Like Tree6Likes
 Old 08-19-2012, 02:09 PM   #121
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
gtx3076, my friend.
Tell me, how's the drone, if any, with the exhaust?
Zero drone that I have noticed. I would say considerably less drone than stock CBE.
I disagree. You have to be getting choked on the hotside, you should still be picking up flow by increasing boost since you are still well on the map. The GTX3076 has the same exact hotside you have now so I doubt it will help much.
Port the hotside, or T3 EWG manifold, v-band DP, and a larger hotside. Unfortunately the change to T3 is an expensive proposition.
Probably the only things I will pursue will be more preload (probably won't help) and potentially a catless DP...
I am very confident that I will gain ~50whp of massflow when the temps drop in the next few months...
The Following 2 Users Say Thank You to cld12pk2go For This Useful Post:
802MS3 (08-19-2012), Chimmike (08-19-2012)
 Old 08-19-2012, 02:11 PM   #122
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Oh, you'll definitely gain with the drop in temps/humidity. That's a battle I fight every year my friend. Hence my use of meth.
07 MS3
The original Genpoo Hater
 Old 08-19-2012, 02:49 PM   #123
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
I concur...zero drone at any RPM/gear...def doesn't have the 3K RPM 80MPH interstate drone anymore...that is traded for a loud idle...super loud cold start fast idle....medium loud to loud, hollow growl during acceleration up to ~3-3.5K then about the same as OE....all this observed from in cabin...no idea how it sounds to the rest of the world.
isn't the majority of the issue the backpressue in the EM raising the PR at the turbine and not the DP?
NJSPEED3 (08-19-2012)
Garrett 5 bolt t3 iwg turbine housing 06Speed6 MazdaSpeed 3/6 - Turbo Induction 0 11-03-2011 05:17 PM
HOW TO: Port turbine housing with IWG Chimmike MazdaSpeed 3/6 - Turbo Induction 2 08-12-2011 06:50 PM
.64 or .82 turbine housing? Jarods7920 MazdaSpeed 3/6 - Turbo Induction 12 05-02-2009 09:43 AM
Page generated in 0.25035 seconds with 23 queries
