 Old 11-08-2014, 01:31 AM   #1
sawdust777's Avatar
Posts: 11   (View Stats)
sawdust777 is a glorious beacon of lightsawdust777 is a glorious beacon of lightsawdust777 is a glorious beacon of lightsawdust777 is a glorious beacon of lightsawdust777 is a glorious beacon of light
Groaned at 8 Times in 2 Posts
Default CS downpipe fumes
2010 Speed3 CBE, DP, RJI, APT
After installing the CSDP, I am having exhaust fumes leak into the interior of the car. Ive checked all the joints and cant find any leaks. At least I cant hear, feel or see any. I have no idea where they might be coming from. With the AC on recycle the interior air I have no issues, but with defrost of vent on it gets bad really fast.
Anyone else have this issue ? Advice ?
sawdust777 is offline   Reply With Quote
 Old 11-08-2014, 02:13 AM   #2
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
I'm pretty sure that means there is an exhaust leak. Also if you deleted one or more of the cats that does not help the situation. Did you use a new gasket for the Downpipe to turbo?
 Old 11-08-2014, 02:36 AM   #3
roguemazda's Avatar
Posts: 159   (View Stats)
roguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud of
put some washing up liquid round the joints of the down pipe, it will start to bubble where the exhaust gas are escaping from
roguemazda is offline   Reply With Quote
 Old 11-08-2014, 02:46 AM   #4
roguemazda's Avatar
forgot to say car needs to be running when doing this
 Old 11-08-2014, 02:53 AM   #5
sawdust777's Avatar
JD - Yes front Cat removed. went with catless DP
 Old 11-08-2014, 04:00 AM   #6
MSP6's Avatar
Posts: 1,246   (View Stats)
Dude....use your brain. You replaced an exhaust piece and now you get bad fumes in the cabin immediately........its leaking....undo the connections and check your gaskets then reconnect.
The Following 5 Users Say Thank You to MSP6 For This Useful Post:
Code Monkey (11-09-2014), Easter Bunny (11-08-2014), He Hate Me (11-17-2014), JSmith (11-08-2014), nilashish (11-12-2014)
 Old 11-08-2014, 06:22 AM   #7
sawdust777's Avatar
Yeah , MSP6 I kinda knew it was leaking but there wasn't an obvious leak when I checked it in poor lighting setting. I will be sure to use my brain when I get it in my garage. And I'm pretty sure that I knew to check all of the connections too. You should be a mechanic / comedian full time. I was simply asking for the best place to start in case anyone had the same issue.
The Following 7 Users Say NO Thank You to sawdust777 For This Un-useful Post:
Easter Bunny (11-08-2014), faeker (11-08-2014), InkedInspector (11-09-2014), MazdaBoy2.3 (11-12-2014), nilashish (11-12-2014), Pointless (11-09-2014), Sploozel (11-11-2014)
 Old 11-08-2014, 06:32 AM   #8
MSP6's Avatar
I only meant to be half an asshole....
Leaks can be seriously bad without being visibly noticeable at all, even with the best of lighting. My downpipe had damn near backed itself off my turbo and the only reason I noticed was my AFR's went whacky.
I was pointing out that you hadn't done 30 things at one time. You removed and replaced 1 item, and now have an exhaust leak. Where do you think your culprit is?
Also....if you're to survive here you'll need thicker skin. That was a friendly tap on the noggin to try and make you stop, slow down and think.
The Following 7 Users Say Thank You to MSP6 For This Useful Post:
aromig (11-09-2014), InkedInspector (11-09-2014), mxlplx71 (11-13-2014), nilashish (11-12-2014), nojjy (11-08-2014), Pointless (11-09-2014), Sploozel (11-11-2014)
 Old 11-08-2014, 09:43 PM   #9
kidlifecrisis's Avatar
Posts: 672   (View Stats)
kidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the world
Also check to be sure you put the spring bolts in correctly and didn't bottom them out, the springs need a little gap to do their jobs.
Which cs dp is this? I have the one piece long dp (which I believe is discontinued) with 80mm outlet, I had some leakage when I still had the stock catback. Check the dp to midpipe and make sure the sizes match
kidlifecrisis is offline   Reply With Quote
 Old 11-09-2014, 10:15 AM   #10
F4LL3N's Avatar
Posts: 354   (View Stats)
F4LL3N is the leader of the worldF4LL3N is the leader of the worldF4LL3N is the leader of the worldF4LL3N is the leader of the worldF4LL3N is the leader of the worldF4LL3N is the leader of the worldF4LL3N is the leader of the worldF4LL3N is the leader of the worldF4LL3N is the leader of the worldF4LL3N is the leader of the worldF4LL3N is the leader of the world
Are you pulling any codes? Usually turbo to downpipe you'd have around 20% Long Term FT and pulling lean bank 1 codes. I ran straight out the downpipe at one point and my AFRs were fine. Smelled like shit, but racecar.
F4LL3N is offline   Reply With Quote
 Old 11-09-2014, 02:09 PM   #11
skoski17's Avatar
Posts: 1,235   (View Stats)
I did the same thing but deleted the cats and since doing this, I do smell fumes from time to time. I figured it was because of the delete.
Too much for you
skoski17 is offline   Reply With Quote
 Old 11-09-2014, 05:17 PM   #12
JgamB's Avatar
Posts: 2,566   (View Stats)
Unburnt hydrocarbons stink. If you're sitting still or in a garage, you're going to smell it if you're catless.
