 Old 11-26-2011, 11:15 AM   #1
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
you also have to understand automotive technology as changed alot since when the book was made. ive personally talked to corky bell, you can also reach him since he owns a company called begi. i briefly asked him about maximum boost, and he said that although he stands by what he said at the time, alot as changed since then and technology has made some of his points obsolete.
in the last paragraph imo it sounds more like hes saying if you cant get enough fuel, dont band aid it by wmi injection.
however on the relevant topic he pretty much says.
"Water Injection is best used when boost levels over 6 psi are desired but no intercooler is present. "
my advice isnt to delete a intercooler completely, but if wmi is used, i would advise to run a smaller intercooler as you will have less of a pressure drop, and with wmi there really is no need for the extra air to air cooling.
oh and running a big intercooler requires modification of the crashbar. i had to cut mine at the flanges since those are what hold the core up. another food for thought
Evo 8 intercooler zumin 2010 MS3 - Turbo Induction 6 02-25-2011 03:25 PM
INTERCOOLER akbrazil 2010 MS3 - Engine, Transmission & Driveline 100 05-06-2010 10:08 AM
HELP...OIL IN INTERCOOLER bombdotcom MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-16-2008 02:22 PM
Page generated in 0.23536 seconds with 21 queries
