Like Tree18Likes
 Old 02-13-2017, 10:04 AM   #81
Would it be possible to purchase blanks?
I just noticed you asked about the blanks almost a month late
We are not offering camshaft blanks for purchase.
Derrick
 Old 07-05-2017, 05:37 PM   #82
Bramma's Avatar
Posts: 56   (View Stats)
Bramma is a glorious beacon of lightBramma is a glorious beacon of lightBramma is a glorious beacon of lightBramma is a glorious beacon of lightBramma is a glorious beacon of lightBramma is a glorious beacon of light
Neutral  +1 score
Maybe I should have said parts, there are 5 scheduled to be released before July 2017 for the Mazdaspeed 3/6.
-Derrick
Not to revive an old thread but any word on these 5 new parts? It's July.
SpeedyTurd likes this.
2006 Titanium Gray MS6
__________________________________________________ ___
Mods:
CS Stage II SRI, CS RMM, Cobb AP V3, Sure Diff Mounts(both),
CS HPFP, CS TMIC, CS DP, CS RP, CS Dual VTA BPV, CS Lowering Springs
Quietly reading and learning...
Bramma is offline   Reply With Quote
 Old 07-05-2017, 06:24 PM   #83
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
2 weeks.
crapatalk it sucks for free
Bramma likes this.
 Old 07-05-2017, 06:42 PM   #84
2 weeks.
Probs
monkey.bones.007 likes this.
 Old 07-18-2017, 10:27 AM   #85
Bramma's Avatar
2 weeks.
Heard any updates?
Mods:
 Old 07-18-2017, 10:56 AM   #86
Heard any updates?
2 weeks.
KiwiFlavor likes this.
KiwiFlavor (07-18-2017)
 Old 07-18-2017, 12:38 PM   #87
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Yup, two weeks sounds about right.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 08-13-2017, 11:02 AM   #88
rbarnz's Avatar
Posts: 10   (View Stats)
rbarnz is an unknown quantity at this point
Subbed.
--2013 MS3-- 17x9 RPF1; CS Full 3.5" Intake; Autotech Internals; Grimspeed 3 Port; JBR SSP+CW; JBR Shifter Bushings; SP63 Breather; JBR OCC; DM OCC VTA; DM PCV Plate; DM Trilogy; ATP Turbo DP+RP (Catless); UR Catback w/ Cobb Hangers; JBR EGR Delete; JBR Hood Vent Insert; SSQV VTA; TR8 w/ JBR Under Route; CS HPSS Fuel Line; CS Adjustable Short Shifter; CS Interior Kit; CS IM & 72mm TB; DO DVC 30 w/ single D14 (50/50); CS Battery Box (ECU Relocate); CS Gauges (Triple A Pillar); BNRS4v3; Cobb IWG Bracket; CPE Exhaust Manifold; Tial MV-R 44mm Screamer; 3 Bar MAP; Cobb AP; STuned on E30
rbarnz is offline   Reply With Quote
 Old 08-13-2017, 01:26 PM   #89
Djohns's Avatar
Posts: 3,944   (View Stats)
Originally Posted by rbarnz View Post
Subbed.
For?
2010 black mica speed3
Soon:built motor
 Old 08-13-2017, 01:41 PM   #90
FSRRM's Avatar
Posts: 44   (View Stats)
FSRRM is just really niceFSRRM is just really niceFSRRM is just really niceFSRRM is just really nice
Well since I couldn't get any Corksport Cams I'll be testing the Kelford Stage 2 Cams https://www.kelfordcams.com/nz/camsh...shaft-set.html
We've made a monster out of the k04 by completely changing the internals similar to someone in the club here I recall until a bolt smash his turbo.
I actually blew my cylinder wall since the new k04 so it's getting sleeved, half inch studs (because IDGAF), XSPOWER Manifold, Kelford Stage 2 Cams, Manley H Rods, SpeedPerformance Pistons.
Yeah fuck K04 + Cams. Let's see
FSRRM is offline   Reply With Quote
 Old 08-13-2017, 02:33 PM   #91
zenit's Avatar
Posts: 1,364   (View Stats)
details on modified k04 and dyno/power figures for cam swap?
-feejay
-wetzel
 Old 08-13-2017, 02:38 PM   #92
FSRRM's Avatar
Just waiting for Nate to send me my rods and bearings to complete the build Once it's done out dyno should be fixed as well.
I will setup a live feed or something
 Old 08-13-2017, 03:04 PM   #93
zenit's Avatar
Cool. I'm not sure if you referred to me as the person with a modified K04, but your description does sound like me.
-feejay
-wetzel
 Old 08-13-2017, 05:23 PM   #94
FSRRM's Avatar
Nice yes probably you. I'm CTA which is Cyborg Tuning Alliance I'm on Facebook.
