(Thread Starter) | Not Ranked : 0 score I just found that even though my current Treadstone TR11 IC is much better from a delta T and delta P perspective, I am still not getting much (if any) additional massflow after replacing my CXRacing IC0035. I am guessing that my exhaust must be severely choked up, which means either the ATP GT30 0.55 A/R turbine housing or my stock CBE is a huge restriction. I am pretty much going to get a Cobb CBE in the near future, but I am just curious what other people have managed to make with the ATP turbine housing to get a feel of if it might be my main restriction or not... It would obviously not be cheap/easy to upgrade to another turbine housing as it would require a new EM/DP...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
| The Following 3 Users Say Thank You to cld12pk2go For This Useful Post: |
Groans: 433
| Not Ranked : 0 score What exhaust are you running? I've done 420whp (per vdyno) on the ATP IWG housing, and that's on stock CBE. Frankly, I think the ATP IWG housing will flow 500whp. I'm converting to EWG myself but welding the flapper, and I'll probably take a flap wheel to the inside of the ATP housing as best I can to port it out.
It is interesting that you are at approx the same power level as I am. Have you tried to push beyond 420whp?
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
| Not Ranked : 0 score my last actual dyno was 430whp with AWD but logs show i was making 15-20 more whp before i finally blew.
| The Following User Says Thank You to superskaterxes For This Useful Post: | Downmented (08-18-2012) |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| The Following 6 Users Say Thank You to NJSPEED3 For This Useful Post: | andrew88 (08-03-2012), atvfreek (08-03-2012), BigjohnB20 (08-03-2012), BlueStreak (08-08-2012), Bucker (08-03-2012), dturboman (08-05-2012) |
(Thread Starter) | Not Ranked : 0 score Where those number with the GT35 turbine housing or a GT30? What CBE?
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score Ditch the COBB CBE, buy CNT! Less than half the price..flows great..sounds great..
__________________ |
I need quiet, which only leaves Cobb and Racingbeat unless I am missing something and I do not like the Racingbeat design...
| The Following User Says Thank You to cld12pk2go For This Useful Post: | atvfreek (08-05-2012) |
Groans: 219
My CNT TBE catless isn't too loud actually..I mean when you get on it..any 3" exhaust is going to howl, but when I'm cruising it's pretty quiet and there is very little drone.
__________________ | |
| The Following User Says Thank You to helmetface For This Useful Post: | ak_spray (08-03-2012) |
(Thread Starter) | Not Ranked : 0 score Do you have a feel for the sound difference between the stock CBE and the CNT? I am mostly concerned about idle and low throttle (can't wake up the neighbors starting the car)...
![]() Join Date: Aug 2011 Location: Miami, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,355
Groans: 279
@atvfreek always said that even near 300whp it starts becoming a restriction. At 420 I'd say you have AT LEAST 20whp to gain from a true 3" exhaust. P.S. UR CBE Is the shit.
__________________ 2010 LSM Speed3 Bolted + Corn + Meth + ACT 6-Puck #BakeryTuned | |
| The Following User Says Thank You to Roddiy For This Useful Post: | atvfreek (08-03-2012) |
Groans: 219
After the exhaust settles in, it's going to be a little louder than stock, begging the size difference, but I truly don't feel it's "much" louder at low throttle and barely louder at idle. I park my car directly under a 3 family building, who's tenants have their windows open all night and I've not received one complaint in the ~10 or so months I've had my exhaust done up like so. I hang with some of them, those with kids and no one has said anything. So I can't think it's much worse. But again, the initial cold start is a bit vicious, afterwards it's reasonable, I feel. UR was what I was thinking of when we spoke of RacingBeat Cld12pack. It's a good sound, although I can't testify for it's idle and low throttle decibel rating.
