 Old 02-26-2016, 12:30 PM   #1
Default Everything A Noob Should Know About Mazda Lowering Springs
Whether you want a lower center of gravity for better handling or you want to get rid of that ugly wheel well gap, lowering springs are a great buy. From hitting the track on the weekend to a spirited drive through the countryside, CorkSport lowering springs are the upgrade you’ve been looking for. By adding […]
More...
 Old 02-26-2016, 12:48 PM   #2
tagundnacht's Avatar
Posts: 4   (View Stats)
tagundnacht is an unknown quantity at this point
Do you recommend any shocks/struts to combine with your product? Or will these Springs bolt up to the stock shock/strut?
***Side note: this may be a super noob question, BUT I have only owned a speed3 for 3 weeks! *** Thats my excuse and i'm sticking to it! Thanks for the info!
tagundnacht is offline   Reply With Quote
 Old 02-26-2016, 04:55 PM   #3
Brandon@corksport's Avatar
Posts: 170   (View Stats)
We always recommend upgrading the shocks and struts. That is why we offer a kit for everything. That being said they will work with your factory setup.
Cheers,
Brandon Johnson
CorkSport Mazda Performance
(360)260-2675 ext. 106
BrandonJ@corksport.com
 Old 02-27-2016, 09:23 AM   #4
Thanks for the info.
 Old 02-27-2016, 11:22 AM   #5
FittedMazda's Avatar
Posts: 53   (View Stats)
FittedMazda is a glorious beacon of lightFittedMazda is a glorious beacon of lightFittedMazda is a glorious beacon of lightFittedMazda is a glorious beacon of lightFittedMazda is a glorious beacon of light
I'm very pleased with my CS springs on Koni Yellows. Have about 8K miles on them and they look great and give a nice drop without a harsh ride.
2010 MS3 -Black Mica- EBTEC Built Motor, ACT 6 Puck, CM Meth Kit, OBX Exhaust, GT2871, BSD, Coolant Bypass, AEM Failsafe, EGR Delete, CNT DP, HTP 3.5" Intake, JBR OCC, OZ Ultraleggera 18", and moar
FittedMazda is offline   Reply With Quote
 Old 03-10-2016, 04:01 PM   #6
Jrs7686's Avatar
Posts: 152   (View Stats)
Jrs7686 will become famous soon enoughJrs7686 will become famous soon enough
Same here, I love the Koni yellows with my Cobb Springs. Set the rears to mid and the fronts to plus 1 from mid. It is one of the best setups in my opinion. I might set the rears to 1 pus mid.... because semi racecar
Jrs7686 is offline   Reply With Quote
 Old 03-10-2016, 01:07 PM   #7
Shwaykid's Avatar
Posts: 646   (View Stats)
And if you want that tucked look, just put three people in your backseat...
Pardon my ugly ass stockers. Had to switch my rear wheels as my Motegi's were rubbing hard.
2008 Mazdaspeed3 GT
Jet Black Wax (06/24/2017)
 Old 03-18-2016, 03:41 AM   #8
DenverMazda2's Avatar
DenverMazda2 is an unknown quantity at this point
Another noob question for you: do I need the lowering springs with the 15-way adjustable shocks. My stock shocks are blown, i want the 15-ways, but not sure if I need the springs as well...?
DenverMazda2 is offline   Reply With Quote
 Old 03-18-2016, 05:10 AM   #9
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Springs are cheap and since you'll be under there already swapping out struts/shocks, just do both and be done with it. You will thank yourself as soon as you drive off.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 03-21-2016, 07:33 PM   #10
Default Sweet!
Thanks for the advice. Time to go order them. Im going with Corksport for both.
Product Release! CorkSport 2014+ Mazda 6 Lowering Springs CorkSport CorkSport 0 12-11-2013 01:10 PM
Dual Product Release!! CorkSport Performance Lowering Springs for Mazda 3 and Mazda 2 CorkSport CorkSport 2 04-09-2013 12:53 PM
Page generated in 0.29975 seconds with 27 queries
