 Old 08-08-2017, 07:35 PM   #1
Marcus's Avatar
Posts: 777   (View Stats)
Marcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the world
Default CS SSP with trans ssp?
Just wondering if you're ssp will work with a ssp already installed under the hood? Or do we revert back to oem.
Thanks yo.
2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km
Leakdown results was 50% or more across all four. slow rebuild in progress
Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses.
Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB.
SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate.
Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs.
To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters
Marcus is offline   Reply With Quote
Differences between a ms6 trans and a ms3 trans? alex_dewitt_ms3 MazdaSpeed 3 - Engine, Transmission & Driveline 6 07-28-2016 08:24 AM
Help me fix this trans... chuckms6 MazdaSpeed 6 - Engine, Transmission & Driveline 53 03-24-2013 01:47 PM
LSD in ms6 trans 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 11 08-08-2012 11:03 PM
New trans 06Speed6 Mazdaspeed3/6 General Discussion 42 05-27-2009 08:56 PM
Page generated in 0.23001 seconds with 21 queries
