![]() Join Date: Jul 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 46 Times in 14 Posts
(Thread Starter) | Not Ranked : 0 score Greetings, I was under my car and saw one of the brackets from the RSB completely torn (the other one's faith will be similar, I'm sure). The RSB was installed approx. 2 years ago in 2014. Some rust is expected after a couple of winters but that's quite a surprise. Please check yours just in case! Anyone with similar issues?
__________________ 2017 Ford Focus RS - Stock 2004 MSM - AEM Intake - BEGI - FM Turboback - Turbosmart BPV - Hallman Boost Controller - ... "I'm a Turbo addict, I know." SCCA Philadelphia: (http://www.phillyscca.com/solo/) 2012 MS3 Silver w/ Tech Package - sold in '17 2009 WRX Stage 2- sold in '12 |
![]() Join Date: Sep 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,205
| Not Ranked : 0 score Brackets break all the time, it's no biggie. They're usually made by energy suspension and pretty flimsy TBH. Corksport could possibly replace them free of charge but they'll end up break again especially if you're seeing that kind of corrosion. I've gone through 2 sets myself with my JBR .125. You can get billet brackets if you don't want to deal with it again. Both JBR and corksport sell them. I personally bought these off of amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 They're cheaper than energy suspension replacements, a lot thicker and feel more sturdy overall. I think companies like JBR and Corksport should ditch those energy suspension brackets and switch to Prothane; they're better in my experience and fit our frames fine. The only downside is no grease fittings but I never used them anyway.
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines |
__________________ 2017 Ford Focus RS - Stock 2004 MSM - AEM Intake - BEGI - FM Turboback - Turbosmart BPV - Hallman Boost Controller - ... "I'm a Turbo addict, I know." SCCA Philadelphia: (http://www.phillyscca.com/solo/) 2012 MS3 Silver w/ Tech Package - sold in '17 2009 WRX Stage 2- sold in '12 | |
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
OP give us a call and talk to Vincent here to see what he can do for you. -Derrick | |
| The Following 4 Users Say Thank You to CorkSport For This Useful Post: |
![]() Join Date: Apr 2015 Location: Austin, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
| Not Ranked : 0 score Is the bar installed upside down? Mine has the sticker right side up and on the right side of the RSB. Nevermind, I just checked mine and the arms are the same angle. Difference is the sticker placement. Last edited by Silaramic; 10-12-2016 at 09:23 AM. Reason: MSF Database - Automerged Doublepost |
| classic neal.
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
![]() Join Date: Dec 2013 Location: Surprise, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 368
| Not Ranked : 0 score http://corksport.com/mazda-billet-sw...-brackets.html
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD |
![]() Join Date: Jul 2011 Location: Minnesota
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 219
| Not Ranked : 0 score Depending on how long you plan to own your car, you may want to look into the Hotchkis RSB Bracket. 4 winters and no issues on mine, and I only grease it about 3 times a year which is negligent. @Nliiitend1; also has not had issues with them I believe. Edit: I see Corksport now has a similar bracket to the Hotchkis |
| The Following User Says Thank You to smurugby12 For This Useful Post: | Nliiitend1 (10-13-2016) |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
| Not Ranked : 0 score Greasing a bar? Man, I've had my JBR bar on for over 3 years and haven't greased it but once. I also seem to be lucky in that I'm still on the original energy suspension brackets that haven't broken. I guess it's a benefit that I don't get that much rust down in the south.
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // |
(Thread Starter) | Not Ranked : 0 score Corksport worked with me and I got the new beefier billet brackets. Install completed, problem solved. Thank you CS.
| The Following 4 Users Say Thank You to moonrider_99 For This Useful Post: |
-Derrick | |
| The Following User Says Thank You to CorkSport For This Useful Post: | Mastermind46 (11-23-2016) |
| CorkSport Product Release! CorkSport 2007-2009 Mazdaspeed 3 Front Mount Intercooler for SRI | CorkSport | CorkSport | 6 | 11-14-2011 03:15 PM |
| CorkSport Product Release! ? CorkSport Mazdaspeed 3 Lowering Springs Now Available | CorkSport | CorkSport | 0 | 08-05-2011 06:30 PM |
| So Corksport sent ME a check today!!! | Novej | CorkSport | 0 | 04-04-2011 09:40 PM |