__________________ Last edited by helmetface; 08-03-2012 at 12:34 PM. Reason: MSF Database - Automerged Doublepost | |
Groans: 279
I have the CBE though I have both cats on, its very low. I've also heard it on a Catless PU and at Idle it's pretty quiet, though it obviously gets real loud as soon as you step on it.
| The Following User Says Thank You to Roddiy For This Useful Post: | Payne Racing 67 (08-09-2012) |
![]() Join Date: Jan 2009 Location: Cleveland, OH
Rep Power: 3292 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,280
| Not Ranked : 0 score CBE is not a problem on a 3. Period. My last Vdyno with my ATP X76 was 463whp @27psi, stock em, stock catback and that peak whp was at redline, so nothing was choked up at all. Also, already made 440+ on my 6466 @18.5psi, stock catback as well. IMO, the turbo itself is the biggest restriction here... but I'm one of the only people on here who likes big turbos on these cars, so I know that won't be a populaar opinion. |
| The Following User Says Thank You to Realgib3 For This Useful Post: | Chimmike (08-03-2012) |
| Not Ranked : 0 score There are 2 ways to increased massflow: 1. Increase the VE of the motor by reducing pumping losses so that you flow more at the same pressure ratio - given the compressor can do it. 2. Increase the pressure ratio (ie boost). This requires to spin the turbine faster. This requires a larger pressure differential across the turbine. This requires less backpressure past the turbine and less pressure drop across the manifold ... or just more exhaust flow altogether. Are you maxing out WGDC? If not, you can spin it faster but make sure you compensate with cooling as the compressor is losing efficiency and introducing heat. If WGDC is maxed out I would look at either decreasing back pressure post or pre turbine. This will give you more WGDC headroom. If you're after increasing the VE of the motor and the compressor CAN flow more then I'd look at the largest pressure drops from intake to exhaust and I would look at how to increase air density before and after the compressor.
It would seem that the compressor side should be capable of ~500whp without too much issue from the map?
Groans: 433
Frankly from what I've gathered in research and other opinions, stock CBE is holding us back at 400+whp After reading realgib3, now I wonder. regardless, I'll fab up a 3" cat back after my motor build, if for nothing else than some nice sound. I would expect to see maybe 20whp from it though. Especially since by that time I'll be on aftermarket EM and EWG.
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. | |
| The Following User Says Thank You to Chimmike For This Useful Post: | Realgib3 (08-03-2012) |
I am currently maxing out my WGDC (10 PSI spring with max preload). However, I expected to get another 1-2 PSI of boost with the decrease in IC DP. Since this didn't happen, I am thinking the exhaust must be choked up... My BATs are under ambient so no issue with heat load.
![]() | | #19 | ![]() |
![]() Join Date: Nov 2010 Location: rockledge fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,125
| Not Ranked : 0 score IMO a custom dp with a $80 qtp cutout is better then a $800+ cbe, but that's just me. Tapatalking
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) ![]() |
![]() | | #20 | ![]() |
| The Following User Says Thank You to Lex For This Useful Post: | atvfreek (08-05-2012) |
![]() | | #21 | ![]() |
Groans: 433
![]() | | #22 | ![]() |
| Not Ranked : 0 score I dont understand why no one has done a 4"cbe yet. Before we all say thats going to to be too loud and what not I think some of the big turbo guys would really benefit going 4". Its easy power to be had just curious why no one has done it. If my car was going to be kept that was next on the list to free up some HP |
![]() | | #23 | ![]() |
Groans: 219
| Not Ranked : 0 score Just gunna leave this here... CNT RACING 07-08 Mazdaspeed 3 catback Exhaust (76mm piping) (stainless tips) For the non-fabbers You know what they say.."Less time Fabbin' - more time Fappin'"
__________________ Last edited by helmetface; 08-03-2012 at 01:38 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following 2 Users Say Thank You to helmetface For This Useful Post: | cld12pk2go (08-03-2012), EdgeAutosport.com (08-03-2012) |
![]() | | #24 | ![]() |
I have the 14 PSI WGA in my workshop as ATP sent me the wrong one initially, it is just a royal PITA to install it (will have to pretty much pull DP and unbolt turbo from EM...I might eventually give in and do it though...
I have been dithering on the CNT vs Cobb CBE for a few months thinking that if the CNT is too loud I can just add an additional straight through resonator to tone it down but mostly I think I would likely be better off with paying more for the known quantity in the quite Cobb CBE.
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | ||
![]() | | #25 | ![]() |
| Not Ranked : 0 score @helmetfail the funny thing is I found a "bucket style muffler" I was going to use on that setup lol |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | helmetface (08-03-2012) |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score Build it and they will come...lol
| The Following User Says Thank You to cld12pk2go For This Useful Post: | EdgeAutosport.com (08-03-2012) |
![]() | | #27 | ![]() |
Groans: 433
| Not Ranked : 0 score I've heard good things about the Vibrant cbe.
