Like Tree7Likes
 Old 02-24-2012, 12:29 PM   #1
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
Default TRSpeed GTX3071r EWG
So after having the worst BT fever ever, I decided it was time.
I want to thank @JP@edgeautosport.com for AMAZING customer service, advice, and pricing. Definitely highly recommend you give this man for your BT needs or pretty much anything.
Here: 720-215-0225
Tuning will be started ASAP with the one and only @Lex and some Corn Love.
Go the hook up with:
-GTX3071r with ATP EWG Turbine Housing Bolt on Kit:
Kit comes with:
**38mm Tial MVS
**Oil/Coolant Lines
**Dump Tube
**V-band Clamps
-90 Degree Elbow for WG
-CPE Whale Penis
-CPE BIG MAF
-GS EBCS
-2.25 to 2.00 Silicone
Parts Should be in 2 weeks.
Ill keep updated.
@Daddy Chinkus (derek)
@keefover (jordan)
@SleeperHatch (gale)
@TRSpeed (aaron)
@Whiteboy (jon)
@streets (tony)
@BPASPEED (Arnaldo)
@JohnMS3 (john)
@turbo test (daniel)
@Hamilton69 (graham)
@midoritora (meynard)
@UnknownSuperhero (GREG)
@Phoenix Speed3 (brenden)
@TheDeebs
@darth_speeder (alex)
@EL F00LI0 (EL FLAKE)
@Dash08
@Oliverms3
@nobrakez
@jv83
@Ex_WRX_driver
@JCMS07
@MattJackson86
@f-castrillo
@RJD23
@MS3MYK
@BrownMagic
@Zoomspeed
@Boosten Ya(josh)
@krazycoble
04/05/2012
Ok guys Sorry for not updating, I have just been very busy with work.
Here are the pics of parts.
Install went pretty smooth especially with the help of @Daddy Chinkus asian hands and @UnknownSuperhero place and everything else. Pretty much thank everyone for the great help.
Here are a Few Tips:
Tip:1 Install Oil Feed Line before tightening down turbo to manifold that banjo bolt is a huge PITA SERIOUSLY. If you didn't Tighten the banjo before well you will need pliers, screw driver and paper in Socket trick thanks to @eric@edgeautosport.
-place bottom and top banjo washers. place screw driver thru middle so washers don't fall off.
-with pliers align the oil feed hard line.(keeping Screwdriver in until perfect alignment).
-with paper in socket tighten down banjo bolt.
Tip:2 You will need a longer Coolant drain line hose. Unfortunately i don't remember the size.
Tip:3 Get @Lex for tuning madness!
If I remember more tips I will keep updated.
WVDPS643 likes this.
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline   Reply With Quote
The Following 16 Users Say Thank You to TRSpeed For This Useful Post:
atvfreek (02-24-2012), Boosted Beluga (02-24-2012), charlesfist (02-25-2012), Dash08 (02-25-2012), EdgeAutosport.com (02-27-2012), JohnMS3 (03-06-2012), JP@edgeautosport.com (02-24-2012), jv83 (02-24-2012), Lex (02-24-2012), Monotonous ONE (02-24-2012), Oliverms3 (02-24-2012), Phoenix Speed3 (03-06-2012), rfinkle2 (02-24-2012), Vader (02-24-2012), Whiteboy (02-24-2012), xI Leveler Ix (04-07-2012)
 Old 02-24-2012, 01:30 PM   #2
Whiteboy's Avatar
Posts: 2,032   (View Stats)
Whiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the world
Groans: 142
I freaking hate you! Seriously, I do...
You guys have E85 down there??? Lucky bastard!
~My Mod List: ETS TMIC; CP-E SRI; COBB TIP; CP-E DP; CP-E RMM; CP-E Safe Seals; ITV-22's; GHL SS CBE; TWM STS w/bushings; Autotech HPFP Internals; AP (Stratified by Lex); Matt Damond OCC; CP-E Triple Gauge Pod w/ Prosport Premium Boost, AFR, and Oil Pressure Gauges; JBR Eliminator Shift Knob~
Whiteboy is offline   Reply With Quote
 Old 02-24-2012, 02:54 PM   #3
EL F00LI0's Avatar
Posts: 703   (View Stats)
EL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the world
How much did that run you? Never heard of an ewg kit just the mazda hotside housing. Looks like its going to be a good build dude.