 Old 11-11-2014, 01:57 AM   #13
sawdust777's Avatar
Update: pulling no codes, small leak found bottom rear corner of turbo / downpipe gasket. and yes its the hardest one to get to. Going to replace the gasket and try again. For those who might at some point need to replace this gasket and find the $96 dealership price or even the $49 SU price a bit much, check out the Remflex RF18-020 for $22. It doesn't specifically list the car models but it looks exactly the same. I will know more tomorrow.
The Following 4 Users Say Thank You to sawdust777 For This Useful Post:
aromig (11-11-2014), Easter Bunny (11-12-2014), MSP6 (11-11-2014), Sergeant_M (11-11-2014)
 Old 11-11-2014, 07:01 AM   #14
I happen to be looking for that gasket as well and was shocked at the price, let us know if the one you found works
 Old 11-11-2014, 07:27 AM   #15
kornybun's Avatar
Posts: 119   (View Stats)
kornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the world
Remflex gaskets are the shit. I used one to seal up my Ebay dp to mid pipe. They are great for sealing uneven gaps. Didn't know they made one for the K04.
-kornybun
kornybun is offline   Reply With Quote
 Old 11-12-2014, 12:35 AM   #16
sawdust777's Avatar
The Remflex is the answer ! fits perfectly and seals easy with less torque. Tell the world.
And that fixed the leak at the downpipe / turbo.....but I found another leak that no gasket can fix. I am thinkimg that this new issue should be a new thread but essentially, the friggin CSDP was broken at a tig weld. I had to remove the whole pipe and have it mig welded. I have had great success with every product from Corksport up until now and I wont smear their name, but the tig weld on this particular pipe was kindy crappy.
Anyone know if the stock motor mounts are to blame for stressing the DP ?
Either way I'm up and running with NO LEAKS !
The Following 3 Users Say Thank You to sawdust777 For This Useful Post:
btstarcher (11-13-2014), Easter Bunny (11-12-2014), JgamB (11-12-2014)
 Old 11-12-2014, 07:08 AM   #17
LatinKraze's Avatar
Posts: 804   (View Stats)
I bought a used CS DP, it was cracked at the welds to the flange. Got it rewelded before install and it's been fine for 2.5 years but I'm fully mounted.
2016 CX-5 GT AWD
 Old 11-12-2014, 07:57 PM   #18
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
Did you buy new or used? Motor mounts or not it shouldn't cracked that quickly if new. It's good you got it figured out though, and thanks for the info on the gasket.
 Old 11-12-2014, 10:03 PM   #19
sawdust777's Avatar
No, I bought the pipe new and have had it on the car a while. No idea when the weld snapped but Im guessing probably around the same time I started smelling fumes, but then again the gasket was also fried. I ordered the CS motor mount inserts to head off any future stress to that pipe.
The Following User Says Thank You to sawdust777 For This Useful Post:
ASHMS3 (11-13-2014)
 Old 11-13-2014, 10:31 AM   #20
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Yes, that remflex piece is for our k04. I was working with them to have one made and they already has it in their catalog. They have drawings of our turbine flange and manifold flange also but didn't do anything with it yet.
Also should add that for exhaust leaks I built a tester similar to a boost leak tester that I slip over my exhaust tip. You can check for leaks on a cold car and won't burn your hands.
Soon to come.
WHO KNOWS? A.D.D. FTW!
Last edited by Turbo_Steve; 11-13-2014 at 10:31 AM. Reason: MSF Database - Automerged Doublepost
 Old 11-13-2014, 11:47 AM   #21
F4LL3N's Avatar
If you're doing the gasket, just slab the shit out of it with RTV and put it back on. $9 fix. My downpipe gasket has been through all sorts of shit, and it still holds.
 Old 11-13-2014, 04:58 PM   #22
SpencerC's Avatar
Posts: 2,159   (View Stats)
Glad you figured it out. I'm curious how long you have had the downpipe though.
 Old 11-13-2014, 11:00 PM   #23
sawdust777's Avatar
Spencer- had it on the car for about 1.5 yrs
SpencerC (11-14-2014)
 Old 11-14-2014, 12:14 PM   #24
SpencerC's Avatar
Hopefully you submitted a warranty form here: https://app.smartsheet.com/b/form?EQ...dfd91666d9c770
 Old 11-15-2014, 01:35 AM   #25
sawdust777's Avatar
Spencer,
I appreciate the link and I just sent the form in documenting my issues. I do not have much documentation of the original purchase date or install date ( there was a significant delay in installation). Not sure what can be done at this point and I am not overly concerned with it either. I just was surprised that your product was not perfect as they usually are. Worry not, I am a loyal customer of Corksport and I am not going anywhere anytime soon.
 Old 11-21-2014, 02:04 AM   #26
sawdust777's Avatar
Spencer,
CS has made everything right by me. I didnt intend to ask for, or really expect any gesture on their part but they went above and beyond. You guys have some of the best customer service I have ever seen ! BTW give Kelly at ext 103 a huge raise. She was fantastic !
 Old 11-24-2014, 08:15 PM   #27
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
I have this same issue CSDP. I keep the A/C fan on recirc. I haven't had the time nor the patience to get in there and find out where it is coming from. I don't think mine is cracked though.
Frequentflyer is offline   Reply With Quote
Report: World Health Organization says diesel fumes cause cancer Haltech Automotive News 0 06-13-2012 05:00 PM
Supplier fumes as carmakers take electric motors in-house Haltech Automotive News 0 06-21-2010 08:50 AM
If 100% Meth spalshed or fumes on the dp or mani could it ignite? gsrtype1 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 35 05-30-2009 07:31 PM
Nardelli: Chrysler is running on fumes Haltech Automotive News 0 11-23-2008 10:10 PM
Page generated in 0.47714 seconds with 34 queries
