Like Tree9Likes
  • 5 Post By WhiteWidow
  • 1 Post By kritz
  • 1 Post By dawgincustoms
  • 2 Post By WhiteWidow
 Old 11-17-2013, 09:18 PM   #1
WhiteWidow's Avatar
Posts: 44   (View Stats)
WhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud of
Groaned at 5 Times in 2 Posts
Default WhiteWidow BT Build
Whats going on guys. Lots may know me from MazdaSpeed Owners Group FB page. Well I finally was able to use a different paypal account to donate to here lol. So no more brownie for me Anyhow I have a build going on by dawgincustoms and Speed Perf6manc3 Shop. I have been around for quite some time but I'm just usually a reader on here. Anyhow here is a lil list of what is going on with my build currently.
Garrett GTX3076R EWG Tial Housing w 44mm Tial Wastegate Setup, Cobb V3, PTO Billet Caps, Stage 6 Custom Clutch, ACT Flywheel, Counterweight, Shifter Bushings, AutoExe Front Sway Bar & Whiteline Rear Sway Bar, KW V2 Coilovers, H11 MZR Headstuds, ARP Mainstuds, CPE Injector Seals, CPE Exhaust Manifold, EBCS Boost controller, 3 Gauges on Pillar, Juggernaut Front Diff Mount, Dreadnaught Rear Diff Brace, CPE Stage 2 RMM, AWR PMM TMM, 500hp Drive Shop Axles, CorkSport Front Strut Tower Bar, EGR Delete, Ptp HPFP Internals, Custom 4" Intake, 3Bar Map Sensor, Port n Polished Heads, Weisco Pistons Bored .020 Over, Manley H-Beam Rods, Port Injection Fuel Kit, CPE Oil and Coolant Lines, JBR Stage 2 Oil Catch Can, JMF V2 Intake Mani w Port Inj taps, Forge V1 BOV, Keyed Cranks, VCTS Delete, Relocated trunk battery, 160amp alternator, Denso v24s Plugs, FMIC, Custom 3" DP, Custom 3" exhaust out to rear, Stainless Clutch Line, Braided Brake Lines, Vented Oil Cap, Brass Shift Forks, Balance Shaft Delete, Clevite Rod & Main Bearings with some 18" x 7" Five Spoke Rims with P225/40/R18 Fierce Instinct Tires.
You might have also seen my car on Cobb Tunings website under Mazda Section here
MAZDA
Hopefully we can have this build done by New Years =D
WhiteWidow is offline   Reply With Quote
The Following 10 Users Say Thank You to WhiteWidow For This Useful Post:
Bolted6 (11-17-2013), dawgincustoms (11-17-2013), evolizzee (11-18-2013), Funkster777 (11-17-2013), helmetface (01-08-2014), hnda etr (01-28-2014), jm211 (11-18-2013), kritz (11-17-2013), mxlplx71 (11-17-2013), psychophyr (11-18-2013)
 Old 11-17-2013, 09:20 PM   #2
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
You're gay Nate, but welcome.
cocoanton likes this.
Nator is what it does.
The Following 5 Users Say Thank You to kritz For This Useful Post:
Esteban123toro (11-18-2013), hnda etr (01-28-2014), IanMacKenzie (11-17-2013), Micha (02-11-2014), WhiteWidow (11-17-2013)
 Old 11-17-2013, 09:23 PM   #3
WhiteWidow's Avatar
I need 100 kilos of meth Steven for my build. You got me bro?
 Old 11-17-2013, 09:24 PM   #4
mtosofsky's Avatar
Posts: 543   (View Stats)
mtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the world
Subbed for epic build thread. Welcome to the VIP side of things Nate!
