 Old 03-05-2012, 03:19 PM   #41
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
There is no reason that it shouldn't be, but I've never had a set of Bilsteins in my hands that I could measure...
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 03-05-2012, 05:20 PM   #42
grantmm's Avatar
Posts: 826   (View Stats)
Groaned at 8 Times in 5 Posts
Just take them off and drive around for a few miles or a day. Easy. If the noise goes away then it's related to the sway bar setup.
 Old 03-07-2012, 01:04 PM   #43
Atomic41's Avatar
Posts: 1,174   (View Stats)
I'm thinking is my Hotchkis swaybar bushing that make this noise. I read a lot and I'm not alone. Does someone has this problem of noise with his hotchkis bushing ?
Is it normal ? I install them this winter ...
2008 MAZDASPEED3 Black
Stratified Tuned / Stage 2
 Old 03-07-2012, 05:50 PM   #44
Bob-o's Avatar
Posts: 1,312   (View Stats)
@Atomic41
I just did my bilsteins too, and i has the same clunk you have!
PS: That squeak you hear is my foot on the clutch. Wet shoes FTL
 Old 03-07-2012, 06:51 PM   #45
Atomic41's Avatar
Do you have an idea where it comes ?
But you don't have aftermarket sway bar and endlink like me ... you're on stock ?
 Old 03-07-2012, 07:59 PM   #46
Bob-o's Avatar
Yea stock sway bar and endlinks. I think it's just a matter of making sure everything is tightened down. They seem to back off their threads, so you've gotta make a point to batten it down.
I'm 99% sure its coming from my RSB, or rear endlinks. I'll tighten them down this weekend when i have time lol
 Old 03-08-2012, 06:09 AM   #47
Atomic41's Avatar
So for you ... the noise came from behind not like me.
 Old 03-08-2012, 06:28 AM   #48
Bob-o's Avatar
Ohh. Your's is coming from the front?
 Old 03-08-2012, 06:48 AM   #49
Atomic41's Avatar
Yep !
 Old 03-19-2012, 06:12 AM   #50
Atomic41's Avatar
I think I will change for other brand for my front endlink ... must I go back for stock one or Powergrid or Whiteline ?
Thanks to give me your impression
 Old 03-19-2012, 07:27 PM   #51
Atomic41's Avatar
Any suggestions ?
 Old 03-19-2012, 09:04 PM   #52
Nliiitend1's Avatar
You should be fine using OEM enlinks with your modest drop.
2008 MS3 GT
2016 MX-5 Club
 Old 03-20-2012, 12:01 PM   #53
Atomic41's Avatar
I reinstall the stock endlink and the noise was there again but very less than with the Corksport one.
But I don't able to work with a lift and my stock endlink weren't so tight so I think my problem is from the corksport endlink. So I think I will go with the powergrid.
WHat do you think about that ?
 Old 03-20-2012, 05:49 PM   #54
Nliiitend1's Avatar
You can get new OEMs for much less than Powergrids, and you don't really need the adjustability of the Powergrids, but it's your money...
2008 MS3 GT
2016 MX-5 Club
 Old 03-21-2012, 09:29 AM   #55
Atomic41's Avatar
What length of endlink do I need with my setup (bilstein b8 + eibach pro kit) ?
Shorter or longer than my oem endlink ...
 Old 03-21-2012, 10:27 AM   #56
Nliiitend1's Avatar
If anything, you'd want endlinks that are longer by the same amount that your static ride height changed from OEM, but again, OEM length shouldn't cause any problems.
2008 MS3 GT
2016 MX-5 Club
 Old 03-21-2012, 11:25 AM   #57
Atomic41's Avatar
So if eibach drop 0.8" (in front for pro kit). Maybe it will be good to pick endlink of 13" (average) of length
 Old 03-21-2012, 05:09 PM   #58
Atomic41's Avatar
can someone confirm ?
 Old 03-21-2012, 06:24 PM   #59
warlord's Avatar
Posts: 756   (View Stats)
warlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the world
Groaned at 60 Times in 18 Posts
Yes, if your dropped .8" in the front you want to use 12.8" front endlinks.
