![]() Join Date: Jan 2015 Location: Brisbane, Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 38
(Thread Starter) | Not Ranked : 0 score I've emptied it twice now as I've done nearly 1500KM and it let out a heap of oil and odd looking liquids so its clearly doing its job which I'm thankful of. But it was such a PITA to pull off the skid cover everytime then get oil all over myself while undoing the bung. Of course when I installed it, I was out of time to try and get the damned drain valve in, that and I didn't have a TORX bit to fit it. But I finally got around to doing it this afternoon, I managed to drain it, throw the new drain valve on it, and drill a hole through the skid cover so that the fitting pokes out, I also attatched a 2" length of the yellow PVC hose that comes with it so I can just throw a bottle under it and not worry at all, it is also installed in the recommended spot so I can reach my arm down from the top and turn the valve on/off. Here's a pic I thought I'd throw up so you know what I mean, It's probably been covered before, but its a refresher for those new people who are yet to install it ![]() IMG_3636.jpg ANNNDD! My 5HP each Decals! I had like 10 of these laying around, and after putting them all under my hood I decided I should display the name for all to see! haha IMG_3635.jpg
__________________ '12 Black Speed 3 CS RMM -~- CS SSP & Gearbox Bushings -~- CS OCC -~- CS LED light kit -~- CS Front and Rear Sway Bar -~- UnPlugged EGR Delete -~- CS Hood Struts -~- DVC30 WMI -~- JBR 3" Widepath -~- CS HPFP -~- GrimmSpeed 3 Port -~- HKS SSQV -~- CS TMIC -~- 500W Memphis Sub/Custom Wheel Well Box -~- 3" Xforce TBE -~- RayD Tuned |
| The Following User Says Thank You to Kor3y101 For This Useful Post: | slw97 (04-15-2015) |
| Keep your Engine Running Cleaner and Better with the CorkSport Aluminum Oil Catch Can and Drain Valve Kit | CorkSport | CorkSport | 24 | 08-31-2013 07:17 AM |
| oil continuing to drain into intake after occ and new pcv valve | Kydizzle | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 15 | 10-17-2012 07:21 PM |
| Fumoto valve vs. magnetic drain plug | pebenito | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 05-10-2010 07:51 PM |
| Source of Battery Drain, Tire Valve Cap, Replacing A Brake Light: Mike Allen's Weekly Online Auto Clinic | Haltech | Automotive News | 0 | 09-19-2008 02:30 PM |
