![]() | | #121 | ![]() |
![]() Join Date: Oct 2009
Rep Power: 188 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 72
| Not Ranked : 0 score ![]() Before, sitting on the driveway: ![]() Spring removed, you can see the rusted parts from where the coils were making contact while blocking: ![]() After, sitting on the driveway: ![]() These springs ride MUCH better. There are no more noises that were previously chalked up to "because coilovers, bro". I can take a speed hump at 40 km/h with no horrendous bang like before and they are also, dare I say, comfortable ![]() Hopefully they'll see a shakedown at the track this Sunday. Thanks to CorkSport for getting in contact with Paul to help us in our endeavours at the track and in helping to better the products for the Mazdaspeed community. |
| The Following 8 Users Say Thank You to MajesticBlueNTO For This Useful Post: | bertrand_CX_7 (06-11-2013), Celestspeed3 (06-11-2013), cshunter (06-12-2013), grantmm (06-12-2013), kritz (06-11-2013), Mr Wilson (06-11-2013), ZetaDrift (06-12-2013) |
![]() | | #122 | ![]() |
![]() Join Date: Jul 2012 Location: Gresham, OR, USA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
Groaned at 5 Times in 1 Post
| Not Ranked : 0 score Any information on the rear springs? should those be replaced along with the fronts? and if so what measurements are they and what spring rate would be recommended? thanks for any help. |
| The Following 2 Users Say Thank You to Kyllo24 For This Useful Post: | bertrand_CX_7 (06-11-2013), kritz (06-11-2013) |
![]() | | #123 | ![]() |
![]() Join Date: Feb 2011 Location: Vaughan, Ontario, Canada
Rep Power: 1135 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 977
(Thread Starter) | Not Ranked : 0 score There is nothing "wrong" with the rear springs. I just don't prefer progressive springs. That being said I made up some aluminum adapters that allow me to run a 2.5" ID standard race spring like the ones I used in the front. Rates for the rear rear depend greatly on how you want the car to behave. The spring is also levered so he wheel rate is not as easy to figure out as the front. If you wanted to AutoX I'd say maybe 650lb springs to start. If you were on the track I'd suggest 400lb springs at start. If you were drag racing, I don't know, maybe 1000lb springs to keep the weight on the front wheels. You could also do that with shock tuning if that is available to you. Keep in mind the tires you use will also have an affection what spring rate is ideal for you. |
| The Following 6 Users Say Thank You to Celestspeed3 For This Useful Post: | cshunter (06-12-2013), grantmm (06-12-2013), Kyllo24 (06-11-2013), MarineMazda (06-11-2013), Nliiitend1 (06-12-2013) |
![]() | | #124 | ![]() |
![]() Join Date: Jun 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 176
Groaned at 8 Times in 5 Posts
Granted, mine needed new bushings which AST warrantied very easily, but that was after 2 years of all year, all weather driving.PS. When we took the coils off for the work, the early version Corksport Camber Plates looked amazing still! | |
| The Following 2 Users Say Thank You to grantmm For This Useful Post: | Celestspeed3 (06-12-2013), Nliiitend1 (06-12-2013) |
![]() | | #125 | ![]() |
| Not Ranked : 0 score I had a problem with this where the top of the sway bar end link hit the chassis and we just turned the end link attachment point out a little to solve it. I don't understand why they didn't make it where the endlink is attached to a moveable ring on the threaded portion of the strut body. Why do manufacturers weld it when this is supposed to be a track friendly suspension setup? |
| The Following 3 Users Say Thank You to grantmm For This Useful Post: |
![]() | | #126 | ![]() |
(Thread Starter) | Not Ranked : 0 score So the AST's had this problem as well? |
| The Following User Says Thank You to Celestspeed3 For This Useful Post: | grantmm (06-12-2013) |
![]() | | #127 | ![]() |
| Not Ranked : 0 score The end link problem was due to how Pete set it up. He had too large of a spacer on the top part of the end link to strut connection. Swapping the spacer to the bottom where the sway bar attaches and putting the short one up top along with twisting the connection point a little more towards the wheel straightened that right up. In case people are wondering what I'm referring to when I say threaded portion and where the endlink attaches to the strut: ![]() I really wish Corksport went with that design (the top left strut). I have that piece basically bottomed out and I do all of the corner balancing with the adjustable endlink. |
