Like Tree5Likes
  • 2 Post By Polish_Eagle
  • 1 Post By sharksinspace
  • 1 Post By MSMS3
  • 1 Post By Luke@corksport
 Old 01-22-2018, 11:44 AM   #1
Polish_Eagle's Avatar
Posts: 408   (View Stats)
Default BPV Failure
Just wanted to let others know about Corksports BPV and be cautious as the internal spring will fail. I contacted corksport regarding the spring failure and they will not cover the cost of replacement for this failure (the part just became 4 years old and out of warranty). If you read around regarding the BPV you'll see others have had failures too, so clearly it's a design or manufacturing flaw. Support said they would only be willing to sell me the spring, but that $10 spring now becomes $30 USD due to shipping to canada for a part that should never fail.
So those in Canada be warned and I'd recommend getting a different BPV that's more reliable and won't have a spring failure. Corksport has really slid in reliability and support. I had their coilovers and they failed, and now their BPV failed. Sad to see and I will probably avoid corksport now.
Edit:
Corksport called last night and said they will warranty the part. Thank you Corksport for doing the right thing.
Picture below.
The Following 6 Users Say Thank You to Polish_Eagle For This Useful Post:
Code Monkey (01-22-2018), Db09ms3 (01-22-2018), JSmith (01-26-2018), MSMS3 (01-26-2018), pwdunmore (01-22-2018), Vansquish (01-28-2018)
 Old 01-22-2018, 08:06 PM   #2
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
The original spring did have a habit of breaking, but they've since changed manufacturer and may also now be using a stronger material (still wavespring design) for greater durability. luckily, when i realized mine had popped, i was able to get a new one shipped out free of charge. sucks you've got to eat the cost for that hefty Canuckistan shipping fee.
Genpoo stuff
 Old 01-22-2018, 10:50 PM   #3
RazoE's Avatar
Posts: 181   (View Stats)
RazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond repute
How can you tell it's fucked? I've had two CS BPVs, both Non-dual port, my old one sounded normal, my new (to me) one noticeably blows off longer, and sounds like it's winding down (sounds amazing to be honest). No flutter though. Is this a sign it's gone belly up? I'd rather it work properly than to sound cool, which is why I replaced my forge.
-2008 Mazdaspeed3
Corksport Stage II SRI - boost tubes - Dual VTA BPV / CP-E TMIC / HKS 3" CBE / JBR shifter bushings - Reverse gate - Modified Raider air dam for TMIC / COBB cold air box - AP V3 / Autotech HPFP / Damond short shift plate / Optima yellow top / Mazdaspeed lowering springs and camber arms / Black Gen Pu wheels
RazoE is offline   Reply With Quote
 Old 01-23-2018, 05:09 AM   #4
Best way to tell is to open it up and check. The recommended maintenance time is every 6 months, so during your maintenance of the valve you can inspect the spring.
Also, a little update, Corksport called last night and said they will warranty the part. Thank you Corksport for doing the right thing.
sharksinspace and RazoE like this.
 Old 01-23-2018, 08:17 AM   #5
Groans: 126
@RazoE; Open it and check; mine was working perfectly even with the busted spring.
RazoE likes this.
Genpoo stuff
 Old 01-26-2018, 12:57 AM   #6
RazoE's Avatar
Thanks for the advice, guys. I ordered assembly grease, too, to service it while I have it apart. Hopefully everything goes well ��
-2008 Mazdaspeed3
 Old 01-26-2018, 07:19 AM   #7
MSMS3's Avatar
Posts: 2,830   (View Stats)
Frankly, you should consider picking up someone's spare stock BPV. It is an elegant dual diaphragm design that works flawlessly, holds boost well to higher levels than the K04 can safely achieve, and is extremely reliable.
I've run the stock BPV with my mods below for almost ten years now, dynoing 300/300 and 13.2 at 107-108 with my fail 60 ft. 60-100 mph is 6.0 seconds, enough to get me into the 12s, if I could launch worth a shit.
Db09ms3 likes this.
The Following 2 Users Say Thank You to MSMS3 For This Useful Post:
Db09ms3 (01-26-2018), dp3 (02-01-2018)
 Old 01-26-2018, 09:16 AM   #8
Db09ms3's Avatar
Posts: 536   (View Stats)
I fuckin' agree. No need to bi a bpv until the stocker starts crapping out or your goals are high as giraffe pussy.
 Old 01-26-2018, 11:12 AM   #9
Bingo's Avatar
Posts: 740   (View Stats)
Groaned at 9 Times in 7 Posts
Unless you're not talking about the OP, wouldn't running a 3076 call for an upgraded BPV? I guess I was under the impression that the stock BPV was only good until ~23 psi. I only want clarification since I'm seriously looking into a BT this summer and I'm factoring in the cost of a new BPV.
Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks.
Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A.
 Old 01-26-2018, 11:54 AM   #10
LenSpeed6's Avatar
Posts: 164   (View Stats)
LenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud of
Hmm, this is very interesting. I'm trying to set my car up to be capable of around 26 psi, dont know if I'm going to run that much but if a stock BOV will work that will save me some cash up front for a bit until I really want to upgrade.
BTW, what do you do to service the CS BOV? Just take apart and grease?
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts
To think... this is suppose to be my winter car... because,
'72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far
'12 1/2 Triumph Daytona 675R stock some how
'79 AMC Spirit AMX, 4.6L stroker I6
LenSpeed6 is offline   Reply With Quote
The Following User Says Thank You to LenSpeed6 For This Useful Post:
grobeforya (01-02-2019)
 Old 01-26-2018, 12:45 PM   #11
shamie's Avatar
Posts: 952   (View Stats)
Personally I'd upgrade the OEM BPV for anything more than 22psi. Anything up to that OEM works the best (but you won't get that ricer sound).
 Old 01-26-2018, 12:57 PM   #12
LenSpeed6's Avatar
Yeah the sound isn't what I'm looking for, more reliability and can hold pressure
06 Speed6
 Old 01-26-2018, 01:45 PM   #13
@LenSpeed6; I have a Synapse BPV, can post a proper for sale thread if you are interested.
 Old 01-26-2018, 02:40 PM   #14
MSMS3's Avatar
I didn't see OP's upgraded much larger turbo. I can't speak to whether the stock BPV could hold boost up in the 20's at higher rpm. I know several here are tuning for the K04 with boost in the 22-24 psi range at lower rpm, but those tunes taper back to 16-18 psi range at redline.
My tune has boost peaking at about 19 psi under load in the 3,500-4,000 range with taper above that. Stock BPV is as tight as a nun's pussy at those levels. So, honestly don't know about how it would work with the bigger turbo. Should be able to pick up one cheap to nothing and try. Wouldn't really hurt to try.
I see now that Corksport is going to honor the warranty and replace the spring free of charge, so alternative solutions may be moot. Maybe they still hang out here and saw the commotion. That's good of them.
 Old 01-28-2018, 10:27 AM   #15
Groans: 126
I wouldn't run stock on more than maybe 21psi (and that's still dependent on the unit, some just seem to work better than others), and definitely not on an upgraded turbo.
@LenSpeed6; to service the CS, just open it up and grease it. make sure that wavespring is still in one piece. don't overtorque the allenbolts on reassembly.
Genpoo stuff
 Old 01-28-2018, 11:58 AM   #16
RazoE's Avatar
Here's what I discovered during the lube process. It was from the very end of the spring, no biggie. Rest is in 1 piece. It also blows off noticeably quicker and quieter, which is good.
Also the reason I went CS is because the piston opening is much larger than the original and I figured the more air it moves the better. The opening is gigantic compared to the Forge's, which is why I swapped that one out.
-2008 Mazdaspeed3
 Old 02-01-2018, 09:34 AM   #17
Luke@corksport's Avatar
Posts: 120   (View Stats)
Luke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond reputeLuke@corksport has a reputation beyond repute
Just to clarify, OP was sent a new spring free of charge.
The stock BPV can hold boost pressure up to 23psi no problem. It's actually the fastest acting valve out of all the valves you can use.
Upgraded turbo's push a lot more air, so the minute you upgrade your turbo is when i would recommend upgrading your stock BPV.
Most people end up upgrading their stock BPV because they notice it starts leaking.
sharksinspace likes this.
Luke@corksport is offline   Reply With Quote
The Following 2 Users Say Thank You to Luke@corksport For This Useful Post:
Polish_Eagle (02-02-2018), sharksinspace (02-01-2018)
VVT Failure... MazdaSpeedster Mazdaspeed3/6 General Discussion 11 10-03-2017 05:51 PM
PCV Failure EvoFire MazdaSpeed 3 - Engine, Transmission & Driveline 20 06-04-2014 05:04 PM
SURE RMM Failure clowncar 2010 MS3 - Engine, Transmission & Driveline 141 05-14-2012 06:57 PM
Failure Dave092 Mazdaspeed3/6 General Discussion 18 05-06-2011 09:24 AM
WTF do I have to do to fix my RMM after PMM failure. Adam is so pro MazdaSpeed 3 - Engine, Transmission & Driveline 2 04-18-2009 08:23 PM
Page generated in 0.37994 seconds with 30 queries
