![]() Join Date: Apr 2012 Location: Los Angeles
Rep Power: 426 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 956
(Thread Starter) | Not Ranked : 0 score But the other night we had a "let's all do compression checks" night at our meet. I did not touch the valve except to disconnect the recirc & that other small vacuum hose to remove my TMIC. When done, I reconnected everything, and when I drove off the valve was fluttering. I attributed this to the fact that engine blow-by oil had kept it lubricated, but had had a chance to drain out enough while the TMIC was off. And so I figured it was due for service anyway. But now 5 removals off the car, disassembling , clean and re-lube, and reinstall it , and 2 types of grease later (first a very tacky Lucas Oil assembly lube (moly based), and now a white lithium grease) and the damn thing won't stop fluttering. I fully cleaned it each time before re-lubing. The wave spring seems to be in perfect shape, and the piston itself doesn't seem to have suffered any kind of scoring from friction. I called @CorkSport today and I believe it was Brandon that I spoke to. He had suggested a specific lubricant called Lubriplate 109. This company makes A LOT of different lubricants, but one called 109 is not one I could find, let alone find a place to purchase. Just to be clear, I have triple checked all hose clamps that were removed the other night, just to be sure it wasn't a leak issue, even though I was sure it wasn't as the car has no problem holding boost. But I am at a complete loss as to what to do to fix it, and from what I understand from researching on here, the valve flutter isn't something that is just annoying or unfortunate. It seems to be something that can cause problems in the realm of permanent damage, and obviously that's not something I need. I've been hesitant to use the first piston it came with since the revised one has never given me an ounce of grief till now, and I don't see why/how it would start to now. Anyway, didn't want to wait till Monday to try calling CS again so if someone out there has the knowledge and kindness to get me fixed up sooner, I certainly welcome any experienced input, whether from one of you guys (or gals) from @CorkSport or from you gear heads who have successfully troubleshot and fixed this issue in the past. Thanks for any helpful info ya'll! -Nut
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: Last edited by The Nut; 05-02-2015 at 01:30 PM. |
| Not Ranked : 0 score You have a prototype valve. Not production. Any issues would need to go directly to @CorkSport; since issues you are having may not relate to production units. You never know what final changes were made. |
| The Following User Says Thank You to Raider For This Useful Post: | The Nut (05-02-2015) |
![]() Join Date: Dec 2013 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
| Not Ranked : 0 score Have you checked other things such as the connections on the hoses going to the bpv and the hoses themselves for small cracks or such? I do not see how a mechanical part just being moved would cause a problem with it. It's not like it's a delicate piece. Did the vacuum port get bumped or bent during the tmic removal/install? Just throwing some ideas out there.
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
| The Following 2 Users Say Thank You to speedfreak44 For This Useful Post: | Nliiitend1 (05-03-2015), The Nut (05-02-2015) |
![]() Join Date: Jan 2015 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
Groaned at 26 Times in 14 Posts
| Not Ranked : 0 score Yea it diffinately sounds like a split vacuum hose. Try replacing the hose running from the im to the bpv, if its leaking it wont have enough vacuum pressure to hold the valve open, causing it to flutter as air pushes its way through. |
| The Following User Says Thank You to cam1391 For This Useful Post: | The Nut (05-02-2015) |
Many thanks to all 3 of you guys. I'll post how it goes when I'm done.
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: Last edited by The Nut; 05-02-2015 at 01:33 PM. | |
![]() Join Date: Jan 2010 Location: Lake Villa, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,503
| Not Ranked : 0 score Put the CS bpv on another local's car and see if it acts the same on that car. If so, leave your stock one on and send it back to CS.
__________________ Mazdaspeed 3 2010 w/ tech package - Celestial Blah Blah Blah 4/15/12 dynojet results: 305whp / 355 tq |
| The Following 2 Users Say Thank You to JTMS3 For This Useful Post: | Nliiitend1 (05-03-2015), WetzMS3 (05-04-2015) |
![]() Join Date: Jul 2010 Location: Rowland Heights, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 121
| Not Ranked : 0 score I believe they recommended lubriplate 105 |
| The Following User Says Thank You to cam1391 For This Useful Post: | The Nut (05-03-2015) |
(Thread Starter) | Not Ranked : 0 score Maybe I misunderstood him. But I'll be replacing the hose later today to hopefully fix the issue, if not to only eliminate that possibility.
