Closed Thread
 Old 01-30-2012, 06:13 PM   #1
yaeger101's Avatar
Posts: 124   (View Stats)
yaeger101 is a jewel in the roughyaeger101 is a jewel in the roughyaeger101 is a jewel in the rough
Groaned at 40 Times in 10 Posts
Default upgrade stock
I'm looking to upgrade my stock turbo i don't want anything to big car is a daily driver n winter beater. just want a lil more n get rib of the stock shit one
yaeger101 is offline
 Old 01-30-2012, 06:15 PM   #2
RayRay's Avatar
Posts: 3,120   (View Stats)
RayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the world
Groaned at 9 Times in 5 Posts
What other Mods do you have done? You might find the power and performance you need just by simply adding bolt on power to your car... And, what kind of car do you have?
2009 MazdaSpeed 3
Spy Hunter Smoke Screen Mod
Cobb AP (Custom Tune), ATP GTX3076 28PSi, CP Forged Pistons .020 Over, Pauter Forged Rods, Bore and Hone Block .020 Over, CP-E DISI Injector Seals, ARP Head Studs, MZR Cometic Head Gasket, ACT Stage 2 Heavy Duty Clutch,Cobb SRI Intake, JBR TIG, JBR TB Gasket, JBR 88 Duro Transmission Mount, JBR EGR Delete , JBR TB Coolant Bypass, CP-E Big Turbo TIP, KMD HPFP Internals, Street Unit TurboSmart Dual Port BOV, CorkSport TMIC, CorkSport DP, CorkSport Test Pipe, CorkSport CBE, CPE Single Guage Pod, DashHawk, Prosport Boost Gauge, Devils Own Progressive Methanol Injection Kit 80/20 with D07 Nozzle, E85 Tune 50/50, JBR DogBone 88 Duro Rear Motor Mount, CorkSport Mid Chassis Brace, JBR Stage 2 Short Shift Plate, H&R Springs, 18x8 Drag DR38 +47, Eibach 5mm Spacers, 235/40 18 Brisgestone RE760.
RayRay is offline
 Old 01-30-2012, 06:15 PM   #3
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
So, uh, read through the stickies and do some research here. Plenty of info........ALREADY.......available for you to read through.
07 MS3
The original Genpoo Hater
Chimmike is offline
Closed Thread
stock turbo replacement upgrade 671 grains of reason MazdaSpeed 3/6 - Turbo Induction 63 09-17-2011 09:14 AM
Which upgrade shocks for stock MS3 Qtip MazdaSpeed 3/6 - Suspension & Brakes 31 05-14-2010 01:29 AM
Intercooler upgrade on stock ECU mituc MazdaSpeed 3/6 - Turbo Induction 6 08-06-2009 11:34 AM
Upgrade stock exhaust on MS3 jlefrense Mazdaspeed3/6 General Discussion 9 03-11-2009 02:26 PM
Stock turbo upgrade mdogg MazdaSpeed 3/6 - Turbo Induction 20 03-31-2008 02:14 PM
Page generated in 0.23547 seconds with 22 queries