2008 MS3 GT GTX//Relentless Customs//Voltron Approved//Nishan Tuned
mtosofsky is offline   Reply With Quote
The Following User Says Thank You to mtosofsky For This Useful Post:
 Old 11-17-2013, 09:24 PM   #5
kritz's Avatar
Groans: 95
Sent
 Old 11-17-2013, 09:27 PM   #6
dawgincustoms's Avatar
Posts: 243   (View Stats)
dawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the world
Yea this one is gonna be a beast. Car will be getting fully gutted pretty much so I can start with bare bone and wire in the fuel system, clean up stereo wiring, replace shift cables, clean up bad work by previous shops with gauges and that, tucking stuff in the bay as it comes together and making it extremely clean and work well.
WhiteWidow likes this.
dawgincustoms is offline   Reply With Quote
The Following 2 Users Say Thank You to dawgincustoms For This Useful Post:
Qwik6 (11-17-2013), WhiteWidow (11-17-2013)
 Old 11-17-2013, 09:50 PM   #7
Gay for Pay
Faggmeister's Avatar
Posts: 25   (View Stats)
Faggmeister will become famous soon enough
Groaned at 9 Times in 3 Posts
Subbed! Can't wait to see it all finished!
2006 Mazdaspeed 6
Snowflake White Pearl
Garrett GT3076, TiAl 44mm EWG, HTP 3.5" intake, CP-e turbo manifold, M2 DP, CPE single Cat-Back, Autotech HPFP, CX racing FMIC, TR11 Intercooler, TiAl QR BPV, NGK plugs 0.028, JBR OCC stage 2, BC coil-overs, JBR RMM, Whiteline RSB, SURE front and rear differential mounts, Cobb AccessPort, EVO x wheels, Yokohama ADVAN AD08 tires, NISHAN TUNED!
Faggmeister is offline   Reply With Quote
The Following User Says Thank You to Faggmeister For This Useful Post:
 Old 11-17-2013, 10:02 PM   #8
jgarmo's Avatar
Posts: 108   (View Stats)
jgarmo has a reputation beyond reputejgarmo has a reputation beyond reputejgarmo has a reputation beyond reputejgarmo has a reputation beyond reputejgarmo has a reputation beyond reputejgarmo has a reputation beyond reputejgarmo has a reputation beyond reputejgarmo has a reputation beyond reputejgarmo has a reputation beyond reputejgarmo has a reputation beyond reputejgarmo has a reputation beyond repute
this is purrrty dope! cant wait to see whats next
jgarmo is offline   Reply With Quote
The Following User Says Thank You to jgarmo For This Useful Post:
 Old 11-17-2013, 10:23 PM   #9
Hammology's Avatar
Posts: 540   (View Stats)
Groans: 36
subbed
Built motor
GTX3071
Meth
6th Port
The Following User Says Thank You to Hammology For This Useful Post:
 Old 01-28-2014, 12:08 PM   #10
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Originally Posted by Hammology View Post
subbed
Use the "Subscribe to thread" link... newb...
 Old 01-28-2014, 01:30 PM   #11
Hammology's Avatar
Groans: 36
nope
Built motor
GTX3071
Meth
6th Port
 Old 11-17-2013, 10:42 PM   #12
Matrix311's Avatar
Posts: 2,133   (View Stats)
solid man thats awesome! I'm just finishing my build. Very similar to yours and a few part differences. Whats your power goal?
The Following User Says Thank You to Matrix311 For This Useful Post:
 Old 11-17-2013, 11:24 PM   #13
WhiteWidow's Avatar
My goal is to shoot for 500 range give or take.
The Following User Says Thank You to WhiteWidow For This Useful Post:
 Old 11-18-2013, 01:11 AM   #14
GARRETHEXTREME's Avatar
Posts: 516   (View Stats)
GARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the world
damn, this would be a sick build! subbed to see the glorious result!
2008.5 Mazdaspeed3 GT
MODS:
ETS TMIC - Forge BPV - JBR Tru 3in Intake - JBR Boost/Bypass Hoses - Koni Yellows - Corksport CBE/Corksport Racepipe - Front Corksport FSB (Thanks Previous Owner) - JBR RSB - JBR STS/Heavy Weight Knob - Corksport Aluminum Skid Plate - JBR 88a RMM - Corksport LED Light Kit - Goodridge Braided SS Brake Lines - COBB AP - Corksport HPFP
Running on Freektune OTS+ Map
Possibly the first deaf MS3 owner here? hmmm...
