![]() | | #121 | ![]() |
Groans: 111
| Not Ranked : 0 score It may be a bit too thin at 9 and 3 but that's not too bad either since I have pretty small hands. The flat bottom, the points where the sections meet and so on give you quite good points of reference while driving. The stitching imperfections (see a few posts above) luckily are not in any point of contact between the hands and the wheel, so I made peace with these imperfections as well. Overall it is definitely better than the OEM, even if it's not as perfectly stitched as the OEM. I rate it 8 out of 10 (the OEM being about 6 - good part, good finish, quality material, but totally unsuitable for a sport car model even if it's good for a regular 3). Good job @CorkSport! And thank you!
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI Last edited by mituc; 05-19-2015 at 02:22 AM. |
| The Following 4 Users Say Thank You to mituc For This Useful Post: |
![]() | | #122 | ![]() |
![]() Join Date: Sep 2013 Location: Vancouver, BC
Rep Power: 303 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,298
| Not Ranked : 0 score +1 on Pu wheel
__________________ All Go, No Show 2013 LSM W/ Tech CORKSPORTFull Race RMM CORKSPORTPMM CORKSPORTTMM CORKSPORTTMIC(temporarily uninstalled for Warranty BS) CORKSPORTECU RELOCATION BATTERY BOX(temporarily uninstalled for Warranty BS) CORKSPORTSSP CORKSPORTSHIFTER BUSHINGS CORKSPORT3.5" POWER SERIES SRI/TIP(temporarily uninstalled for Warranty BS) CORKSPORTBPV(temporarily uninstalled for Warranty BS) CORKSPORTRSB @ Full Stiff CORKSPORTMid Chassis Brace CORKSPORTHood Struts + decals for 20whp CORKSPORTLicense Plate Frames COBBAP v3 w/ Window Mount AUTOTECHHPFP INTERNALS ToBeInstalled: CORKSPORTFull Catless TBE, Rear Trunk Brace, Adjustable FELs, Cold Air Box (modified for 3.5") dbaDBA42962S Front and Rear Rotors StopTechRear Braided SS brake lines JBROCC & VTA OCC kit, EGR BO, Boost Tubes Cooling MistWMI kit StratifiedCustom Tune (as soon as TBE is on) On Deck wilwoodFastbrakes DP4front Caliper kit (w/ bp-10 pads and braided SS fr lines) Hawk PerformanceHB478F.605 or HB478Z.605 rear pads BilsteinB16s |
| The Following 2 Users Say Thank You to Awal For This Useful Post: | aromig (05-17-2015), my2k13speed3 (05-17-2015) |
![]() | | #123 | ![]() |
![]() Join Date: Aug 2011 Location: Fuckin Topeka, Kansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,200
CorkSport, I have cash to throw at you as soon as it's ready.
__________________ "I apologize for nothing!" - Hedonismbot ![]() Last edited by aromig; 05-22-2015 at 11:07 AM. | |
| MS3 steering wheel in MS6 | Mattsy | Mazdaspeed3/6 General Discussion | 4 | 06-23-2012 04:11 PM |
| Steering wheel TSB. | Demi | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 4 | 11-15-2008 04:03 PM |
