 Old 04-13-2011, 11:24 AM   #1
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Steps 1 should be fine. If you get spark blow out you can try gapping them a bit tighter, or upgrading to the HKS twin ignition, or a lot of BT guys are running the Kenne Belle Boost a Spark (BAS), which is like half the prices. It basically sends more juice to the coils when your under boost and they're running larger gaps.. some on stock plugs iirc. Kenne bell boost a spark
I forget if you're running upgraded injector seals, but that's something you should defeinitely look into if you haven't. They can leak, causing false knock, and eventually blow out and cause head damage. CPE makes em for $170 Injector seals
I'm doing my seals this weekend to prep... no funds for the BAS so I'm keeping my fingers crossed on the blowout! lol
Geneva Preview: Techart to debut 911 Turbo, Turbo S Haltech Automotive News 0 02-16-2010 03:20 PM
Turbo swap (cx-7 turbo for ms3 turbo on MS6) johnnyspeed6 MazdaSpeed 3/6 - Turbo Induction 9 09-19-2009 08:56 AM
First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo Haltech Automotive News 2 05-04-2009 06:48 PM
Page generated in 0.26347 seconds with 22 queries
