2010), xcoldricex (07-09-2010)
 Old 07-08-2010, 11:13 PM   #4
Captain
hahahaha, seriously, mazda is gonna get sued for knee surgeries in like ten years.
Actually the DCR i'm running isn't the same as his first version. It's alot more straight forward:
But it's still stock turbo location, and i hate it.
www.permtuning.com
xcoldricex (07-10-2010)
 Old 07-08-2010, 11:25 PM   #5
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Ide place it above the head.
2006 Mazdaspeed 6
djuosnteisn (07-09-2010)
 Old 07-08-2010, 11:37 PM   #6
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Groans: 70
I'd do it up and above the head vs. at the battery. Mainly, since a DP seems easier to make and route that way. I'd make sure to do a bit of heat wrapping on the hotside and quite a lot of heat shielding on the VC and hood.
As for oil and coolant lines, SS braided teflon hose for the oil lines, and either SS braided rubber, or silicone hose for the coolant lines. Depending on the size of the lines, I'm sure I could help you out there. I haz lots of hoes.
Current Fail:
The Following 4 Users Say Thank You to MATT DAMOND For This Useful Post:
Alpha (02-18-2011), djuosnteisn (07-09-2010), jayspeed3 (07-09-2010), jmhinkle (07-14-2010)
 Old 07-08-2010, 11:53 PM   #7
kore2000's Avatar
Posts: 448   (View Stats)
kore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the world
Groans: 90
Groaned at 69 Times in 21 Posts
I love the top mount manifold on my car. I wouldn't have done it any other way. There was plenty of room and the DP/VTA tube was hella easy to route. The only issue I had was that my motor rocked so much that it dented the firewall, but I could seriously care less about that. I don't know too much about the thickness or the metal they used (SS I believe), just that the guy that built mine (Mike) said it was covered for life against cracks so I didn't worry too much.
One piece of advice that I'm really glad I did, get the damn mani, DP, and turbo ceramic coated because the top mounts generate a lot of heat when run hard.
kore2000 is offline   Reply With Quote
The Following 2 Users Say Thank You to kore2000 For This Useful Post:
djuosnteisn (07-09-2010), jmhinkle (07-14-2010)
 Old 07-09-2010, 06:11 AM   #8
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
do you have a 3 or a 6 kore2000? i haven't seen a 3 with a top mount yet.
The Following User Says Thank You to xcoldricex For This Useful Post:
 Old 07-09-2010, 06:16 AM   #9
kore2000's Avatar
Groans: 90
I've got a 6. I'll see if I can take a pic with the cell phone today of my current setup as it sits on my car.
djuosnteisn (07-09-2010), xcoldricex (07-09-2010)
 Old 07-09-2010, 06:25 AM   #10
ILL3ST
xcoldricex's Avatar
is there enough room for a top mount for a 3?
The Following 2 Users Say Thank You to xcoldricex For This Useful Post:
djuosnteisn (07-09-2010), Fobio (07-09-2010)
 Old 07-09-2010, 06:38 AM   #11
the_caruch's Avatar
Posts: 698   (View Stats)
the_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the world
I'd go with it above the head like Mark did too. Maybe a dumb question but would it be too close to the hood to cause heat problems?
You always do badass things djuosnteisn. And whatever you decide will be no exception.
cp-e CAI, cp-e Turbo Inlet, cp-e catted DP, cp-e HPFP, cp-e flashes, cp-e Standback w/PNP, cp-e FMIC, TRZ RMM, TS Compact BOV (full re-circ), DDM 55W 6k HID's, Cobb RSB. HKS Hi-Power Exhaust, OCC
the_caruch is offline   Reply With Quote
The Following User Says Thank You to the_caruch For This Useful Post:
 Old 07-09-2010, 06:49 AM   #12
gtarman77787's Avatar
Posts: 1,872   (View Stats)
gtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the world
Groans: 444
Groaned at 154 Times in 97 Posts
i say put it in the back seat of your car
i'm pretty sure someone on MSF did that actually...
oh
oh wait... it got stolen
yeah... alright sorry -- bad suggestion
trunk maybe?