![]() | | #128 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm having trouble visualizing the spacer regarding the endlink fitment. Can you describe it again please. |
![]() | | #129 | ![]() |
| Not Ranked : 0 score I'm running around with the front sway bar detached for now, so getting a picture of the endlinks was pretty quick. Swap the two spacers top and bottom (The slightly longer one on top is supposed to be on the inside of the endlink not the wheel side, but I didn't feel like taking the extra 5 seconds to put it on that way for this picture) and you can see how the endlink moves further in towards the wheel well. ![]() That's what open endlinks look like when they've gone through 2 Salt Lake City winters. The eye parts are 15 dollars or so to replace, so it doesn't really matter. |
![]() | | #130 | ![]() |
(Thread Starter) | Not Ranked : 0 score Gotcha, thanks. |
![]() | | #131 | ![]() |
![]() Join Date: Nov 2010
Rep Power: 394 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,114
| Not Ranked : 0 score OK I think I found the spring spec I was looking for. But @MajesticBlueNTO and @Celestspeed3 didn't provide how they did set up the car height with the adjuster ring to get the car as lower and closest to the height, the original springs from this Kit. Can anyone of you guys who ran this Eilbach spring confirm the following: 1) What helper spring goes with this Eilback 2.5" spring? Is it what cames originally with the Corsport coilover kit? 2) How did you adjust the height to get the car's height lower than stock. Those are the 2 questions I'm trying to solve now. And I'm running out of time because the first events are starting already this coming weekend and I'll need to hit the alignment shop again after the install. To anyone who can give some heads up, please feel free to chime in so I can get the car ready for this racing season. Thanks
__________________ 2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII. Pending install: JB EGR block plate Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness. 2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system. | |
![]() | | #132 | ![]() |
| Not Ranked : 0 score Im using the same each spring and still using the cs helper spring. And what do you mean lower than stock? Sent from my SCH-I535 using Tapatalk
__________________ Richtuned on k04 92 oct. 280whp/335wtq Richtuned on 50/50 E85 300whp/350wtq AUTOTECH HPFP INTERNALSCorksport: Coilovers, Front endlinks, SS Brake lines, Rear sway bar, Downpipe, Racepipe, Exhaust hangers, Licence plate relocation kit JBR: 80 duro motor mount trilogy, Solid shifter bushings Cobb: XLE BPV, STS, FMIC Other: HTP 3" intake, autoexe rear toe bar,Moog rear endlinks, 3 Bar MAP sensor, Grimmspeed 3 port EBCS Ricer Mods: EVO X GSR wheels powdercoated gold, Valve cover powdercoated gold, Hawk hps brake pads, Stoptech slotted front and rear rotors, 15% Window tint, saikou michi OCC, DDM HIDS 5000K lows 3000k fogs, Rally armor mud flaps[SIGPIC][/SIGPIC] |
| The Following User Says Thank You to Kyllo24 For This Useful Post: | bertrand_CX_7 (02-03-2014) |
![]() | | #133 | ![]() |
| Not Ranked : 0 score So is this how you guys set up the helper springs with the Eilbach? Is the helper spring supposed to be all the way compressed, static, like in the pic below? This is what I'm trying to figure out. Thanks for your answer: ![]() So the original springs that comes with the corksport coilover kit drops the car lower than stock. I mean to get a similar car height achieved with the spring that come with this kit. Do you guys have more pics of the car, so I can see how low is the front on the car and also a pic of the front coilover like the one Paul posted with the Eilbach spring + helper spring? It'll be greatly appreciated. Thanks
__________________ 2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII. Pending install: JB EGR block plate Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness. 2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system. Last edited by bertrand_CX_7; 02-03-2014 at 10:10 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #134 | ![]() |
| Not Ranked : 0 score Helper springs are fully compressed at ride height. At some point in droop travel, they become uncompressed. They are supposed to touch the main spring at full droop to keep it seated. Adjust your perch to whatever ride height you feel like.
