 Old 12-12-2016, 01:28 PM   #1
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
Default trouble installing down pipe
Ok im open for suggestions before i start fabing this up. Background. This is a CPE manifold with a gt3582 and tial vband with an ATP downpipe. Went to go install dp and i have this much of a gap between the DP and turbo. Its about 3 inches.So my thoughts are to just get a Vband adapter. (Vband on both ends and put to clamps on it. Or have the ATP pipe cut and extended.
Sorry of the pics being upside down
track weight 3220
street weight 3370
 Old 05-01-2017, 10:13 PM   #2
Stryker125's Avatar
Posts: 386   (View Stats)
Stryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the world
@qtrmile beast; what did you end up doing?
-2006 Speed6-
PTE5862 Tial 44mm ewg
Cpe exhaust mani, Relentless PnP Intake mani
Fmic w/ tr8
+All the things
Tuned by: Will Dawson @Purple Drank
Stryker125 is offline   Reply With Quote
 Old 05-02-2017, 07:39 AM   #3
Took it to the exhaust shop and they modified the exhaust.. They cut off the Vband end off and added about 3'" of pipe and put the Vband on the end of that. Then they had to modify the connection to the cat back since it wasnt slipfit... I will try and get pictures soon...
track weight 3220
street weight 3370
The Following User Says Thank You to qtrmile beast For This Useful Post:
Stryker125 (05-04-2017)
Having trouble installing CPE RMM JS + MS3 2010 MS3 - Engine, Transmission & Driveline 31 09-08-2011 02:24 PM
INstalling a used CS test pipe in the morning, what bolts will I need? jasonspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 5 07-11-2009 10:25 PM
Page generated in 0.23970 seconds with 22 queries