Sent from my BlackBerry 9300 using Tapatalk
2008 MAZDASPEED 3 GT
| Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP |
| Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 |
| Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip |
EL F00LI0 is offline   Reply With Quote
 Old 02-24-2012, 03:34 PM   #4
TRSpeed's Avatar
Lol ya have to drive 30mi for it and store it in 5 gal jugs lol
And ya its the mazda flange and the Turbine housing has an EWG flange. All you do is switch turbine housings. Same easy bolt up like the iwg.
You need to get your Build going!!
Sent from my DROID4 using Tapatalk
Lex Tuned
 Old 02-24-2012, 03:38 PM   #5
Zoomspeed's Avatar
Posts: 370   (View Stats)
Zoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the world
Nice Ill get mine soon...
Performance CobbAPCobbSRI/TIPAutotechInternalsDensoITV22 PlugsForgeBPVJBRDog Bone MountSpeed DaddyCatless DownpipeGreddyOCC
Appearance DDM5000k Headlights/3000k FogsCobbShift KnobCorksportLED Bumper LightsDepoLED Tails
E85
Zoomspeed is offline   Reply With Quote
 Old 02-24-2012, 03:39 PM   #6
TRSpeed's Avatar
Do it!!!
Lex Tuned
 Old 02-24-2012, 03:56 PM   #7
darth_speeder's Avatar
Posts: 653   (View Stats)
darth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the world
ill go BT...
in 3 years
[SIGPIC][/SIGPIC] Corn Fed//Richtuned
darth_speeder is offline   Reply With Quote
 Old 02-24-2012, 04:05 PM   #8
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
Nice man I kinda wish I would have went EWG but didn't wanna spend the extra money
Sent from my Epic Win Avatar
2009 CWP Speed3
 Old 02-24-2012, 04:06 PM   #9
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
sweet man. glad your getting this. Let me know if you have an install day. I'll go and help out.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 02-24-2012, 04:08 PM   #10
You guys will know BT installs like the back of your hands in Cali. Tell you what - I make a summer trip down there with a BT in the trunk, you guys do a one day install on my car while I tune your cars, and I drive back to Canada with the BT under the hood
The Following 9 Users Say Thank You to Lex For This Useful Post:
atvfreek (02-25-2012), Boosted Beluga (02-24-2012), BPASPEED (02-27-2012), Dash08 (02-25-2012), i8urgti (02-25-2012), IshiKage (02-24-2012), Phoenix Speed3 (02-26-2012), TRSpeed (03-12-2012), UnknownSuperhero (03-06-2012)
 Old 02-25-2012, 01:22 PM   #11
Come on out bro! Get your BT done and tune us up!
2009 CWP Speed3
 Old 02-24-2012, 04:13 PM   #12
EL F00LI0's Avatar
Yeah I know of the ewg housing and shit I just didn't know edger sold a kit with an ewg included.
And yeah, I'm prob gonna be stuck with my pte5557 cuz no one wants to buy it so we can both have ewg builds goin. As soon as I get my refund check I'm buying a mani and ewg. And my build will begin
The Following User Says Thank You to EL F00LI0 For This Useful Post:
 Old 02-24-2012, 04:13 PM   #13
Groans: 50
free tunes for life???
08 Mazdaspeed 3
 Old 02-24-2012, 04:36 PM   #14
TRSpeed's Avatar
Originally Posted by darth_speeder View Post
ill go BT...
in 3 years
Haha aslong as you do
nigga you gots a gtx bt too so it doesnt matter. Still gonna be hella beast!
bro ive been wanting to do this since those kits came out lol and ill let you guys know. Will be installing down at cales.gregs.or dereks lol
haha do it!!!!!!
well hurry nigga we needs to get started.you got 2 weeks lol
Wouldnt that be nice lol
Lex Tuned
 Old 02-24-2012, 04:41 PM   #15
671 grains of reason's Avatar
Posts: 350   (View Stats)
671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world
when i go bt im definitely going with jp@edgeautosports. im really leaning toward the same turbo you have right now. i keep reading too much good information on this set up.
2006 MAZDASPEED6 // SURE R6 // SURE AEROS & TIH // COBB AP // JBR TIG // SURE ANCHORS & SHORTCUT // SURE DREADNAUGHT // WHITELINE RSB // RACING BEAT E.L. // ULTRA GAUGE // AMSOIL FLUIDS
formerly pursuit_special
671 grains of reason is offline   Reply With Quote
 Old 02-24-2012, 05:02 PM   #16
I am VERY curious how this housing with the build in WG works. I have no double it will be able to control boost but having that exhaust come out right in the middle of the housing is ... interesting ... so we'll see how this does.