GARRETHEXTREME is offline   Reply With Quote
The Following User Says Thank You to GARRETHEXTREME For This Useful Post:
WhiteWidow (11-18-2013)
 Old 11-18-2013, 07:38 AM   #15
greatdane68's Avatar
Posts: 456   (View Stats)
It's about damn time!!!
Subbed.
2010 Mazda Speed3
FREEKTUNED!
2003 Chevy S-10
2014 Toyota Camry
2011 Dodge Challenger R/T
1997 Geo Prizm
The Following User Says Thank You to greatdane68 For This Useful Post:
 Old 11-18-2013, 08:43 AM   #16
evolizzee's Avatar
Posts: 601   (View Stats)
evolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the world
Groaned at 17 Times in 6 Posts
Nice list of parts Nate! Looks like Ron's Speed shop is puttin in some serious work to the Speed.
2011 Blue Mica 50% E85
COBB: AP, DP, SRI, TIP, OCC // Blitz Steel Mesh Filter // SURE: RMM, Boost Tubes, Counter Weight, Shift Anchors, AGS Knob // JBR: Tranny Mount, Passenger Mount// PT-P: HPFP, Rail Valve // PCV Vent // Forge BPV V1 // ETS 3.5" TMIC // NGK IXs // EGR Delete // Resonator Delete // FoMoCo Gear Oil // Castrol Syn Power 5w-40 // Koni Yellows // H&R Sport Springs // SPC Camber Arms// Spec: Stage 3+ SR Clutch, 12lb Flywheel
13.2@113mph
evolizzee is offline   Reply With Quote
The Following 2 Users Say Thank You to evolizzee For This Useful Post:
dawgincustoms (11-18-2013), WhiteWidow (11-18-2013)
 Old 11-18-2013, 08:57 AM   #17
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
... still not a fan of the FSB.
Past Mazdas & Speeds
 Old 11-18-2013, 03:19 PM   #18
Esteban123toro's Avatar
Posts: 245   (View Stats)
Esteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the world
Groaned at 6 Times in 4 Posts
nice man
Esteban123toro is offline   Reply With Quote
The Following User Says Thank You to Esteban123toro For This Useful Post:
 Old 11-18-2013, 03:37 PM   #19
manila's Avatar
Posts: 1,767   (View Stats)
You have quite the list of mods.
Best of luck to you with this build!
'12 MS3 Black Mica w/ Tech
 Old 11-18-2013, 08:21 PM   #20
WhiteWidow's Avatar
Got a personal set of CP-E oil and coolant lines made for my Tial Housing EWG setup! You don't know how thankful I am for this!!! God made me wait on this build for a reason bc I needed to build it correctly lol =D No lie I have about 50k atm in my car plus I still have to spend more money. Engine at SP being built, brembo big brake set, and the KW V2 coilovers, and brass shift forks to pay for. If I had done this build any sooner I wouldn't be putting it together as nicely as I am this time around. All of you guys have been helping me day by day for a while now and I just want to thank everyone!
So here is a picture of my goodies that Rich is sending me this week!
 Old 11-19-2013, 05:59 PM   #21
WhiteWidow's Avatar
Just placed my order with Speed Perf6rmanc3 to have my engine sent to them this week! Thanks Anthony! Can't wait to see this sucker when it comes back!
 Old 11-19-2013, 06:08 PM   #22
hnda etr's Avatar
Groans: 90
MAZDA
So you're running multiple heads and cranks with your build?
Hammology (11-19-2013)
 Old 11-19-2013, 09:32 PM   #23
Hammology's Avatar
Groans: 36
I'll take a spare crank lol
Built motor
GTX3071
Meth
6th Port
WhiteWidow (11-20-2013)
 Old 11-19-2013, 06:44 PM   #24
WhiteWidow's Avatar
lol i'm just letting EdgeAuto deal with it. I didnt mean to make that plural on the crank either.