![]() | | #28 | ![]() |
| POWERED BY POLSKA ![]() Join Date: Apr 2010 Location: Eagle, WI
Rep Power: 389 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 948
Groans: 38
| Not Ranked : 0 score My .02- on just a bnr s3 I went from slight tire squeaking to traction loss on third gear datalogs changing only stock cbe to cnt cbe. I am single catted and really like my cnt cbe, I had to be talked into it because I was afraid it would sound ricey, It does not. Decently quiet at idle/low throttle, nice deep tone when on her. I have gotten a few good comments from american muscle guys that I know. Also for the cold starts, just tap the throttle right at start up and she just purrs a tiny bit heavier than normal idle.
__________________ BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB 25%E85FREEKPERMED |
| The Following 2 Users Say Thank You to themytb For This Useful Post: | atvfreek (08-05-2012), cld12pk2go (08-03-2012) |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score So my cheap side won out as I couldn't ignore $339 shipped. CNT CBE on order. If it is too loud, I will just hack in one of these: Vibrant Performance 1142 - Vibrant Performance Ultra-Quiet Resonators - Overview - SummitRacing.com Dynomax Performance 17267 - Walker Ultra Flo SS Mufflers - Overview - SummitRacing.com Hopefully, it arrives by next Friday so I can do more testing.
| The Following 6 Users Say Thank You to cld12pk2go For This Useful Post: | 86AmishMs3 (08-04-2012), atvfreek (08-05-2012), Black Metal (08-04-2012), Chimmike (08-04-2012), Lex (08-04-2012), lilred (08-05-2012) |
![]() | | #30 | ![]() |
![]() Join Date: Sep 2011 Location: Rockville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,554
Groans: 130
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score The vibrant ultra quiet resonator is no joke. Does exactly what it says. I have it on my 3" catback and a very nice deep tone to it while not that loud.
__________________ 06 Black Cherry Mica MS6 GT: Speed Perf6rmanc3 built motor, GT3076r EWG, ACT 6 puck Clutch kit, HTP 3.5" full intake, M2 downpipe, XS Power Exhaust Manifold, CP-E austenite 3" exhaust, Whiteline 24mm rear sway bar, Injector RX Cleaned injectors, JBR trilogy motor mounts, JBR EGR Block off plate, Ported and ceramic coated intake manifold, 3 bar MAP, 3 port EBCS, Cobb AP, CX racing piping with Treadstone TR8, CP-E SAFEseals, MD OCC, Step Colder spark plugs, Turbo XS RFL BOV, AT fp internals, CP-E rear diff mount, Turbine Tech Front rear diff mount, DSS 500hp rear drivers side axle, Wilwood 4 Pot Calipers, Team Dynamics 18"x8" Pro Race 1.2s +38, SPC front ball joints, H&R springs, Morimoto clear projector retrofits. |
| The Following User Says Thank You to Jh8909 For This Useful Post: | cld12pk2go (08-04-2012) |
![]() | | #31 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1904 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Not Ranked : 0 score I have a magnaflow hf 3in cat paired to my cs cbe and my car is very tame sounding. I love it and at wot it sounds like pure sex. Zlatans car with just catless long dp sounds louder than my car. I like mine being quiet under wot. I think the cs is one of the best options for this car at 80mm also. Ps. On the topic of whats the potential of the atp back half. I think 480-500whp is obtainable but with some porting/reshaping of where it bolts to the mani 525-550whp is doable. Ive seen the dyno graphs/matched with vd maps and traps to back it up. Pretty impressive for a bolt on turbo. Evo owners are hitting 600-650whp with atp bolt on turbos. good stuff
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
| The Following 2 Users Say Thank You to driver311 For This Useful Post: | 86AmishMs3 (08-04-2012), cld12pk2go (08-04-2012) |
![]() | | #32 | ![]() |
![]() Join Date: Jun 2011 Location: Parma, OH
Rep Power: 1009 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score Can't really beat the CNT even if it was $500...