 Old 02-24-2012, 07:48 PM   #17
TRSpeed's Avatar
Ya we will see. I havent really seems many people use this housing. But good thing is that people will know very soon. And if anything bad, well ill just cap off the EWG hole and just get a EWG Mani.
Lex Tuned
 Old 02-24-2012, 08:07 PM   #18
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
please document as much as possible
this is what imma do one day
 Old 02-24-2012, 08:08 PM   #19
jv83's Avatar
Posts: 466   (View Stats)
jv83 is the leader of the worldjv83 is the leader of the worldjv83 is the leader of the worldjv83 is the leader of the worldjv83 is the leader of the worldjv83 is the leader of the worldjv83 is the leader of the worldjv83 is the leader of the worldjv83 is the leader of the worldjv83 is the leader of the worldjv83 is the leader of the world
I ENVY YOU! I have about 3 years as well before any major mods. Gotta hit up jp@edgeautosports for a AP ASAP! Got my tax return and its burning a hole in my account.
jv83 is offline   Reply With Quote
 Old 02-24-2012, 08:08 PM   #20
TRSpeed's Avatar
Definitely will. Should not be too bad.
Lex Tuned
 Old 02-24-2012, 08:37 PM   #21
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
all i know is stupid gales turbo busted up my hands real good, i aint wrenching shit. all i will do is eat and command
The Following 3 Users Say Thank You to dooderek For This Useful Post:
Boosted Beluga (02-24-2012), Dash08 (02-25-2012), SleeperHatch (02-24-2012)
 Old 02-24-2012, 09:19 PM   #22
Haha yes it did...my hands are fucked as well. Although I WILL ADMIT without @Daddy Chinkus help I would have never been able to do this much less get the car running in 1 day with all the problems we ran into.
2009 CWP Speed3
 Old 02-24-2012, 09:43 PM   #23
JP@edgeautosport.com's Avatar
Posts: 887   (View Stats)
We are actually the only ones offering this as a one item bolt-on kit. We put ALL the items you need together for a kit as an item on our website. You can select the turbo, color of the wastegate, and the optional CPE Big Turbo TIP. It comes with EVERYTHING the IWG kits come with to make it a full bolt-on kit but with the EWG setup instead. We actually sold 2 of these exact same setups this week. We are also about to install this setup on our shop car with the CPE manifold and a GT3076R. We will be documenting EVERYTHING including a back to back test of a tuned stock mani and the same tune with bolting on the CPE mani. We will be able to show people EXACTLY how much power you can potentially gain by bolting on a manifold with not only the big turbo but we're going to do it with stock turbo as well for all those considering upgrading the manifold before the turbo.
@eric@edgeautosport.com ran this setup with the GT3076R and made 447whp with a small E85 mix. Of course, he had the one and only @djuosnteisn to help with that locally. But the setup can make power, there's no doubt.
We love how easy this turbo kit is. You can literally bolt-on an entire EWG setup about as easy as the IWG setups.
CLICK HERE TO SEE THE TURBO KIT ON OUR WEBSITE
@TRSpeed and @SleeperHatch, can't thank you guys enough for your support. Thanks for being customers. We really appreciate it.
Lex, just stop halfway in Washington and we'll help you out We'll even have the turbo ready so you don't have to bring it here haha
The Following 11 Users Say Thank You to JP@edgeautosport.com For This Useful Post:
BPASPEED (02-27-2012), charlesfist (02-25-2012), Dash08 (02-25-2012), EdgeAutosport.com (02-27-2012), Lex (02-25-2012), Manny3 (02-25-2012), Scribbles (02-25-2012), SleeperHatch (02-25-2012), speedms6 (02-25-2012), thehead (02-25-2012), warlord (02-24-2012)
 Old 02-24-2012, 09:09 PM   #24
TRSpeed's Avatar
Hahaha have cale jerk you off nigga
Lex Tuned
The Following User Says NO Thank You to TRSpeed For This Un-useful Post:
 Old 02-24-2012, 09:37 PM   #25
TRSpeed's Avatar
Damn lol don't worry ill pass out some oxy pills before we start my build haha. And would this have been easier with a lift since you ain't installing a long exhaust part?
Lex Tuned
 Old 02-24-2012, 09:54 PM   #26
TRSpeed's Avatar
This is why, Jp is the best.
Also do it @Lex!!!! Then come down here!
Really anxious to install this beast!
Lex Tuned
The Following 3 Users Say Thank You to TRSpeed For This Useful Post:
EdgeAutosport.com (02-27-2012), Lex (02-25-2012), thehead (02-25-2012)
 Old 02-24-2012, 10:10 PM   #27
2zz mr-s
dooderek's Avatar
Groans: 239
ima say this, if your buying shit from someone else besides jp your doin it wrong. this dude raises the bar when it comes to customer service and prices.
