 Old 07-02-2015, 05:00 PM   #1
Default The CorkSport Mazdaspeed Exhaust Manifold Heat Shield
We’ve got something your Mazdaspeed engine bay has been needing for a long time: Our new exhaust manifold heat shield—or as some folks like to call it: The Pimp Shield. A new heat shield, you ask? Isn’t that just aesthetic? Sure, you could stick with the OEM shield, but ours is manufactured from 5052 aluminum […]
More...
JgamB (07-02-2015), Kamaril (07-02-2015), littleloogy (07-03-2015), Raider (07-02-2015)
 Old 07-02-2015, 05:51 PM   #2
Kamaril's Avatar
Posts: 909   (View Stats)
Kamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the world
Groans: 77
Got this and the radiator cover on the way!
2011 MS3 BLACK MICA W/TECH PACKAGE
BNRSv3 - COBB 3 Port Boost Controller - BOSCH 3 Bar MAP Sensor - HTP 3" Intake (Candy Red)- CS Downpipe - CS LED Fog Lights - CS Interior LED Kit - CS Hood Strut Kit - COBB AccessPORT - JBR Adjustible Rear Sway Bar - JBR Solid Shifter Bushings - SURE Flow M3 W/ Res Delete - MangnaFlow 4x3.5" Stainless Exhaust Tips - AutoTech Internals - JBR 88a Dogbone RMM - H&R Lowering Springs - NGK Iridium Step Colder - Beachshoer's Pnp Intake Manifold W/ VTCS Delete - TurboSmart Plumb Black BPV - CX Racing FMIC - 18x8 Bronze MB Motoring Battles - Nitto Motivo 235/40/18 - Hawk HPS Brake Pads - Block8head Dual Gauge Pod - Prosport Evo Boost and Coolant Temp Gauges - Autodvdgps Touch Screen DVD Player W/ Navigation - CS Radiator Cover - CS Exhaust Manifold Cover - CS OCC
Stratified Tune In Progress
SCCA Member# 450495
Class - SMF
TRMotorsport C3 17x9 Hancook 255/245 RS-3
LIQUOR AND WHORES
Kamaril is offline   Reply With Quote
 Old 07-02-2015, 08:12 PM   #3
JgamB's Avatar
Posts: 2,566   (View Stats)
Nooo idea who called it the Pimp Shield, but that dude nailed it.
CorkSport (07-08-2015), Raider (07-02-2015)
 Old 07-02-2015, 10:28 PM   #4
you did. Pimp!
JgamB (07-03-2015)
CS exhaust manifold heat shield mxlplx71 CorkSport 27 06-26-2015 08:50 AM
Heat shield melting to manifold EL F00LI0 MazdaSpeed 3/6 - Turbo Induction 15 05-15-2011 03:27 PM
GI: Intake Manifold Heat Shield Gasket superskaterxes MazdaSpeed 3 - Engine, Transmission & Driveline 45 05-19-2009 06:37 PM
Page generated in 0.24723 seconds with 23 queries