 Old 01-08-2014, 12:17 PM   #25
WhiteWidow's Avatar
Engine is still with SP63 right now at the machine shop. Going to go ahead and do some powder coating I think while it's there. While I've been waiting, I picked up some other items like KW V2s TR10 IC and the port injection fuel kit. Still deciding what colors I should powder coat though. I'm ready to see this thing in action as much as anyone else...
The Following 3 Users Say Thank You to WhiteWidow For This Useful Post:
Funkster777 (01-08-2014), Mistersix (02-15-2014), mxlplx71 (01-08-2014)
 Old 01-16-2014, 08:26 AM   #26
WhiteWidow's Avatar
Grabbed a couple more items. Turbine Tech diff mount. And that HTP 4" Powdercoated White intake. Plus here is a sneak peak at my port n polished "head". This is the only pic I got atm so can't complain about the quality =X
mxlplx71 (01-16-2014), pmartz16 (01-23-2014), SpeedRebirth (01-16-2014)
 Old 01-16-2014, 03:34 PM   #27
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
love those hogged out ports, makes me want to put my hand in there or sumthin
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
WhiteWidow (01-21-2014)
 Old 01-23-2014, 01:11 PM   #28
pmartz16's Avatar
Posts: 1,140   (View Stats)
Hope you get to make that intake look good. Sad I didn't get to use it. But glad I went with a top mount setup. Post engine bay pics when you get it installed! @WhiteWidow;
2014 Mz3 MG
The Following 2 Users Say Thank You to pmartz16 For This Useful Post:
jreiden1 (02-15-2014), WhiteWidow (01-30-2014)
 Old 02-11-2014, 06:58 PM   #29
WhiteWidow's Avatar
Here's my baby lookin all sexy n shit!!!! It's coming home soon as this weather clears up lol
greatdane68 and mxlplx71 like this.
The Following 2 Users Say Thank You to WhiteWidow For This Useful Post:
Funkster777 (02-26-2014), Mistersix (02-15-2014)
 Old 02-14-2014, 06:25 AM   #30
The motor for this one will be here the end of next week, then the madness can start. Have about 7 weeks will Epic Nator Meet which is my deadline for having this car completed, broke in and tuned. Also trying to get another full build done before then to. Stay tuned as progress will be coming real soon.
The Following 4 Users Say Thank You to dawgincustoms For This Useful Post:
BigBoostMS3 (02-14-2014), jreiden1 (02-15-2014), pmartz16 (02-14-2014), WhiteWidow (03-07-2014)
 Old 02-15-2014, 06:55 AM   #31
Mistersix's Avatar
Posts: 2,585   (View Stats)
So this is the speed 6 I see every time I fire up my ap?
The Following 2 Users Say Thank You to Mistersix For This Useful Post:
sho (02-15-2014), WhiteWidow (03-07-2014)
 Old 02-15-2014, 11:47 AM   #32
Yes it is.
The Following User Says Thank You to dawgincustoms For This Useful Post:
 Old 02-15-2014, 02:13 PM   #33
Mistersix's Avatar
Cool. Always been a fan of it's styling choice's.
The Following User Says Thank You to Mistersix For This Useful Post:
 Old 03-07-2014, 05:15 PM   #34
WhiteWidow's Avatar
Officially started Project Widow! If you guys would like to follow this build day to day. Join this group here! Dawgincustoms personal Business Group! https://www.facebook.com/groups/244178772415459/
Funkster777 (03-10-2014), ItsNox (03-11-2014)
Build me a BIG Turbo Build for MS3 NCspecV81 2010 MS3 - Big Turbo Builds 14 04-15-2013 02:16 PM
Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy Haltech Automotive News 0 09-02-2011 07:20 AM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 06:52 PM
Page generated in 0.54078 seconds with 38 queries