| The Following 2 Users Say Thank You to phate For This Useful Post: | bertrand_CX_7 (02-04-2014), Mauro_Penguin (02-04-2014) |
![]() | | #135 | ![]() |
| Not Ranked : 0 score Yes the helper spring is supposed to be collapsed. uploadfromtaptalk1391490642354.jpg Sent from my SCH-I535 using Tapatalk
![]() | | #136 | ![]() |
| Not Ranked : 0 score The reason I was so confused was because I got a 9K spring and the helper spring was all the way compressed. And there was no way it looked normal to me since the front of the car was way to high. Ii guess I'll drop the 9K spring and go with the Eilbach spring + helper spring. Hopefully this should solve the stability I'm trying to achieve on the front.
| The Following User Says Thank You to bertrand_CX_7 For This Useful Post: | phate (02-03-2014) |
![]() | | #137 | ![]() |
Edit: If it's a no name brand spring, the rate could be WAY off.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
| The Following User Says Thank You to phate For This Useful Post: | bertrand_CX_7 (02-03-2014) |
![]() | | #138 | ![]() |
What I did was trying to take out the helper spring to get the car to an acceptable height, since the front was way too high. But by doing this, the 9k spring was not being compressed when not install on the car. And when installed, the only way I could get some compression on the spring, was to set the adjuster ring pretty high. Therefore this will cause the car to be up very high once the car is of the jack.
__________________ 2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII. Pending install: JB EGR block plate Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness. 2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system. Last edited by bertrand_CX_7; 02-03-2014 at 10:50 PM. | |
![]() | | #139 | ![]() |
| Not Ranked : 0 score BTW, where to get those Eilbach springs? Thanks
![]() | | #140 | ![]() |
| Not Ranked : 0 score Good call. The shorter spring with helper is the only decent way to solve that. Calculating proper spring lengths isn't as simple as it sounds, lol. I think I've figured out what my 6 needs (finally, heh). Any Eibach vendor should be able to get them. I prefer MAP for most everything, but I'm sure Edge and the like have them, as well.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. Last edited by phate; 02-03-2014 at 10:54 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #141 | ![]() |
| Not Ranked : 0 score Can anyone confirm? This is what I got before installing the suspension on the car. Is the height on the adjuster ring about right?
![]() | | #142 | ![]() |
| Not Ranked : 0 score Looks about right to me. tapatalk sucks.
| The Following User Says Thank You to Kyllo24 For This Useful Post: | bertrand_CX_7 (02-07-2014) |
![]() | | #143 | ![]() |
| Not Ranked : 0 score Ok have the front struts in. Height is really close to what I got before. I'll adjust it first thing tomorrow morning before hitting the alignment shot. Thank you'll guys for the support & assistance.
![]() | | #144 | ![]() |
| Not Ranked : 0 score I can't find these on their website anymore. Did they get rid of them? tapatalk sucks.
![]() | | #145 | ![]() |
| Not Ranked : 0 score Give some feedback here. Car feels incredible balanced with the 500 Lbs spring. This is how it should be. I'm loving it it again...... On the top of it new clutch.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f500/corksport-146959/ | ||||
| Random MS3 Chat Thread - Page 179 | This thread | Refback | 06-05-2013 01:10 PM | |
| Bullsh*t thread - Page 728 - 2010-13 Mazda 3/Mazdaspeed 3 Forums | This thread | Pingback | 06-02-2013 09:13 AM | |
| CorkSport Announces Release of New CorkSport Stub Antenna | CorkSport | CorkSport | 5 | 10-03-2012 09:31 PM |
| CorkSport Product Release! CorkSport 2007-2009 Mazdaspeed 3 Front Mount Intercooler for SRI | CorkSport | CorkSport | 6 | 11-14-2011 03:15 PM |
| CorkSport Product Release! ? Introducing the New CorkSport Radiator Cap | CorkSport | CorkSport | 0 | 08-05-2011 06:30 PM |
| CorkSport Product Release! ? CorkSport Mazdaspeed 3 Lowering Springs Now Available | CorkSport | CorkSport | 0 | 08-05-2011 06:30 PM |