gtarman77787 is offline   Reply With Quote
The Following 12 Users Say Thank You to gtarman77787 For This Useful Post:
-cj- (07-10-2010), djuosnteisn (07-09-2010), FreeFlyFreak (07-09-2010), Jessed87 (07-22-2010), jmhinkle (07-14-2010), kgb (07-09-2010), madvillain (07-09-2010), Monotonous ONE (07-14-2010), predapio (07-10-2010), RayRayBauder (07-13-2010), spoonher (07-09-2010), wankular (07-09-2010)
 Old 07-09-2010, 07:10 AM   #13
holeinmypocket's Avatar
Posts: 1,129   (View Stats)
holeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the world
GTFO use the search button.....then determine what you goals are...seriously though GTFO of this thread NOOB
some vendor needs to just make a TM Mani....even if it's only 5 to start out with...they would sell like hot cakes
Last edited by holeinmypocket; 07-09-2010 at 07:10 AM. Reason: MSF Database - Automerged Doublepost
holeinmypocket is offline   Reply With Quote
The Following 4 Users Say Thank You to holeinmypocket For This Useful Post:
86AmishMs3 (07-09-2010), djuosnteisn (07-09-2010), gtarman77787 (07-09-2010), triplejumper18 (07-09-2010)
 Old 07-09-2010, 07:15 AM   #14
ReD BoY's Avatar
Posts: 523   (View Stats)
ReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the world
Groaned at 32 Times in 15 Posts
eh...
---Stupid kid can haz car.
ReD BoY is offline   Reply With Quote
 Old 07-09-2010, 07:34 AM   #15
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
I likethe battery turbo location actually. Besides fabbing the mani and dp which I'm sure would suck, getting to the turbo in the future would be cake
NATOR PA
 Old 07-09-2010, 07:36 AM   #16
Fagwagon's Avatar
Posts: 2,090   (View Stats)
Groans: 75
Dj, go with the side mount like conso got done. If you can do it yourself, you will save a lot of money, to me when it mounts right up on the head it still looks kinda eww.
The side mount is a lot more work but i think you will like it better in the long run!
The Following 2 Users Say Thank You to Fagwagon For This Useful Post:
djuosnteisn (07-09-2010), xcoldricex (07-10-2010)
 Old 07-09-2010, 07:42 AM   #17
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
t6 88mm
DUSTIN: I'll email you a few pics when I get home.
The Following 5 Users Say Thank You to www.cp-e.com For This Useful Post:
djuosnteisn (07-09-2010), Force_Fed (07-13-2010), FridayGt (07-22-2010), jmhinkle (07-14-2010), Realgib3 (07-09-2010)
 Old 07-09-2010, 07:47 AM   #18
Groans: 444
t6 88mm
DUSTIN: I'll email you a few pics of my weiner when I get home.
fixed
The Following 7 Users Say Thank You to gtarman77787 For This Useful Post:
-cj- (07-10-2010), djuosnteisn (07-09-2010), Frequentflyer (07-09-2010), FridayGt (07-22-2010), jmhinkle (07-14-2010), ReD BoY (07-09-2010), triplejumper18 (07-09-2010)
 Old 07-09-2010, 07:51 AM   #19
integrrac's Avatar
Posts: 95   (View Stats)
integrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond repute
someone plz just cut a hole in the hood already?
evokiller likes this.
integrrac is offline   Reply With Quote
The Following 19 Users Say Thank You to integrrac For This Useful Post:
cld12pk2go (07-15-2010), danesti (07-09-2010), dirty_derka (03-29-2011), djuosnteisn (07-09-2010), Docnox (07-10-2010), dougefresh_ (03-20-2011), Frequentflyer (07-09-2010), jayspeed3 (07-09-2010), jmhinkle (07-14-2010), kgb (07-09-2010), madvillain (07-09-2010), NoTraction (03-01-2011), prenedo (07-24-2010), ReD BoY (07-09-2010), rigor (07-10-2010), spoonher (07-09-2010), thehead (02-20-2012), wankular (07-09-2010), xcoldricex (07-10-2010)
 Old 07-09-2010, 07:52 AM   #20
ReD BoY's Avatar
Originally Posted by gtarman77787 View Post
fixed
hahahahahaha DRE FACE!
 Old 07-09-2010, 08:07 AM   #21
integrrac's Avatar
Last edited by integrrac; 07-09-2010 at 08:07 AM. Reason: MSF Database - Automerged Doublepost
The Following 9 Users Say Thank You to integrrac For This Useful Post:
djuosnteisn (07-09-2010), Frequentflyer (07-09-2010), gtarman77787 (07-09-2010), jmhinkle (07-14-2010), madvillain (07-09-2010), prenedo (07-24-2010), rigor (07-10-2010), wankular (07-09-2010), xcoldricex (07-10-2010)
 Old 07-09-2010, 08:57 AM   #22
Captain
Great ideas. I'll def make a heat shield that sits between the turbo and valve cover. It'll let me get a lil creative too, haha. And i'll use a turbine boot or w/e their called, but like a snuggie for the hotside. And probably get everything coated as well, as kore suggested. As for the hood, i guess i could attach some of that thermal tape stuff, i dunno, i'll have to think on it a bit more.
I'll definitely lean on your for some help with the hoes
We all knowz you the hoz master.
I'll post some mock up pics once i get the long block assembled.
