  • 1 Post By 08.5MS3
 Old 03-28-2015, 10:30 PM   #1
blake0521's Avatar
Posts: 302   (View Stats)
blake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud of
Default dual vs single exhaust
Was looking on your web site and it claims that the dual gets you 14 hp and the single gets you 10. Whats the reason behind this? You would think that the single would out flow the dual since there are less bends but i sounds like I am wrong.
I am getting into the 300's for whp and want to free up some extra power and get some better sound. I was leaning toward the single since it is much lighter and also cheaper but I am not sure. Thanks!
2010 Mazda Speed3-
Mods:
Cobb sri-Cobb tip-Cobb dp-Cobb bvp xle-Cobb ap v3-Cobb shift knob-AutoTech internals-JBR occ stage 2-JBR short shift plate-JBR solid shift bushings-JBR motor mounts (80 rear 70 side)-JBR TruTorsion 125 rear sway bar - JBR FMIC with crash bar and TR8 - Snow Performance meth kit with devils own fuel cell
Next up: tune.
blake0521 is offline   Reply With Quote
 Old 03-29-2015, 08:59 AM   #2
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Get the triple for maximum horsepowazzz.
dockinstation likes this.
The Following 10 Users Say Thank You to 08.5MS3 For This Useful Post:
Agent_Orange (03-29-2015), ASHMS3 (03-29-2015), dockinstation (03-30-2015), Easter Bunny (03-29-2015), Mr. T (03-29-2015), Pointless (03-30-2015), smoogs12 (03-29-2015), tegxsi (03-29-2015), WAMBUSHHHH! (03-30-2015), WA_MS6 (03-30-2015)
 Old 03-29-2015, 03:29 PM   #3
blake0521's Avatar
Thanks.... Real comments would be great. Found info one other sites mostly about evos and why most high powered build on that platform use single exit. They said it is for weight reduction and also has a marginal power increase. Wanted to know why the slight power increase does not ring true on our platform or if they just simply tested the dual exit with more mods. Right now still leaning toward single since it is cheaper, lighter and will allow me to spend that extra money on some more parts. Just confused why it is rated lower when it has the same tubing size and all that.
@CorkSport;
2010 Mazda Speed3-
Mods:
Next up: tune.
Last edited by blake0521; 03-29-2015 at 03:29 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-29-2015, 04:14 PM   #4
08.5MS3's Avatar
Groans: 89
It's a fucking pipe. End real comment.
The Following 2 Users Say Thank You to 08.5MS3 For This Useful Post:
Agent_Orange (03-29-2015), tegxsi (03-30-2015)
 Old 03-29-2015, 04:45 PM   #5
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
The single does weigh less, its louder. It also has a little more backpressure.
2 mufflers is quieter but flows a "little" more.
Go listen to soundclips on YouTube.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
Last edited by mxlplx71; 03-29-2015 at 04:45 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-29-2015, 07:13 PM   #6
blake0521's Avatar
Not too worried about sound just trying to figure out if its worth the extra cash to go dual or if single will be a good route. Just waiting on cork sport to respond back on if it does truly make less power for some reason or what. Seems weird that it would since evo's make more power with a single exit.
You would think that the extra bend to make it dual exit would be less efficient then a straight through design. I wouldn't think a single exit would have more back pressure since the route is straighter. Hints why I am asking cork sport the question.
and sorry if you think my question is dumb. I am curious so I thought I would ask. If you think it is dumb then don't comment. No one is making you read or respond to this thread. Think it is reasonable to ask since the data does not line up with the data from my other research.
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 03-29-2015, 07:49 PM   #7
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Two exits overcome the inefficiency caused by the extra bends.
It's 4 hp. The difference is negligible. May as well be 0.
The Following 5 Users Say Thank You to Agent_Orange For This Useful Post:
dev (03-29-2015), Drive By Fire (03-30-2015), Mauro_Penguin (03-30-2015), tegxsi (03-30-2015), WA_MS6 (03-30-2015)
 Old 03-29-2015, 08:24 PM   #8
dev
dev's Avatar
Posts: 325   (View Stats)
dev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the world
Wouldn't even register on the butt dyno.
Stock as Fuck
dev is offline   Reply With Quote
The Following User Says Thank You to dev For This Useful Post:
tegxsi (03-30-2015)
 Old 03-30-2015, 12:49 PM   #9
08.5MS3's Avatar
Groans: 89
There are a myriad of reasons why the HP numbers are different. But I'd venture to say that it is not statistically significant.
 Old 03-30-2015, 04:41 PM   #10
Castillo817's Avatar
Posts: 745   (View Stats)
I will be getting their single exit cbe since I myself have a single exit on my pu and it's amazing. Love the tone. And even with the dual and single exhaust, the numbers will not be significantly different
2013 VRM MS3
Ambit RE82 18x9.5 +38 255/35
-v8 swap in progress-
1994 Miata
-Sold-
-Sold-
The Following User Says Thank You to Castillo817 For This Useful Post:
blake0521 (03-31-2015)
 Old 03-31-2015, 10:29 PM   #11
blake0521's Avatar
think i will just save the weight and go single then. Already added a bunch of weight from mods so taking a few pounds off should help!
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 03-31-2015, 10:32 PM   #12
Yea man you won't regret it!
2013 VRM MS3
1994 Miata
-Sold-
-Sold-
 Old 03-31-2015, 10:56 PM   #13
razerer's Avatar
Posts: 168   (View Stats)
razerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond repute
Groaned at 8 Times in 4 Posts
Find a Mazda 3 bumper if you don't want an empty bumper cut out.. Just a thought
Cobb AP V3 // Cp-e HPFP // Cobb SRI TIP // Cobb DP // Cobb FMIC // Denso ITV22 // Cp-e Triton Cat-Back // Forge V2 BPV // JBR 88 Duro RMM
Cobb SoCal tuned
razerer is offline   Reply With Quote
 Old 04-01-2015, 03:14 PM   #14
Brandon@corksport's Avatar
Posts: 170   (View Stats)
Like others have said. The power difference is negligible if there is one at all. The majority of the exhaust comes out of the drivers side on ours any way because of the way it is plumbed.
If looks do not matter to you there really a need to go with the dual. Especially, when its gonna save you a chunk of change.
Cheers,
Brandon Johnson
CorkSport Mazda Performance
(360)260-2675 ext. 106
BrandonJ@corksport.com
The Following User Says Thank You to Brandon@corksport For This Useful Post:
Castillo817 (04-01-2015)
 Old 04-01-2015, 03:20 PM   #15
robander3's Avatar
Posts: 143   (View Stats)
robander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant future
I have also heard singles don't "drone" as much as double on the highway
08 MS3 DD (Sold)
06 Dodge Dakota, V6, 6 speed, 4x4
07 MS6 w/engine block VTA mod (currently going built block, etc)
robander3 is offline   Reply With Quote
 Old 04-01-2015, 03:31 PM   #16
SpencerC's Avatar
Posts: 2,159   (View Stats)
I would actually believe the single drones more, but that's just me.
Also, the power difference is negligible, probably just a difference in the dyno pull we did that day... consider the fact that we did them several years apart.
 Old 04-02-2015, 07:07 AM   #17
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
I am wondering how you decide that you have 300+hp when you don't even have a tune...
Just go with quad pipes, more space available for air to flow though, more hp.
AwAfrican (04-24-2015), Nel Mazdaspeed (04-04-2015)
Single exhaust on a pu nukepilot Gen2 MS3 General Discussion 73 02-20-2014 11:55 PM
Page generated in 0.37318 seconds with 30 queries
