  • 1 Post By QwkEVO
  • 1 Post By mason
 Old 04-13-2012, 12:11 AM   #1
QwkEVO's Avatar
Posts: 484   (View Stats)
QwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the world
Default Update: Battery relocation complete!
So got to my battery relocation today. There just was NO room in between my CPE TIP and the ecu. Ecu was zip tied to the front of the battery box until today.
For those wondering why I have no battery kill switch in the rear for running at the track? I talked to the local track owner and he said as long as I'm not running a 10 second car, and the battery is properly mounted then he will allow me to run. If that rule ever changes it's not that big of a deal really to rewire the trunk for a kill switch.
So I ran 1/0 gauge from the trunk under the car, along the passenger side and into the engine bay. Ran a 1/0 from the alternator back to the power distirbution block. 200 amp circuit breaker underhood as well so when I'm working on the car, just flip a switch to kill power from the battery. Made a custom aluminum mounting plate for the ecu. I reused the factory ECU mounting plate and cover. Grimmspeed mounted to the side of the ECU cover. Use factory mounting points for the custom plate. It's rock solid.
Took me and my buddy about 6 hours start to finish. I think it came out pretty clean.
All I have left under the hood is getting some 90 degree barbed fittings for the line running from the maf to the valve cover so I dont have all that hose snaking along. Make it more of a straight run that way.
brandon3212 likes this.
08 MS3 //PTP Injector seals & stud kit //CP-E RMM //Corksport Sway Bar // Koni Yellow Sports // Eibach Pro Kit Springs // Enkei 18" PF01's //
QwkEVO is offline   Reply With Quote
The Following 18 Users Say Thank You to QwkEVO For This Useful Post:
2008MS3H (04-15-2012), 86AmishMs3 (04-13-2012), ABolewski (12-24-2012), brandon3212 (10-15-2014), crazyp (04-13-2012), doubleflusher (04-28-2012), fishin53 (04-29-2012), helmetface (04-13-2012), JasonMzdSpd3 (04-17-2012), josurr (04-13-2012), jracer (04-13-2012), Ms3_Miami (04-14-2012), ryno077 (05-27-2012), SPEED6 KILLAH (04-15-2012), the public enemy (08-22-2012), uncorked11 (08-27-2012), Z32_MS3 (09-01-2014), Ziggo (04-28-2012)
 Old 04-13-2012, 01:56 AM   #2
leon78's Avatar
Posts: 2,595   (View Stats)
Job looks well thought out and done clean. Nice.
2013 Scion FR-S (Whiteout)
Less parking more racing
The Following User Says Thank You to leon78 For This Useful Post:
QwkEVO (04-13-2012)
 Old 04-13-2012, 06:52 AM   #3
Mase's Avatar
Posts: 1,282   (View Stats)
Mase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the world
Groans: 143
Groaned at 14 Times in 14 Posts
Looks great!
2014 Mazda 6 Grand Touring. Bone stock...
Old car: 2011 Speed 3 /w Tech Pkg. Cobb AP, CPE DP & CBE, JBR Whale Penis Intake, SSP, Motor Mount Trio, and Heavy Shift Knob /w silver vein!, Autotech internals, KSport Konrol Pro Coilovers, Corksport Interior LED's, LED Foglights and LED Rear Bumper Lights. Freek Tuned 50/50 e85
Mase is offline   Reply With Quote
The Following User Says Thank You to Mase For This Useful Post:
QwkEVO (04-13-2012)
 Old 04-13-2012, 05:58 PM   #4
nothing to see here....
drknyte's Avatar
Posts: 501   (View Stats)
drknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the world
Groans: 39
Groaned at 43 Times in 18 Posts
R u putting the spare tire where the battery went?
I kid, I kid!
Looks good!
2008 Mazdaspeed 3 GT in Black Mica:
60ft: 2.167
1/8: 9.052
1/4: 13.922 @ 100.37
(26psi tire pressure & stock tires)
CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP
drknyte is offline   Reply With Quote
The Following 2 Users Say Thank You to drknyte For This Useful Post:
impossible (11-29-2016), Tommy (04-16-2012)
 Old 04-13-2012, 07:38 PM   #5
QwkEVO's Avatar
I kid, I kid!
Looks good!
Thats why I have a cell phone & Triple A! lol
Originally Posted by mason View Post
i would like to do this also. how much did everything cost you?
The battery was at sams club for $160. The wiring, fuse blocks, dist. blocks, circuit breaker, etc. ran an extra $175. I didnt have my camera with me, otherwise I would of taken under the car pics to show the routing. All that time and money for a few extra inches of room hehe. Worth it though. Makes working in that area soooo much nicer now.