I know DCR used mild steel for all the flanges, so i'll probably just copy him i guess. I'm not sure stainless is necessary, and it would get pricey quick.
www.permtuning.com
MATT DAMOND (07-09-2010), MS3-a(sore)ASS-rex (07-09-2010)
 Old 07-09-2010, 09:49 AM   #23
So what about this cast manifold from CPE? That's supposed to be the tightest fit ...
Just make sure you brace the big snail wherever you mount it.
 Old 07-09-2010, 10:23 AM   #24
Groans: 224
Since you brought this cast cp-e manifold up, do you have any idea on a release date for that thing? It'd save me a hell of alot of time.
NATOR PA
 Old 07-09-2010, 10:39 AM   #25
Captain
AFAIK I think they're lining there ducks up on what approach to take.
Tooling around with ideas anywhere from a full turbo solution (basically a single setup big power, like you see on some other platforms, hefty price tag, but probably cheaper than doing it in a modular fashion like we've all been doing thus far), all the way down to just a normal stock placement manifold, but with superior form / fit / function.
I think it's probably obvious what direction i'd like to see them take lol, but in the end they'll end up catering to the larger market, which doesn't exactly = dustin.
www.permtuning.com
MarkyMark (07-09-2010), MS3-a(sore)ASS-rex (07-09-2010)
 Old 07-09-2010, 11:56 AM   #26
MarkyMark's Avatar
Posts: 1,624   (View Stats)
Groans: 62
just do it like mine dude. My turbo comes of in literally 3 min and the manifold off in 20, Intake takes 30 seconds. I'll just have a filter now cuz I am changing the car to blow through
But seriously, it will cut your work time in half, and look sick. Vband the downpipe and that's a 5 min job to remove too.
MarkyMark is offline   Reply With Quote
The Following 7 Users Say Thank You to MarkyMark For This Useful Post:
802MS3 (07-09-2010), danesti (07-09-2010), djuosnteisn (07-09-2010), gtarman77787 (07-09-2010), jmhinkle (07-14-2010), SpeedSixxx (11-20-2010), xcoldricex (07-10-2010)
 Old 07-09-2010, 01:08 PM   #27
Groans: 444
i love the "smart" that goes on in this thread
seriously makes me consider BT
The Following 2 Users Say Thank You to gtarman77787 For This Useful Post:
djuosnteisn (07-09-2010), Post pwned (04-30-2011)
 Old 07-09-2010, 01:09 PM   #28
Captain
Done and done.... how about you post some pictarz so i know what exactly to do lol.
www.permtuning.com
Last edited by djuosnteisn; 07-09-2010 at 01:09 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-09-2010, 01:35 PM   #29
madvillain's Avatar
Groans: 78
Noob question.. but is there any downsides, in terms performance, to having longer runners like on a side mount manifold? I forgot you had a welder in your garage dustin... do something like that crx, shit would be bananas
djuosnteisn (07-09-2010), MS3-a(sore)ASS-rex (07-09-2010)
 Old 07-09-2010, 01:46 PM   #30
Captain
Hahahahaha, fuck that shit, i'm not gonna go that stupid. I just want to make my life easy.
Longer runners typically = a lil better torque down low, but less overall flow. But on a turbo setup, that effect is diminished AFAIK. Short and fat is ideal IMO. And placing the turbo right above the valve cover seems perfect. The mani would be very simple to build.
As soon as i get my long block assembled, i'll get started. I'll tack it all up first and get more opinions from you guys
www.permtuning.com
 Old 07-09-2010, 03:08 PM   #31
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
The wastegate sucks to pull off, but the intake,turbo, and DP can be removed in about half an hour.. Top mount is definitely the way to go...
The Following 15 Users Say Thank You to SSinstaller For This Useful Post:
Broxer (08-18-2011), cld12pk2go (07-15-2010), cpolly69 (11-29-2010), Dano (07-10-2010), djuosnteisn (07-09-2010), Docnox (07-10-2010), FamiliaGT (02-08-2011), FreeFlyFreak (07-24-2010), madvillain (07-09-2010), MATT DAMOND (07-10-2010), MS3-a(sore)ASS-rex (07-09-2010), NoTraction (03-01-2011), rigor (07-10-2010), the_caruch (07-09-2010), xcoldricex (07-10-2010)
 Old 07-09-2010, 03:10 PM   #32
Groans: 224
And then mass produce these manifolds so that we can haz teh fastz too?
NATOR PA
 Old 07-09-2010, 03:15 PM   #33
Captain
SS, how does your mani sound? It looks like all your runners are pretty damn equal length, which is ideal for spool up, but i kinda like the bubbly sound i get from my unequal length runners.
