 Old 07-15-2016, 04:44 PM   #1
lingljp's Avatar
Posts: 4   (View Stats)
lingljp will become famous soon enough
Default Corksport coilovers adjustmsnt
I just installed coilovers on my 3 and I can't seem to adjust the rears properly. I know I need to turn the adjuster until I'm at my desired height but when I do that, the plate with the Allen nuts just comes loose and doesn't change anything. Can anyone give more detailed instructions on how to adjust them properly?
lingljp is offline   Reply With Quote
 Old 07-15-2016, 05:49 PM   #2
With the car in the air use an allen wrench in the big bolt to raise and lower the rear. Use the nut on the big bolt to lock the adjuster in place when you get to the height you want.
-Derrick
Corksport Coilovers wake2011 CorkSport 12 06-28-2013 05:10 AM
Corksport coilovers install help 07TRMS3 MazdaSpeed 3/6 - Suspension & Brakes 15 03-07-2013 12:48 PM
Page generated in 0.23348 seconds with 21 queries