I have already been successful with getting excellent boost pressures and cooler bats but I blew the cylinder wall because I didn't get a downpipe and stock manifold
 Old 08-14-2017, 11:08 AM   #95
nindoja's Avatar
Posts: 2,395   (View Stats)
Uh, what? You blew a hole in a cylinder because you had restricted airflow on the exhaust side?
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 08-14-2017, 02:13 PM   #96
FSRRM's Avatar
See attached.
Too much boost, too much back pressure.
The famous cylinder 3 cracked. We all know the 3rd port on the exhaust manifold flows the most out of the 4 and is usually cylinder 3 that breaks out first.
So, stock downpipe and stock manifold is just plain stupid in my honest opinion. Expensive mistake but it's going to be fun when it's done.
 Old 08-14-2017, 02:54 PM   #97
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
who tuned you? how much boost?
Genpoo stuff
 Old 08-14-2017, 03:41 PM   #98
Djohns's Avatar
See attached.
Are those the SP Pistons?
Soon:built motor
 Old 08-14-2017, 04:25 PM   #99
FSRRM's Avatar
I did. I wanted to see how much the stock turbo could push and what limits are etc and I got 28psi on a stock turbo k04 and from then i been playing with 26psi with methanol and i have a good understanding now. I didn't want to Google it I wanted to figure out myself.
Every other car I tune is more stockish boost with high timing and more
I'm excited for sleeved
Yes they are SP
 Old 08-14-2017, 04:30 PM   #100
zenit's Avatar
You mean stock frame, modified k04, right?
I'm assuming you have a stock manifold, too.
-feejay
-wetzel
 Old 08-14-2017, 04:33 PM   #101
FSRRM's Avatar
No I got 28psi from a stock unmodified turbo.
The turbo did sound like it wanted to snap in half though, that's my thing, I like testing random maps too.
I've found a map to adjust the intake manifold runners as well but only on the Mazdaspeed 3 gen1 and Mazdaspeed 6. I want to further test this but I'm not 100% convinced yet to say yes it makes a difference. Our DYNO needs a new brake module so once it's replaced I'll be testing the new setup
 Old 08-14-2017, 04:39 PM   #102
zenit's Avatar
Can you explain, a map to adjust intake manifold runners?
-feejay
-wetzel
 Old 08-14-2017, 05:06 PM   #103
FSRRM's Avatar
The runners inside the intake manifold are controlled by a vacuum, when I get my car back I will be doing 2 tests.
1. DYNO testing it for power increase down low and up top, I know that less air flow down low helps with torque and opening helps for flow up top, BUT I will be doing a 0 throughout the rev range and 88.67 (Which is OPEN wide on the map)
2. Hooking up a vacuum gauge to see the changes reflected in the map
It's all very exciting actually, I also want to mess with a random map I found on the Mazdaspeed 6's, which could be the 4WD engagement since it's electronically controlled
 Old 08-14-2017, 07:17 PM   #104
Groans: 126
I'm just gonna go ahead and guess that the stupid high temps from pushing the k04 far too hard played a big role in cracking the cylinder.
Genpoo stuff
 Old 08-14-2017, 07:22 PM   #105
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
You've successfully added 14+ posts NOT related to the CS camshafts.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
The Following 2 Users Say Thank You to Fstrnyou For This Useful Post:
FSRRM (08-14-2017), KiwiFlavor (08-14-2017)
 Old 08-14-2017, 07:42 PM   #106
FSRRM's Avatar
I'll stop now. Thanks
 Old 08-14-2017, 10:53 PM   #107
Djohns's Avatar
But do create a different thread for this since I'm sure others, especially @zenit; have further questions for you.
Bexar likes this.
Soon:built motor
 Old 10-27-2017, 09:52 AM   #108
Ryan_Bennett's Avatar
Posts: 8   (View Stats)
Ryan_Bennett can only hope to improve
Groaned at 6 Times in 3 Posts
Any update on dyno videos or big turbo potential. HP gains? Highers revs?
Mazdaspeed 6
Built Block
Mild Head Port
Full Race Mani
Gen 2 GTX3076
Stock Intake Mani
480whp/440wtq
Ryan_Bennett is offline   Reply With Quote
Lets talk Camshafts CorkSport 2010 MS3 - Engine, Transmission & Driveline 118 12-03-2013 07:36 PM
camshafts who has them? b4n30n3 MazdaSpeed 3 - Engine, Transmission & Driveline 5 12-31-2011 05:34 PM
Cosworth camshafts jlefebvre123 MazdaSpeed 3 - Engine, Transmission & Driveline 9 06-28-2011 01:37 PM
Page generated in 0.51616 seconds with 33 queries
