| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
(Thread Starter) | Not Ranked : 0 score More... |
| The Following 8 Users Say Thank You to CorkSport For This Useful Post: | Chev954 (07-02-2013), Code Monkey (07-02-2013), cshunter (07-07-2013), deekspeed (07-02-2013), evil MS3 (07-02-2013), Kamaril (07-02-2013), Mazdazilla6 (07-02-2013), ZetaDrift (07-03-2013) |
![]() Join Date: Jan 2011 Location: Lynn Haven/Niceville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 831
Groans: 77
| Not Ranked : 0 score the top of the knob is stamped with the gear pattern correct?
__________________ 2011 MS3 BLACK MICA W/TECH PACKAGE BNRSv3 - COBB 3 Port Boost Controller - BOSCH 3 Bar MAP Sensor - HTP 3" Intake (Candy Red)- CS Downpipe - CS LED Fog Lights - CS Interior LED Kit - CS Hood Strut Kit - COBB AccessPORT - JBR Adjustible Rear Sway Bar - JBR Solid Shifter Bushings - SURE Flow M3 W/ Res Delete - MangnaFlow 4x3.5" Stainless Exhaust Tips - AutoTech Internals - JBR 88a Dogbone RMM - H&R Lowering Springs - NGK Iridium Step Colder - Beachshoer's Pnp Intake Manifold W/ VTCS Delete - TurboSmart Plumb Black BPV - CX Racing FMIC - 18x8 Bronze MB Motoring Battles - Nitto Motivo 235/40/18 - Hawk HPS Brake Pads - Block8head Dual Gauge Pod - Prosport Evo Boost and Coolant Temp Gauges - Autodvdgps Touch Screen DVD Player W/ Navigation - CS Radiator Cover - CS Exhaust Manifold Cover - CS OCC Stratified Tune In Progress SCCA Member# 450495 Class - SMF TRMotorsport C3 17x9 Hancook 255/245 RS-3 LIQUOR AND WHORES |
![]() Join Date: Jul 2012 Location: Seminole, FL
Rep Power: 1270 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,116
Groans: 55
| Not Ranked : 0 score No
__________________ |
![]() Join Date: Apr 2012 Location: Barrie, Ontario, Canada
| Not Ranked : 0 score Has this mount been designed to clear your rear sway bar without adjustable end links?
__________________ [SIGPIC][/SIGPIC] 2007 Mazdaspeed 6 - Bolted, Methed, Tuned |
(Thread Starter) | Not Ranked : 0 score Works with all stock and aftermarket parts! |
| The Following 2 Users Say Thank You to CorkSport For This Useful Post: | Colin1337 (07-07-2013), SpeedRebirth (07-02-2013) |
![]() Join Date: Aug 2011 Location: woodbury,NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
Groaned at 27 Times in 13 Posts
| Not Ranked : 0 score was about to pull the trigger n buy, but saw that its not stamped with the gear pattern, so i'm debating
__________________ 06 Mazdaspeed 6 Precision 5858cea, PG turbo mani, 3" catless vband DP, 3" JBR intake, Cobb AP, Cobb EBCS 3 bar, TR8 intercooler, CPE 3" single exhaust/magnaflow muffler, NJSPEED P&P intake mani KMD internals, CPE safe seals, GFB turbo fuse, Turbosmart 50/50 JBR tranny mount, AWR dogbone, Turbine Tech front/rear diff mount, Whiteline Rsb, AWR rear adjustable endlinks, BC coils (suckie), OZ Ultraleggeras, waiting to install Devils own meth kit, ATVFREEK tuned! PS: Forever BT slow |
Groans: 55
| Not Ranked : 0 score Don't know where your gears are? A little tapa tapa taparoo...
| The Following User Says Thank You to evil MS3 For This Useful Post: | cshunter (07-03-2013) |
| Not Ranked : 0 score Nope! i like the look, i don't like it looking so empty, idk maybe it will grow on me
![]() Join Date: Nov 2011 Location: Clarksville, Tn
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,001
| Not Ranked : 0 score I like the fact that it does not show where the gears are, and that it retains the look of a OEM style knob.
__________________ 2013 CWP That's slow ![]() 2012 LSM Totaled by an asshole red light runner Previous: Freekbuilt & Freektuned 5858 (only made it to 93 tune )Previous: MILTUNED E85 K04 |
![]() Join Date: Sep 2011 Location: Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
| Not Ranked : 0 score Would be nice without the corksport stitching on it...very sleek. |
![]() Join Date: Jan 2013 Location: Tempe AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 898
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score I am really on the fence with the shift knob, looks great but stitching look like it will only last a couple months.. I assume there is a warranty on these.