I know that my lengths aren't that different, but they definitely give some bubble to the rumble. I may intentionally exaggerate the unequal lengths, just for kicks.
Absolutely perfect. Thanks so much for the pics man!
www.permtuning.com
Last edited by djuosnteisn; 07-09-2010 at 03:16 PM. Reason: second pic answered my ?
gtarman77787 (07-18-2010)
 Old 07-09-2010, 03:18 PM   #34
RacingToaster's Avatar
Posts: 426   (View Stats)
RacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the world
Groans: 40
SS that setup looks good although the welds on that mani look kinda....well...
RacingToaster is offline   Reply With Quote
 Old 07-09-2010, 03:19 PM   #35
Groans: 60
The mani sounds like most other boosted 4 cylinders--no burble to speak of...
The intake is tight on the brake reservoir, but it clears by about .5".
Yeah, they're not the prettiest I've ever seen, but they're VERY VERY thick, and I have no doubt's about this manifold holding up...
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
djuosnteisn (07-09-2010), rigor (07-10-2010)
 Old 07-09-2010, 03:49 PM   #36
Captain
Fuck pretty if it holds.
The weld that broke on my mani after 1 week of abuse was a very very pretty weld... just didn't penetrate very well. "Stack of dimes" doesn't work if the dimes are literally laying on top of the material being welded lol.
www.permtuning.com
rigor (07-10-2010)
 Old 07-09-2010, 05:53 PM   #37
turbospeed's Avatar
Posts: 113   (View Stats)
turbospeed has a spectacular aura aboutturbospeed has a spectacular aura aboutturbospeed has a spectacular aura about
that setup is huge compared to stock
turbospeed is offline   Reply With Quote
 Old 07-09-2010, 07:55 PM   #38
madvillain's Avatar
Groans: 78
So you're generally a fan of mexicans? I have a mexican friend who they call 'Pepsi Can' if you know what im saying.
The Following 5 Users Say Thank You to madvillain For This Useful Post:
DaleNixon (07-11-2010), djuosnteisn (07-10-2010), Dre (07-09-2010), jmhinkle (07-14-2010), xcoldricex (07-10-2010)
 Old 07-09-2010, 10:57 PM   #39
SneakyP86's Avatar
Posts: 1,162   (View Stats)
Go top mount man all that length of the runners for the side mount just sounds like trouble in the long run to me. I had a fabricator lined up to make some like the one I have but at the time couldn't get anyone to say they were interested. It was about the same time everyone was so gung ho over the Medeivel manifold (so hows that working out for you guys LMAO). I'm thinking of getting some type of GTO racing scoops on my stock hood near the back of the hood to help dissipate some of that heat. Don't really think you'd need that heat shield on the valve cover but if you want some extra insurance theres got to be a better way as I think that would look pretty shitty myself.
The Following User Says Thank You to SneakyP86 For This Useful Post:
 Old 07-10-2010, 07:48 AM   #40
MarkyMark's Avatar
Groans: 62
Does this help?
The Following 24 Users Say Thank You to MarkyMark For This Useful Post:
--Top_Secret-- (12-14-2010), Broxer (08-18-2011), cld12pk2go (07-15-2010), Dano (07-10-2010), djuosnteisn (07-10-2010), Docnox (07-10-2010), dougefresh_ (03-20-2011), essejkcamraw (07-10-2010), FreeFlyFreak (07-24-2010), FridayGt (07-22-2010), ganque (07-14-2010), gtarman77787 (07-18-2010), jmhinkle (07-14-2010), Lama (07-11-2010), madvillain (07-10-2010), MPSdriver (07-15-2010), ms3=evokilla (12-26-2010), NJSPEED3 (07-10-2010), NoTraction (03-01-2011), RayRayBauder (07-13-2010), SpeedSixxx (11-20-2010), spnkr21 (07-10-2010), the_caruch (07-11-2010), xcoldricex (07-10-2010)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/top-mount-turbo-setups-61011/
Bosch 3 Bar MAP - ATR values This thread Refback 04-05-2012 07:59 PM
Mazda MPS Owners Club • View topic - New Turbo me thinks ! This thread Refback 03-20-2011 03:57 PM
Gauge setups TheNewGuy MazdaSpeed 6 - Engine, Transmission & Driveline 8 03-14-2011 06:56 PM
Top Mount Turbo Manifold aminzer Mazdaspeed3/6 General Discussion 25 02-06-2010 08:19 PM
AP & Forge setups. 08cosmic3
Cobb Access Port/Maps
0 08-08-2009 06:52 PM
TRZ Transmission Mount/ Mazda3online turbo inlet installed and review! Raider Mazdaspeed Forums User Reviews 0 06-29-2009 06:40 AM
Page generated in 0.59311 seconds with 41 queries
