 Old 04-26-2015, 05:46 PM   #1
MY DICK IS SMALL-beautfpowers@gmail.com's Avatar
Posts: 327   (View Stats)
MY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these parts
Groaned at 212 Times in 84 Posts
Default what is the largest turbo size i can fit on stock location
i have the cpe exhaust mani, i want a 35r, is this possible
MY DICK IS SMALL-beautfpowers@gmail.com is offline   Reply With Quote
The Following 3 Users Say NO Thank You to MY DICK IS SMALL-beautfpowers@gmail.com For This Un-useful Post:
Agent_Orange (04-26-2015), Easter Bunny (04-26-2015), NCspecV81 (04-26-2015)
 Old 04-26-2015, 06:14 PM   #2
 Old 04-26-2015, 06:16 PM   #3
Police - Grammarhead
Vansquish's Avatar
Depends on how stretched out your anus is.
The Following 3 Users Say Thank You to Vansquish For This Useful Post:
Easter Bunny (04-26-2015), ItsNox (04-27-2015), robbspeed (11-26-2015)
 Old 04-26-2015, 07:25 PM   #4
Cevaes_64's Avatar
Posts: 1,066   (View Stats)
This one
The Following User Says Thank You to Cevaes_64 For This Useful Post:
HYDRO (04-26-2015)
 Old 04-26-2015, 08:36 PM   #5
im glad in my absence the mazdaspeed community hasn't changed a bit, my anus has been throughly stretched by this car so you are prob accurate with above post.
 Old 04-26-2015, 09:03 PM   #6
NCspecV81's Avatar
Posts: 2,867   (View Stats)
35R on a stock flange isn't going to be much better than a 3076 or 3071. If you want to go beyond a 30 frame I'd suggest going with the CPE atmosphere kit or go T3+.
2013 CWP and Stock
 Old 04-26-2015, 11:00 PM   #7
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
What turbo to choose is directly related to your power goals and if you will stay on stock block or go built. If you do not plan on building it then a gtx3071/76 is perfect. They can max out your fueling and go much further than what the oem rods can handle.
I'm on a gtx3076 and love it, if I go built I will not need to upgrade the turbo unless my goal is north of 500awhp
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 04-26-2015, 11:03 PM   #8
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
how big is your wallet
94 M
MS6
IS350
 Old 04-26-2015, 11:06 PM   #9
my goal is around 700, i am ordering the jm intake with the speed performance injector kit, i am building the motor completely along with the trans. So will the 35 fit in the stock location with that manifold. I am assuming yes from the way you guys are talking, and thanks for actually trying to answer my question! ( though i do enjoy a good roast)
bigger than my dick, but not as big as my balls.
Last edited by MY DICK IS SMALL-beautfpowers@gmail.com; 04-26-2015 at 11:06 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-27-2015, 12:31 AM   #10
acemanz's Avatar
Posts: 224   (View Stats)
acemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the world
off topic but did you ever manage to find a carbon fiber hood that you were looking for?
acemanz is offline   Reply With Quote
 Old 04-27-2015, 12:58 AM   #11
i gave up, and got a refund. Now I'm going to make them let me return the trunk i bought, hopefully they won't be dicks about it. I had mentioned it to them before but and they seemed ok with it. If a carbon fiber hood comes out one day down the road after i do this build and i feel like i want it ill cross that bridge when i get to it. I'm going to install some carbon fiber mustang vents in the stock hood tho(already have them). Its going to look like sex...trust me.
 Old 04-27-2015, 01:00 AM   #12
this is what they look like, use your imagination
 Old 04-27-2015, 01:19 AM   #13
acemanz's Avatar
why return the trunk? you could always paint it. still saving weight even if the hood doesnt fully match.
Apparently painting carbon fiber is hard though...
 Old 04-27-2015, 03:02 AM   #14
broda's Avatar
Posts: 375   (View Stats)
700 HP is going to need to be larger than a GT35...
 Old 11-26-2015, 06:42 AM   #15
ok then how big can i go, can i go 40? will i have to top mount, I'm trying to organize everything so i can start the wallet raping and get the parts, i want my build done for april, i was thinking 35 but then was thinking wit th head work I'm going to do if i can rev to 7300 why not have a turbo that will make power to redline( lag i know) but you get the idea.
thanks guys
 Old 11-26-2015, 06:58 AM   #16
Mazdazilla6 (11-26-2015), WetzMS3 (11-30-2015)
 Old 11-26-2015, 09:10 AM   #17
i know man, i know. i know nothing. I'm trying, help me out.
