![]() Join Date: Nov 2009 Location: las vegas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 711
(Thread Starter) | Not Ranked : 0 score if it was you witch one would you get. and what rpm do these turbos start to spool? i really think the problem with people bending rods is that the stock turbo spools to soon in the rpm. thanks
__________________ T3 Steed Speed twinscroll manifold- GT35R- CPE HPFP- COBB AP- DO METH- PTP BSD/WIN- CPE FMIC 2.5 piping- Twin Gates- CorkSport Exhaust- Full Mounts |
| The Following User Says Thank You to mason For This Useful Post: | superskaterxes (03-29-2010) |
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,310
Groans: 102
| Not Ranked : 0 score this is part my delima as well. I may do a precision turbo too.
__________________ |
| Not Ranked : 0 score 2871=3000 3071=3500 76=4k 35r=4500 i love my 3076. its the best suited turbo for this displacement
![]() Join Date: Mar 2008 Location: In a house
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54
| Not Ranked : 0 score get which ever you can get for the cheapest, both are good and would probably spool just over 4k. in this video he is brake boosting but you can hear when the tires break loose and thats probably when he hits full boost. i think there are more 3076 guys. how much boost do you want to run on either turbo?
__________________ 7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance |
| The Following User Says Thank You to clos561 For This Useful Post: | AZSPEED3 (03-29-2010) |
![]() Join Date: May 2009 Location: Richmond VA
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score Go for the gt35. How much power are you going for? |
![]() Join Date: Apr 2009 Location: Great White North
Rep Power: 512 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,214
| Not Ranked : 0 score I think most people go with the 3076... Try out the GT35... ![]() Or be different: May have some fitment issues, but wait till boost kicks in....
__________________ Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio. |
| The Following 7 Users Say Thank You to -cj- For This Useful Post: | JohnMS3 (04-01-2010), kilik2 (04-25-2010), nighthawk358 (04-04-2010), RayRayBauder (05-19-2010), super_pablo_ (04-18-2010), TheNewGuy (05-31-2010), ZoomZoomPSSH (05-31-2010) |
| Banned ![]() ![]() Join Date: Jul 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 126
| Not Ranked : 0 score HTA 35r |
![]() Join Date: Mar 2008 Location: Virginia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 456
| Not Ranked : 0 score My GT2871r spools much earlier than 3000 with all my breather mods, though I honestly never boost below ~3500 or so anyway.
__________________ '06 Black Cherry Mica Speed6 Since 2-26-07 | 0-60: 3.87s | CPE CAI, SU MM, Synapse BPV, Magnaflow 2.5" CBE, MDS DashHawk, TWM SS Stage 1, TT Front MM, TT Rear Diff Mount, SU StiffDiff, Whiteline RSB, BC Coilovers, mrlilguy CDFP, CPE Catted DP, HKS Twin Power Ignition System, RAYS Gram Lights 57 Maximum Time Attack, CPE TIP, Denso 2Step Colder Spark Plugs, COBB Shifter Weight, SPC Ball Joints, VTCS, BS, & EGR Delete, VentPod w/VEI Boost Guage, Saikou Michi CC, Labonte ISG-S3 (not installed), GT2871r, DNP manifold, Tial 44mm EWG, Cobb AP, TT Liquid to Air Intercooler, DMH 3" exhaust cutout. |
| The Following User Says Thank You to Smoker6 For This Useful Post: | phillyb (03-30-2010) |
![]() Join Date: May 2009 Location: N Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 523
Groans: 77
| Not Ranked : 0 score it depends if u like lag. i got a 3071 coz i like the fact it spools @ ~3700-4000 and i only WOT around these rpms anyway with stock turbo. so i eliminated PT boost and i can cruise @ 15in.Hg easy.
__________________ 2008.5 MAZDASPEED3 GT TRUE RED ***GONE*** ![]() 2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19 |
| Not Ranked : 0 score this looks pretty cheap, they have a 3076 for basically the same price. cxracing.com: Ball Bearing GT35R GT35 Turbo Charger Turbocharger T3
| Lurkers
Posts: n/a
| Not Ranked : 0 score Well I was curious once. Was a nice low boost map.
![]() Join Date: Sep 2008 Location: Soledad, CA
Rep Power: 446 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 393
Groaned at 5 Times in 2 Posts
(Thread Starter) | Not Ranked : 0 score im looking for around 400 whp to start. but have the ability to hit 500 if i wanted. thats what im looking for?
![]() Join Date: Mar 2010 Location: Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 778
| Not Ranked : 0 score Hey Dizzin...how much power you making..your running stock internals correct?. |
Groans: 77
| Not Ranked : 0 score yeah stock internals. i'm getting a pro tune next week with meth @ 18psi then i'll find out how much power i'm making.
![]() Join Date: Feb 2010 Location: Peru, IN
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score this is the great question...how much horse do you think i would get out of my car...and the answer is...idk lol im still trying to figure it out...i want to get the gt35r but they r expensive and dont have the money right now since i kinda just went out and bought everything that is in my sig...so yea...lol
__________________ 2008.5 Mazdaspeed 3 GT...Fully Forged Block...Ported Heads...Wiseco Forged Pistons/Pauter Forged Rods...COBB SRI...COBB DP...COBB AP...PnP Fuel Pump Internals...Cometic Head Gasket...ARP Head Studs...Denso Iridium HR:8...StreetUnit Rear Motor Mount...ACT 6 Puck Sprung Clutch Kit...Aluminum Flywheel... |
![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score I have done quite a bit of reading up on this topic because I was having the same dilemma. I ended up going with the GT3076 for a few reasons. First of all It is a few hundred bucks cheaper and a tiny bit faster spooling than the GT35. The second reason is that the GT3076 is rated at around 500 crank horsepower at it's maximum output. I don't think I'll ever be in danger of seeing that much power unless some sort of breakthrough is made. |
![]() | | #19 | ![]() |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
![]() | | #20 | ![]() |
![]() Join Date: Jan 2010 Location: Rosemount, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 946
Groans: 53
Groaned at 31 Times in 22 Posts
![]() | | #21 | ![]() |
![]() Join Date: Jan 2009 Location: Bangor PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,426
Groans: 88
| Not Ranked : 0 score gt3076 by far
__________________ 1995 honda civic. 1.6L slow 2007 Kawasaki ZX10r |
![]() | | #22 | ![]() |
| Not Ranked : 0 score HTA35r |
![]() | | #23 | ![]() |
![]() Join Date: Aug 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 64
| Not Ranked : 0 score once i get the money im going 3071 just because with breather mods ive heard of it spooling around 3200rpm and producing enough power to max out the mzr engine. (right now at least)
__________________ Mazdaspeed6 I work stock evo's like its my job. I make yellow lights my Bitch. Mods: gt3076r |
![]() | | #24 | ![]() |
![]() Join Date: May 2010
Rep Power: 0 ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score Gt35 if you looking 400+ |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | Haltech | Automotive News | 0 | 02-16-2010 03:20 PM |
| Turbo swap (cx-7 turbo for ms3 turbo on MS6) | johnnyspeed6 | MazdaSpeed 3/6 - Turbo Induction | 9 | 09-19-2009 08:56 AM |
| First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo | Haltech | Automotive News | 2 | 05-04-2009 06:48 PM |