2018 Audi S6 Prestige. APR Tuned 575 AWHP (current)
2017 Audi A4 APR tuned 315 AWHP (sold)
2014 IS350 (sold)
2013 MS3 Stage2 E85 (sold)
2011 MS3 Stage2 (sold)
warlord is offline   Reply With Quote
 Old 03-21-2012, 08:14 PM   #60
Nliiitend1's Avatar
Unless of course that puts them into the top of the lower control arm (which will happen once the links get too long - of course I can't confirm that the setup you're suggesting will do this, but it's something you have to factor in)...
AGAIN, with the modest drop that the Eibach springs give you, there isn't any reason that the OEM links should cause you any problems...
2008 MS3 GT
2016 MX-5 Club
 Old 03-22-2012, 01:31 AM   #61
warlord's Avatar
Maximum length for genpu endinks is 13.5". After that they become too long and hit the LAC when the suspension is at full drop such as when doing a tire rotation. Been there done that when I had my other Mazda. So even if your dropped lower it's probably best to go no more than 13.25" and leave a bit of room. I found that on the Genpu the sway bar starts to bind/preload once you move it more than .5" from parallel to the ground. At .8" it's not really that tight but at 1.25" it's tight enough that it's interfering with how the front springs and sway are working. I know when I installed my Powergrids it lightened up initial turn in measurably. Didn't have to fight the car to do quick lane changes.
2014 IS350 (sold)
The Following 2 Users Say Thank You to warlord For This Useful Post:
Easter Bunny (03-12-2014), Nliiitend1 (03-22-2012)
 Old 03-23-2012, 11:16 AM   #62
Atomic41's Avatar
To measure the good length do I process like this :
I need to remove my wheel, remove the stock endlink, reinstall my wheel put the car on the ground. Go under and measure center to center the hole in the sway bar and the hole on the shock.
 Old 03-23-2012, 11:51 AM   #63
Atomic41's Avatar
Do I really need to go under my car to measure or just keep in mind that stock endlink is 12" and if I drop my speed with eibach pro kit average 1" lower. I will be fine with new 13" endlink length ?
 Old 03-23-2012, 12:50 PM   #64
warlord's Avatar
Yes to this. If your not going to put your car on blocks, sandbag the driver seat and go for exactly zero preload then close is good enough. Powergrid endlinks also have .5" adjustability so your covered from 12.75'-13.25" c-c. He even overthreads the adjusting rods so you can actually shorten them to 12.5" just in case your sway is warped slightly. Most are. Call Chip at Powergrid and he'll hook you up with the proper size adjusting rods. I believe he sells the rods in mm not inches so you should call him to make sure you get exactly what you need. I believe all the endlinks he sells are for 10mm bolt holes on the strut bracket and the swaybar ends. I'm assuming that's the size you need too. I hope this solves your problem and your not just blowing $150+ on something you don't need. GL.
2014 IS350 (sold)
 Old 03-26-2012, 12:29 PM   #65
Atomic41's Avatar
So you have Powergrid endlink on your speed3 ? Perfect product and build to tough ?
 Old 03-26-2012, 12:34 PM   #66
Atomic41's Avatar
Must I buy these (PowerGrid endlink for 172$ shipped) or OEM endlink (for 80$) ?
If you think I have bilstein B8 + Eibach pro kit
 Old 03-26-2012, 04:46 PM   #67
warlord's Avatar
Powergrid are a good product. You have a modest drop so the problem you have isn't that your endlinks are too short. I'd check that your front swaybar bushings are ok and also that the ends of you stock endlinks rotate freely.
2014 IS350 (sold)
The Following User Says Thank You to warlord For This Useful Post:
Nliiitend1 (03-26-2012)
 Old 03-26-2012, 05:06 PM   #68
Atomic41's Avatar
So I must keep my OEM endlink if I can ...
 Old 03-26-2012, 05:29 PM   #69
Nliiitend1's Avatar
Which I think I've said in several posts already in this very thread...
2008 MS3 GT
2016 MX-5 Club
The Following 4 Users Say Thank You to Nliiitend1 For This Useful Post:
breakfstincluded (03-11-2014), Easter Bunny (03-12-2014), rfinkle2 (03-02-2014), tddvrrn (04-02-2012)
 Old 03-26-2012, 05:31 PM   #70
Atomic41's Avatar
Which suspension setup do you drive ?
