Like Tree8Likes
 Old 06-16-2014, 02:01 PM   #41
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Clearly he was making fun...
But I've done pretty well any bolt on install there is for these cars and a few other cars and have pulled a couple motors in my day, but haven't ever been toying with the guts of the engine (yet).
That's why I said bolt IN. Not a typo just a failed sense of humor haha
 Old 06-16-2014, 02:16 PM   #42
rymanmazda's Avatar
Posts: 1,531   (View Stats)
Groans: 122
I want now!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
NOW!!!!!!!!!!!!!
Freektune: 400whp/387awtq
-Autocross Setup-
Other Rides:
 Old 06-16-2014, 04:15 PM   #43
Thanks, it's nice to see that the only typo in the whole white sheet and listing is "are/is" mixed up.
And where do you mean it should say additional parts? You mean where it has "Addition Parts List" I guess that would make sense.
The thanks button is on the right.
SpencerC (06-17-2014)
 Old 06-17-2014, 09:53 AM   #44
SpencerC's Avatar
Posts: 2,159   (View Stats)
I like that I had thanked most of your posts, and somehow missed that one.
Easter Bunny (06-17-2014)
 Old 06-17-2014, 09:54 AM   #45
Voltwings's Avatar
Posts: 3,713   (View Stats)
When will we see lift / duration specs vs stock cams?
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
Mauro_Penguin (06-17-2014), Vader (06-17-2014)
 Old 06-17-2014, 10:50 AM   #46
shadesofgray19's Avatar
Posts: 794   (View Stats)
Lift can be found in the white paper I did not see talk of duration though.
The Following 2 Users Say Thank You to shadesofgray19 For This Useful Post:
Easter Bunny (06-17-2014), Voltwings (06-17-2014)
 Old 06-17-2014, 11:13 AM   #47
Voltwings's Avatar
Thanks, i over looked that.
I was asking partially for performance, but partially for PTV clearance as well. Dont want to get too frisky trying to spool a big turbo and end up making some contact.
Past:
-Sold-
-Sold-
Current:
maisonvi (06-17-2014), Realgib3 (06-19-2014)
 Old 06-18-2014, 08:32 AM   #48
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Just a heads up about those instructions...They require the crank bolt to be replaced, but not the crank friction washers. We have seen, more than a few times, slipped timing when people didn't replace those friction washers.
Yes, it's more work, but what's a couple hours compared to a few thousand dollars in damage.
Thank @Scribbles for catching that.
Edit: There is also some evidence for the crank sprockets needing replaced, also. The friction washers create a depression in the sprockets, so when reused they don't get loaded the same.
@CorkSport;
Scribbles and Code Monkey like this.
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 5 Users Say Thank You to phate For This Useful Post:
Code Monkey (06-18-2014), Easter Bunny (06-19-2014), JSmith (06-18-2014), Scribbles (06-18-2014), Vader (06-18-2014)
 Old 06-18-2014, 09:10 AM   #49
Eth Fiend
phate's Avatar
Also no mention of measuring cam bearing clearances.
-06 MS6
Code Monkey (06-18-2014), mxlplx71 (06-18-2014), Scribbles (06-18-2014)
 Old 06-18-2014, 12:59 PM   #50
El Beaner's Avatar
Posts: 4,262   (View Stats)
Yep, lets file this under things I won't be doing to my car(but sevretly would love to do) lol.
SOLD 2012 LSM Tech - 11/17/17
 Old 07-23-2014, 05:47 AM   #51
forbidden doughnut's Avatar
Posts: 41   (View Stats)
forbidden doughnut is a glorious beacon of lightforbidden doughnut is a glorious beacon of lightforbidden doughnut is a glorious beacon of lightforbidden doughnut is a glorious beacon of lightforbidden doughnut is a glorious beacon of lightforbidden doughnut is a glorious beacon of light
Having just installed cams on a Ford Duratec 2.3... If your car has any kind of mileage on it, it makes a lot of sense to replace the cam/crank gears, timing chain, tensioners, chain guides, oil pump chain + guides + pump gear. It is also a really good idea to replace the cam gear bolts.
IMHO it does not make sense to put a new gear on an old chain as the original parts have already worn in to each other.
This would also be a great time to do valve springs if you have any inclination to do so.
And, I think this is probably more than an afternoon project...a weekend is more realistic.
forbidden doughnut is offline   Reply With Quote
The Following 2 Users Say Thank You to forbidden doughnut For This Useful Post:
calizoomzoom (07-23-2014), Voltwings (07-23-2014)
 Old 07-23-2014, 06:23 AM   #52
calizoomzoom's Avatar
Posts: 684   (View Stats)
calizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the world
Or 2 weekends, when you have to put stock ones back in due to recall...
And the 3rd weekend to put in revised cams...
calizoomzoom is offline   Reply With Quote
The Following 2 Users Say Thank You to calizoomzoom For This Useful Post:
alaskazero (07-23-2014), Voltwings (07-23-2014)
 Old 07-23-2014, 12:56 PM   #53
ALPINEST4RS's Avatar
Posts: 905   (View Stats)
Groaned at 8 Times in 3 Posts
Haha, did anybody read the FAQ's??
The Following User Says Thank You to ALPINEST4RS For This Useful Post:
 Old 07-23-2014, 01:04 PM   #54
Voltwings's Avatar
Do i need a tune for this?
Past:
-Sold-
-Sold-
Current:
PT-P regrind cams story -- need Web weld & regrind cams MazdaGaragePat MazdaSpeed 6 - Engine, Transmission & Driveline 30 08-10-2016 03:46 PM
Who knows what about cams? GLORIFIEDBOZO MazdaSpeed 3 - Engine, Transmission & Driveline 11 08-02-2012 02:25 AM
Cams Cams Cams.... blkspeed6 MazdaSpeed 6 - Engine, Transmission & Driveline 11 12-17-2010 08:10 PM
PTP or other CAMS SpeedSixxx MazdaSpeed 6 - Engine, Transmission & Driveline 2 11-27-2009 05:52 PM
cams for our MS6 MStempted MazdaSpeed 6 - Engine, Transmission & Driveline 12 06-27-2008 01:20 PM
Page generated in 0.35619 seconds with 31 queries
