CS Turbo preload I am needing to adjust the preload on my CST4 turbo, while it's on the car. . . What is the easiest way to get at it, would it be from underneath the car or from the top? Thanks. |
I adjust mine from the top. You can get it done with two 10mm combo wrenches. If you don't mind me asking, why are you adjusting it? |
Sure, my tuner said it's not building enough PSIs and I need to increase the preload on the wastegate. |
My preload is factory set and I can get 28psi. What boost are you aiming for? Lol. |
Quote:
I'm getting 19.5 psi, looking for more than that. :tongue: |
Hell, my boost creeps to almost that with 0% WGDC. |
Quote:
Bump, did you get this resolved? I’m also having issues, I’m at 80%WGDC and only able to hit 24.5 psi. Checked 2 times for boost leaks, none found. I feel kinda odd adjusting the preload to be honest. I have a CS EBCS set up in bleed mode and CSt4 |
No not really, I adjusted preload. You can get to it feom the top of engine. I did find a small boost leak that helped some. |
Quote:
| All times are GMT -7. The time now is 08:39 PM. |