 Old 03-26-2012, 05:57 PM   #71
warlord's Avatar
I was on Swift springs. I'm now on Raceland coilovers. Not really feelin the Receland (too soft) so I'll be moving on to either H&R or KWv1 coilovers when funds allow.
2014 IS350 (sold)
 Old 03-26-2012, 06:30 PM   #72
Atomic41's Avatar
If you're me you will keep the oem or buy the pwergrid ???
 Old 03-26-2012, 07:10 PM   #73
Nliiitend1's Avatar
What does that have to do with anything? My recommendations have all been based on what YOU have, not what I have...
I am on Mazdaspeed Coilovers.
2008 MS3 GT
2016 MX-5 Club
Easter Bunny (03-12-2014), SLOWHATCH (04-29-2013)
 Old 03-26-2012, 08:28 PM   #74
warlord's Avatar
Keep the oem but make sure they are good. The ball joints on the ends should rotate freely.
2014 IS350 (sold)
 Old 03-27-2012, 06:30 AM   #75
Atomic41's Avatar
Thanks for your help guys.
Warlord and Nliiitend1
 Old 04-01-2012, 03:33 PM   #76
Atomic41's Avatar
So I'm now on oem endlink and I will see if everything is fine next day.
The noise is gone ! My oem are now FULL TIGHT without noise
 Old 03-11-2014, 08:04 PM   #77
Lurkers
need4zoom's Avatar
Posts: 15   (View Stats)
need4zoom is infamous around these partsneed4zoom is infamous around these partsneed4zoom is infamous around these partsneed4zoom is infamous around these partsneed4zoom is infamous around these partsneed4zoom is infamous around these partsneed4zoom is infamous around these partsneed4zoom is infamous around these partsneed4zoom is infamous around these partsneed4zoom is infamous around these partsneed4zoom is infamous around these parts
Groaned at 8 Times in 3 Posts
My OEM rear end links were making a lotta noise in my 07 speed3 at 80k. I got Corcksport end links and had a certified technician put 'em in legit. The noise was gone--for about a month or so and came back. I had a mechanic look at 'em and they failed.
Corcksport dose NOT stand by their product. I talked with them on the phone and they're pretty much like, "tough to be you"
At first, they were gonna send replacements but then went back on their word and no-go... just getting a refund. I do NOT recommend Corsksport at all.
I have ordered OEM rear end links and I anticipate that everything will be fine...I hope.
need4zoom is offline   Reply With Quote
 Old 03-11-2014, 09:13 PM   #78
Lurkers
need4zoom's Avatar
...and yours is the first reply and couldn't be more rude. wow.
I wrote about my experience with Corksport product and also the follow up with them...just shared it--how it happened. If they stood by their product and did well by me, or if their product actually worked, I'd be singin their praises.
 Old 03-11-2014, 09:26 PM   #79
Say Chi Sin Lo's Avatar
Posts: 872   (View Stats)
There are more civilized ways to express a negative experience, that's what the other poster was saying.
The Following User Says Thank You to Say Chi Sin Lo For This Useful Post:
Don06speed6 (03-11-2014)
 Old 03-11-2014, 09:29 PM   #80
Domino81's Avatar
Posts: 5,081   (View Stats)
And there are ways to respond like an adult. Post deleted.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
Nliiitend1 (03-12-2014)
Clunking Noise after H&R spring install Soffball 2010 MS3 - Suspension & Brakes 25 11-13-2011 09:15 PM
CEL, Clunking noise on shutdown etc DC2_2_MS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 06-26-2011 04:12 PM
Clunking noise Cool Whip MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 11-06-2009 12:18 PM
Clunking noise sleeping MazdaSpeed 3 - Engine, Transmission & Driveline 5 09-21-2009 06:20 AM
Clunking noise when stopping chisss MazdaSpeed 6 - Engine, Transmission & Driveline 2 01-19-2009 09:58 PM
Page generated in 0.58978 seconds with 28 queries