 Old 11-26-2015, 09:45 AM   #18
Groans: 33
The 35 turbo will have plenty of power at 8.5k rpm if we could rev that high without mayor modifications. And if you want 700hp then start selling yourself on a street corner coz it's gonna cost you
Mazdaspeed6 -06
290 AWHP / K04
 Old 11-26-2015, 11:34 AM   #19
broda's Avatar
We can't run that high in RPMs anyway since we don't have the tuning available to do so.
If you want to use a 35 then the best option is the HTA3586.
The Following User Says Thank You to broda For This Useful Post:
 Old 11-26-2015, 12:02 PM   #20
HTA is a good option. Xona rotor is having a name your price sale on their new turbos, those things are spiffy. @HawkeyeGeoff;
HawkeyeGeoff (12-01-2015)
 Old 11-27-2015, 08:27 PM   #21
can i go bigger than a 35, like a 40? i feel like the 35 won't get me to 700.
i guess my real question is am i going to buy a turbo and have it not fit in the car lol
i have the cpe manifold
I'm doing an all out engine/trans and big turbo build so i have been working the street corner for the extra cash I'm thinking i need to spend about 15k ( maybe 20 FML) to get me the rest of the way there and I'm OK with that because i want to finally drive my car but when this is done the car will be pretty much new and should last me a long fucking time since i don't drive in the winter, and i also hope to be able to make a few bucks back selling off the parts i have on it now
help is appreciated guys!
 Old 11-27-2015, 08:42 PM   #22
Groans: 33
Im guessing you are on stock flange on that cpe mani? If that's the case you should sell it and go with this kit: Precision Turbo Kit V-Band Ball Bearing Turbo Mazdaspeed 6 2006-2007 - EdgeAutosport.com
You'll never get close to 500 on a stock flange mani. You need v-band, like the kit above. Go with the 6266, 0.82 A/R and Ported "S" compressor. And you might get close...
But that also depends on what is done to the engine. You need a 4" intake, 4 Bar MAP, JMF manifold with PI fuel kit, and fuel made of unicorn piss
Mazdaspeed6 -06
290 AWHP / K04
Easter Bunny (11-28-2015)
 Old 11-27-2015, 08:47 PM   #23
yeah i ordered it incorrectly so I'm talking to cp-e about trading it, worst case i have to sell it but I've bought so much shit (stand back wish i could send back years ago before the AP SMH) from them I'm going to be very angry if they don't let me trade it, n00b mistake but i am learning haha.
as far as everything else you listed, i am aware I'm going sp63 motor with all the bells and whistles, i know what i want short of turbo and clutch then i just have to stock pile the parts and put it all together
can i go garrett 40 housing or too big for the tight turbo location?
how far will the 35 get me, i would like to have some head room
 Old 11-27-2015, 08:53 PM   #24
seems like they make a 37 that is in the same housing as the 35 good for 8-900?
this seems like it should keep me happy for a long time, thoughts?
 Old 11-27-2015, 10:05 PM   #25
broda's Avatar
If you have a CPE manifold and you don't want a stock flange then you pretty much have to go for a Precision Turbo unless if you get a Tial hotside and get a downpipe custom made.
 Old 11-27-2015, 10:14 PM   #26
If you have a CPE manifold and you don't want a stock flange then you pretty much have to go for a Precison Turbo unless if you get a Tial hotside and get a downpipe custom made.
so if i want to go hta i have to sell the manifold and get one that is compatible?
i like how the cp-e manifold seems bullet proof...
so the real question is which turbo is better?
can i get to 700 whp or is this a pipe dream haha
 Old 11-28-2015, 10:22 AM   #27
Groans: 33
700 is only achievable if every component of your setup works perfectly with each other and flows a hell of a lot better than a Mazda flanged setup. With a GTX35 you could see somewhere around 550-600awhp on a 1.02 hotside. You need the PTE setup to get anywhere close to your goal, or a custom setup with a turbo that flows about the same
Mazdaspeed6 -06
290 AWHP / K04
 Old 11-28-2015, 03:06 PM   #28
yeah I've decided on the PTE 6466, thanks for the help guys
plus I'm going to add a 50 shot to spool the beast, hehehehehehehe
wish me luck
 Old 11-28-2015, 03:08 PM   #29
broda's Avatar
If you're going to get a 6466 I'd suggest donating and looking at the Gen 2 For Sale section. Cough cough hint hint.