__________________ TIP/AP-OTS-2/MS-SRI/JBR-88d-RMM/HPFP-Autotech/Ebay Downpipe/JBR-SP/Forged-BPV-v1.2/JBR-Boost-Tubes/WL-RSB/SPEC-CA/TWM-STS/JBR SB/TWM-Phantom-4in extension/Eibach-ProKit/Koni-Yellows/JBR-5mm-spacers/PCed-black-RX8s/Alpine-SWA-10S4/Alpine-M250/JBR-recirc-tube/DRAMA-E28-Tuned ![]() [SIGPIC][/SIGPIC] Sold 08 FJ Cruiser Expo build in progress... |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
| Not Ranked : 0 score Got the knob installed today. Feels great, the knob has a more natural feel to it. Not to heavy not to light. The stitching matches really well to the stock stitching on the boot. Looks way better then factory. Sent from my brain |
| The Following 4 Users Say Thank You to littleloogy For This Useful Post: |
![]() Join Date: Mar 2010 Location: BOCA RATON FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 524
Groaned at 60 Times in 18 Posts
| Not Ranked : 0 score Nice shape and color. CS should have used a different style stitching though.
__________________ 2018 Audi S6 Prestige. APR Tuned 575 AWHP (current) 2017 Audi A4 APR tuned 315 AWHP (sold) 2014 IS350 (sold) 2013 MS3 Stage2 E85 (sold) 2011 MS3 Stage2 (sold) |
| The Following User Says Thank You to warlord For This Useful Post: | littleloogy (07-05-2013) |
![]() Join Date: Mar 2011 Location: HACKNSACK, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 355
| Not Ranked : 0 score Damn damn damn good looking diff mount. I may have to swap out the sure and slap this sucker in and get a big ass Corksport vinyl. After the BBK kit me thinks.
__________________ Black Mica Mazdaspeed 6 [SIGPIC][/SIGPIC] NJSpeed P&P IM, KMD internals, SU TMIC, BNR STG 1, Sure V1 Aeros, Cobb TIP, Turbosmart BOV, Magnaflow CBE JBR Trilogy, Jugg & Dread, Corksport Strut tower brace & rear seat brace, Tein Super Street C/Os 18x8 OZ Ultraleggeras, 225/45/18 Dunlop SportMaxx, 17x8 Enkei SC03, 235/45/17 Bridgestone Blizzaks, Evo Brembo mod, StopTech rotors, Techna-Fit S/S brakelines, StopTech & EBC Greenstuff pads The Mad Scientist Tunings |
![]() Join Date: Jan 2010 Location: Queens'Nyc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 111
| Not Ranked : 0 score I been waiting for that diff mount.... Cant wait till i get paid
__________________ #3527. On genpus for winter >=) 5zigen Hyper 5ZR for summer Magnaflow CBE, CPE Catted DP, Corksport stage 2 SRI w/Corksport TIP, Turbosmart Dual Port BOV, 8000k HID Foglights,Block8head Vent pod w/52mm Prosport Boost Gauge, AWR RMM, AWR Passenger Side MM, JBR TMM, Bilstein HD Shocks Rear, Koni Sport Shocks Front, H&R Sport Springs, STI front lip, 35%Tint all around, Cobb AP, ACT 6 Puck Disc w/ ACT prolite Flywheel, Motul M300 Trans Fluid,PTP CDFP internals, Whiteline RSB, Corksport Rear Diff Mount, JDMGOODIE OEM Vent Visors, Mirimoto Mini HD Bixenon Projectors, ETS TMIC, Tuned by boost_creep ... Tune in progress 8) im on my way ![]() |
| The Following User Says Thank You to stuntz89 For This Useful Post: | memin (07-07-2013) |
![]() Join Date: Jun 2012 Location: Albuquerque, NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 981
| Not Ranked : 0 score Def going to get that dif mount in a couple months, especially since it works with any rsb Sent via banana
__________________ 2005 CTS-V KCCO 2006 Mazdaspeed6 SOLD COBB AP /|\ 3' Magnaflow CBE /|\ Autotech FPI /|\ COBB SF Intake /|\ NGK plugs /|\ RMM /|\ Megan springs /|\ GReddy RS BOV /|\ Strapped diff /|\ eGay catless DP /|\ BSD 'kit" /|\ PTP oil pan baffle /|\ Custom FMIC /|\ Spin on oil filter conversion 1995 Miata SOLD Tokiko Illumina Adjustables | FM springs | HardDog M2 rollbar w/Single diagonal | GV rep front lip | Flyin' Miata rear shock mounts. |
| Dual Product Release!! CorkSport Mazdaspeed 3 Passenger Side Motor Mount and Transmission Insert | CorkSport | CorkSport | 143 | 04-13-2016 12:00 AM |
| Product Release! ? CorkSport Adds Mazdaspeed 6 Rear Sway Bar to Product Line-Up | CorkSport | CorkSport | 47 | 04-22-2014 11:53 PM |
| CorkSport Mazdaspeed 3 Shifter Bushings and Mazdaspeed 3/6 Short Shift Plate Product Release! | Gwynne | CorkSport | 53 | 09-14-2013 07:51 PM |
| Double Product Release! CorkSport Mazdaspeed 3/Mazda 3 and Mazdaspeed 6 Rear Motor Mount | CorkSport | CorkSport | 30 | 04-19-2013 06:44 PM |
| CorkSport Product Release! CorkSport 2007-2009 Mazdaspeed 3 Front Mount Intercooler for SRI | CorkSport | CorkSport | 6 | 11-14-2011 03:15 PM |