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: |
(Thread Starter) | Not Ranked : 0 score Vacuum hose replaced, didn't fix problem.
| Approved MSF Vendor ![]() Join Date: Apr 2014
Rep Power: 137 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score How does the banjo bolt look on top of the bob. Some times those can get damaged and cause a leak, making the valve not operate correctly.
__________________ |
(Thread Starter) | Not Ranked : 0 score It looks absolutely fine, but I'll check it when I get home. It's the only part I haven't touched. Thanks for the heads up, I'll let you know how that goes.
![]() Join Date: Dec 2014 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 9
This seems odd for the BPV to randomly start having issues, but it's hard to say. Give us a call Monday morning so we can try to troubleshoot this issue together. Sorry for the inconvenience. FYI: This is Barett, one of the engineers at CS. I don't have an official user name/profile on MSF. -Barett | |
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: | |
(Thread Starter) | Not Ranked : 0 score Not the banjo bolt either. IDK what else to try. I'll hopefully be able to troubleshoot this with CS tomorrow.
| Not Ranked : 0 score Ill give you a call here in a little bit!
| The Following 3 Users Say Thank You to Brandon@corksport For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Shout out to @CorkSport for going above and beyond to fix my situation. You guys are the best!
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: Last edited by The Nut; 05-04-2015 at 10:21 PM. |
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) | |
| The Following User Says Thank You to JgamB For This Useful Post: | The Nut (05-04-2015) |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score They sure did.
| The Following User Says Thank You to The Nut For This Useful Post: | JgamB (05-04-2015) |
![]() | | #20 | ![]() |
| Not Ranked : 0 score Care to shed any light, just in case I experience anything similar?
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score You have a p.m.
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score So.... As it turns out, absolutely nothing wrong with the BPV, only it's idiot noob owner. Not entirely clear why it was never a problem having the vacuum hose routed beneath the cold pipe, but even though it wasn't pinched in any way, it was crimped at enough of an angle to keep it from flowing properly, and therefor causing the valve to flutter. When I had the same issue with the OEM one, I knew something else had to be up. @CorkSport really went above and beyond to help me right the situation, and I'd like to publicly apologize to everyone there that worked to help correct my situation by making me an offer that they did not have to. I hope to hear back from them soon as the ball is now in my court to right the headache I have given them. Thank you for putting up with me @CorkSport.
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: Last edited by The Nut; 05-05-2015 at 08:55 PM. |
| The Following 5 Users Say Thank You to The Nut For This Useful Post: | Awal (05-05-2015), JgamB (05-06-2015), JSmith (05-06-2015), mazdaspeedmyk (05-05-2015), monkey.bones.007 (05-05-2015) |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Why did you route it that way out of curiosity?
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score Just always have since the first time my OEM I.C. was taken off (Not by me). It was never a problem, so i just assumed that that was how it was supposed to go.
![]() | | #25 | ![]() |
| Not Ranked : 0 score Gotcha. Well fuck it at least the problem is fixed and yet again corksport goes above and beyond
| The Following User Says Thank You to speedfreak44 For This Useful Post: | The Nut (05-05-2015) |
![]() | | #26 | ![]() |
Good to here Jason! Ill see what's going on and give you a call in a bit.
__________________ | |
| Problem after problem: Running rich & Fuel cuts | wherewuat | 2010 MS3 - Troubleshoot/Diagnostics | 30 | 01-30-2014 02:13 PM |
| Problem with ATR | ms3blackmica | MazdaSpeed 3/6 - ECU Computer Tuning | 15 | 07-05-2013 01:12 AM |
| Did you have the same problem? | krammer | Appearance - SILVER | 0 | 06-22-2010 09:45 PM |