__________________ Parting out car, 800whp motor with 4k miles on it, 6466 turbo kit... ect I also do diesel gear swaps hit me up for more info. |
![]() | | #33 | ![]() |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
| Not Ranked : 0 score I think kmac is atp hotside right? He's at like 500whp, then there's that tranny kissing guy, joel. He made nearly 500. Dturboman also made 500whp realm on VD. Me personally I'm keeping it conservative. 22-23psi. I know when I was stock turbo I saw a 4-6g/s improvement from just a catback. People love to say a catback does nothing...but every little bit will help. I like Eric's idea...but just make a 3.5" exhaust downpipe back. Did you port the turbine housing at all while you were doing the flapper. I definitely ported mine and i'm sure it helps some (that hump at the wastegate seemed like a restriction)....and I'm sure it helped create creep issues I was having in the beginning.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold |
![]() | | #34 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score IMO the biggest restriction is the .55 A/R housing but at your power levels that stock cbe is probably becoming an issue. I am excited to see results on TS setups with a fat A/R housings, .82 or bigger.Sshouldn't lose much spool going from .55 to .82 T3 divided and it should help the top end considerably.
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
![]() | | #35 | ![]() |
Sorry for the intrusion cld12pk. Good luck with your exhaust. Adjustable IWG Bracket - Short | |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | 86AmishMs3 (08-05-2012), Easter Bunny (08-05-2012) |
![]() | | #36 | ![]() |
http://www.mazdaspeedforum.org/forum/foru...1-build-94543/
It should be an interesting data point. I will probably be tempted to go T3 0.82 A/R turbine housing if the CBE doesn't seem to help, but honestly I don't think I can justify the cost of a new EM/turbine housing/DP/WG...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) Last edited by cld12pk2go; 08-05-2012 at 03:50 AM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #37 | ![]() |
| Not Ranked : 0 score I believe you will get a nice gain from the CBE. Especially if you have your wgdc maxed. Each car that I've tuned that was close to or above 300whp we needed to lower wgdc to maintain boost targets.
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
| The Following 2 Users Say Thank You to atvfreek For This Useful Post: | 86AmishMs3 (08-05-2012), rfinkle2 (08-05-2012) |
![]() | | #38 | ![]() |
![]() ![]() Join Date: Apr 2011 Location: Winston-Salem, NC
Rep Power: 3104 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,046
Groans: 221
__________________ EMWNM 2013 Beating Black women one 5.0 at a time... ![]() 2008 mazdaspeed 3 true red Tuned by Nishan , 33% E85, GTX3067r Boost?, Yeah I got some., Port and polish manifold, XS power Tubular Exhaust Manifold, Wiesco pistons, K1 rods, L19 head studs, ARP crank studs, Cobb three port EBCS, Forge BPV, CXRacing FMIC with TR8 core, cobb AP V2, EBC redstuff full, DBA 4000 rotors 6x6 slotted, HTP 3" full intake, JBR 88d rmm, JBR 80d pmm, JBR 80d tmm, CNT catted DP, Magnaflow CBE, KMD internals, Koni Yellows, Moog endlinks, Moog lower control arms, OZ ultraleggera 18x8, Mich Pilot Super Sports 235/40/18, Hotchkis RSB, NGK step colder plugs.![]() Build in progress. Track whore in the making. | |
![]() | | #39 | ![]() |
Groans: 433
I foresee some potential modification though when using on an ATP turbo. dunno.
| The Following User Says Thank You to Chimmike For This Useful Post: | rfinkle2 (08-05-2012) |
![]() | | #40 | ![]() |
![]() Join Date: Apr 2011 Location: Bucks county (bristol),pa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 663
dynosheet on 30+psi race fueland track vid on 26psi/93 octane because Haters gonna hate Last edited by dturboman; 08-05-2012 at 11:54 AM. Reason: MSF Database - Automerged Doublepost | ||
| Garrett 5 bolt t3 iwg turbine housing | 06Speed6 | MazdaSpeed 3/6 - Turbo Induction | 0 | 11-03-2011 05:17 PM |
| HOW TO: Port turbine housing with IWG | Chimmike | MazdaSpeed 3/6 - Turbo Induction | 2 | 08-12-2011 06:50 PM |
| .64 or .82 turbine housing? | Jarods7920 | MazdaSpeed 3/6 - Turbo Induction | 12 | 05-02-2009 09:43 AM |