@Putin 2.3T;
 Old 11-28-2015, 05:10 PM   #30
lol good looks
 Old 11-30-2015, 07:43 AM   #31
Realgib3's Avatar
Posts: 2,443   (View Stats)
1. I gotta get this outa the way and say you could not sound more like a troll.
2. you will not need nitrous to "Spool" a 6466. That turbo spools fast.
3. IDK why I even posted in this thread. I can't believe I'm that bored right now.
WetzMS3 likes this.
The Following 4 Users Say Thank You to Realgib3 For This Useful Post:
Easter Bunny (11-30-2015), MY DICK IS SMALL-beautfpowers@gmail.com (11-30-2015), speed3 britz (11-30-2015), WetzMS3 (11-30-2015)
 Old 11-30-2015, 07:48 AM   #32
it could always spool faster lmao, I'm not trolling i swear, just a little 50 shot hahahahah
seriously tho why wait till 4500 rpm when i could have more fun at 3500 rpms?
zmzmbm
 Old 11-30-2015, 08:19 AM   #33
This thread makes my head hurt.
If you want to build something like this, why not put the time into measuring things and doing some research yourself instead of hoping someone will just tell you what to do?
For what it's worth, 500hp is achievable on a stock flange exhaust manifold, someone earlier in the thread said it was not possible.
A PTE kit with a 6466 or 6262 will get you close if not past your 700hp goal. It has been done on a few cars already.
If you want to innovate, stop being lazy and do some work. If you want 700hp while being lazy, call Edge or Kozmic and get a PTE kit.
ItsNox likes this.
Easter Bunny (11-30-2015), Realgib3 (11-30-2015)
The Following User Says NO Thank You to WetzMS3 For This Un-useful Post:
 Old 11-30-2015, 08:24 AM   #34
Jarods7920's Avatar
Posts: 1,415   (View Stats)
You could run an s366 turbo.
The Following User Says Thank You to Jarods7920 For This Useful Post:
Mazdazilla6 (11-30-2015)
 Old 11-30-2015, 08:32 AM   #35
There are SOOO many turbos that can get you to 700. Seriously.
Go on the aftermarket flow rate list on here and see what fits your needs.
 Old 11-30-2015, 01:11 PM   #36
believe me i have been doing plenty of research, but this is a hobby/ learning process for me so I'm not afraid to be humble and ask for some guidance and then do some more research off the things people tell me so i can make an informed choice.
the 6466 seems like it will get me there no problem and the power band seems great for the tuning solutions we have right now.
as for me being lazy, as you can see by my fenders i clearly haven't taken the time to do anything original on my own because i am too lazy LOL
 Old 11-30-2015, 01:16 PM   #37
You are being lazy.
Compressor maps as well as frame dimensions for almost any turbo in existence can be found on the internet, if not on this very site. If you want to do something innovative, research comp maps, pick a turbo based on your desired power and spool, then go measure shit.
You aren't being humble and asking for specific help with a hard to resolve issue, you are being lazy and asking to be spoon-fed information that is readily available. Congrats on the fender flares.
Easter Bunny (11-30-2015), HawkeyeGeoff (12-01-2015), Realgib3 (11-30-2015), speed3 britz (12-01-2015)
 Old 11-30-2015, 01:19 PM   #38
You are being lazy.
suck my dick bro, I'm too lazy to jerk off...
The Following 2 Users Say NO Thank You to MY DICK IS SMALL-beautfpowers@gmail.com For This Un-useful Post:
 Old 11-30-2015, 01:21 PM   #39
Your fenders beg to differ.
Easter Bunny (11-30-2015), HawkeyeGeoff (12-01-2015), MY DICK IS SMALL-beautfpowers@gmail.com (11-30-2015)
 Old 12-01-2015, 12:35 PM   #40
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
Just for reference, I think on my setup the 35R could probably get closer to 660-700. I only run the thing at 32 psi. I made close to 600 during 80°F summer days.....BUT that being said, Precision or one of the giant Xona Rotors would be fantastic and a better option.
Silver 2007 Speed3 GT
The Following 3 Users Say Thank You to HawkeyeGeoff For This Useful Post:
MY DICK IS SMALL-beautfpowers@gmail.com (12-01-2015), SpeedRebirth (12-01-2015), WetzMS3 (12-01-2015)
Stock Mazdaspeed3 Decal Location UnknownSuperhero 2010 MS3 - How-To's 18 01-20-2012 03:30 PM
Aftermarket sub in stock location DocSean MazdaSpeed 3/6 - Car Audio & Electronics 7 11-20-2009 09:05 PM
Page generated in 0.57068 seconds with 34 queries