EdgeAutosport.com (02-27-2012), thehead (02-25-2012), WWPearlMS6 (02-25-2012)
 Old 02-24-2012, 10:25 PM   #28
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Have to agree, even all the way from Australia
Sent from my Galaxy Nexus using Tapatalk
 Old 02-25-2012, 01:23 AM   #29
Groans: 50
I want a GTX3076R IWG. A great turbo for $1700
08 Mazdaspeed 3
 Old 02-25-2012, 01:53 AM   #30
krazycoble's Avatar
Posts: 662   (View Stats)
krazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the world
Damn Aaron...you ain't fucking around! You got me wanting to pull the trigger now on a BT lol!
Stratified Tuned 2011 MS3 | 410 HP - 402 TQ | Dynojet 10-21-12
krazycoble is offline   Reply With Quote
The Following User Says Thank You to krazycoble For This Useful Post:
 Old 02-25-2012, 02:27 AM   #31
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
Does ATP list the A/R for the EWG housing?
Fueled by the haters.
 Old 02-25-2012, 07:37 AM   #32
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
It's always .55.
2007 CTS-V - Trying to sell
 Old 02-25-2012, 08:38 AM   #33
It's always .55.
This has been an ongoing mystery but ATP claims it's .72. I know some of the earlier turbos had a .55 actually cast in to the turbine housing (from what I'm told) but to this day I've asked ATP 2 or 3 times on the phone and they say it's .72. For whatever it worth....
Also, I always tell people at the end of the day, it doesn't matter, it's the only Mazda flange turbo upgrade for a Garrett turbo. It's not like there are choices so it is what it is.
 Old 02-25-2012, 09:20 AM   #34
I was just curious if they changed it for the EWG housing.
Either way I very happy with the 0.83 Tial housing you supplied me and I can't wait until the motor is ready.
The Following 2 Users Say Thank You to Celestspeed3 For This Useful Post:
EdgeAutosport.com (02-27-2012), JP@edgeautosport.com (02-25-2012)
 Old 02-25-2012, 10:47 AM   #35
TRSpeed's Avatar
great for you since your built lol
Jason all i got to say is, Do IT!!! No other can can just bolt straight up BT for the price and make easy 430 whp without replacing clutch, trans, complete fuel system, etc. its simple just a few parts.
it is the same as the iwg a/r, which I believe is. A .72
It's always .55.
.72
Boosted Beluga likes this.
Lex Tuned
The Following 2 Users Say Thank You to TRSpeed For This Useful Post:
Boosted Beluga (02-25-2012), EdgeAutosport.com (02-27-2012)
 Old 02-25-2012, 10:59 AM   #36
Groans: 50
I'll have to see where I stand next year. I might say fuck it and and by one next year with taxes.
08 Mazdaspeed 3
 Old 02-25-2012, 10:59 AM   #37
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
Groans: 266
@JP@edgeautosport.com Where are you guys in washington
DONOTBUGME is offline   Reply With Quote
The Following User Says Thank You to DONOTBUGME For This Useful Post:
 Old 02-25-2012, 12:09 PM   #38
bmylez's Avatar
Groans: 31
Interesting. Pretty sure I've seen nothing but .55 printed on the housings, so I guess ATP fails at labeling their housings?
They are in Colorado (it's in their profile info )
The Following 2 Users Say Thank You to bmylez For This Useful Post:
EdgeAutosport.com (02-27-2012), ms3_150 (02-29-2012)
 Old 02-25-2012, 12:51 PM   #39
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
That's what I thought but all the stuff i've ordered has shipped out of WA. Based on UPS info i'd guess they are in or around Vancouver
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline   Reply With Quote
The Following User Says Thank You to Broxer For This Useful Post:
 Old 02-25-2012, 12:58 PM   #40
No change in A/R going from IWG to EWG for the bolt-on kits.
We are actually in both places lol. I moved the company out to WA for personal reasons back in October but we'll be moving back to Denver this summer. We're in Vancouver right now, Portland area.
The Following User Says Thank You to JP@edgeautosport.com For This Useful Post:
GenPU GTX3071r build stang9779 2010 MS3 - Big Turbo Builds 519 04-05-2012 09:13 PM
GTX3071R? Cataphract_40 MazdaSpeed 3/6 - Big Turbo Builds 17 10-28-2011 10:46 AM
Page generated in 0.71418 seconds with 39 queries