Last edited by QwkEVO; 04-13-2012 at 07:38 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to QwkEVO For This Useful Post:
RobT2009 (09-23-2012)
 Old 04-13-2012, 06:25 PM   #6
mason's Avatar
Posts: 946   (View Stats)
The Behemoth likes this.
 Old 04-13-2012, 06:36 PM   #7
Death-From-A-Mile's Avatar
Posts: 1,371   (View Stats)
Death-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the world
Groans: 87
Links to the switches and power distribution box?
Death-From-A-Mile is offline   Reply With Quote
 Old 04-13-2012, 07:44 PM   #8
QwkEVO's Avatar
I bought them off the wall at my buddy's shop. Most expensive piece was the wiring (1/0 isnt cheap) and the circuit breaker which was $30. Everything else was $30 or less. All the parts and wiring are from Soundquest (Sound Quest Electronics). You can get the parts a lot cheaper on ebay. I paid a bit below retail only because it's my buddies shop and he wasnt charging me for labor to lend a hand. And I got to use his lift.
 Old 04-14-2012, 12:19 PM   #9
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
For future modders, when I was doing sound competitions we used 0 gauge welding cables, it is very flexable, has a high strand count, is copper, and best of all its cheap. You can even buy it used if you dont mind it being scuffed up.
2006 Mazdaspeed 6
The Following 4 Users Say Thank You to 06Speed6 For This Useful Post:
helmetface (04-28-2012), RobT2009 (09-23-2012), SLOWHATCH (04-14-2012), torquemaniac (02-20-2014)
 Old 04-15-2012, 12:05 PM   #10
mazdamx3freak's Avatar
Posts: 219   (View Stats)
mazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond repute
how many feet of power wire did you use? and you ran it under the car? could you explain that a little better or pics of it , thanks.
2008.5 CPW
JBR:3.5 intake, fmic, r51 Battery Box, Ancors, EGR Delete, Thermal Spacers, 5mm Wheel spacers, Shift plate.
Matt Dimond OCC, Autotech Internals, CNT catted downpipe, itv-22, Threadstone T8L FMIC,SU Turbosmart Bpv, SUv2 Rmm
mazdamx3freak is offline   Reply With Quote
 Old 04-15-2012, 03:12 PM   #11
QwkEVO's Avatar
Sorry no pics from under the car. Next time when I have it on the lift I'll shoot some pics of the routing.
 Old 04-16-2012, 09:30 PM   #12
driver311's Avatar
Posts: 1,769   (View Stats)
Wow very impressive man. Does that intake have a straigtener? I like the extra room from no battery. id like to do that but my track will make me have a battery kill switch. Hmmmmm.
Suggestion. Shave that intake manifold and itll look soooo good. Man im impressed with your motor bay.
Mazdaspeed
 Old 04-17-2012, 09:44 AM   #13
QwkEVO's Avatar
Thanks man! But what do you mean by shaving the intake manifold? It's ceramic coated now so I wouldnt want to do anything to harm the coating. No straightener on the intake, although I'm thinking about adding a honeycomb to it from Treadstone.
 Old 04-28-2012, 03:09 PM   #14
Ziggo's Avatar
Posts: 3,843   (View Stats)
What about that battery tray? Looking to duplicate this setup.
Ask Me About My:
 Old 04-29-2012, 07:00 AM   #15
QwkEVO's Avatar
The battery tray is just a standard universal one size fits all as well as the adjustable tie down you can get at any local auto parts store. I used 3/8 all thread (Lowes) for the bolt(s) securing it. Fender washer, lock washer and nut underneath the car, as well as right inside the bottom of the trunk to lock it into place. As well as the same washer, lock washer, nut on top of the tie down. Be sure you use some kind of sealant around the all thread where it comes into the car at the base of trunk.
Good luck!
Ziggo (04-29-2012)
 Old 09-23-2014, 01:40 PM   #16
tzddrmz's Avatar
Posts: 8   (View Stats)
tzddrmz is an unknown quantity at this point
Where does that ground wire thats grounded on the strut tower go to?
tzddrmz is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/update-battery-relocation-complete-110653/
The Official Sacramento chat/meets thread Part 3 - Page 120 - 8th Generation Honda Civic Forum This thread Refback 04-17-2012 11:04 PM
battery relocation diy dooderek MazdaSpeed 6 - How-To's 19 10-07-2013 05:15 PM
My battery relocation Nitr0EngiE MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-18-2011 05:55 PM
battery relocation kit??!!! turd burglar MazdaSpeed 3 - Engine, Transmission & Driveline 4 04-03-2010 02:08 AM
Battery Relocation? madvillain MazdaSpeed 3 - Engine, Transmission & Driveline 43 03-01-2010 11:00 AM
Battery Relocation KayWhy MazdaSpeed 3/6 - Car Audio & Electronics 18 08-24-2009 09:59 AM
Page generated in 0.37740 seconds with 30 queries
