 Old 11-17-2013, 08:48 PM   #1
Bigdaddypuff's Avatar
Posts: 161   (View Stats)
Bigdaddypuff has a reputation beyond reputeBigdaddypuff has a reputation beyond reputeBigdaddypuff has a reputation beyond reputeBigdaddypuff has a reputation beyond reputeBigdaddypuff has a reputation beyond reputeBigdaddypuff has a reputation beyond reputeBigdaddypuff has a reputation beyond reputeBigdaddypuff has a reputation beyond reputeBigdaddypuff has a reputation beyond reputeBigdaddypuff has a reputation beyond reputeBigdaddypuff has a reputation beyond repute
Default Front Camber Plates
Has anyone had any luck with them? I am looking for an aggressive look upfront. They are a little out of my price range but i wanna save up. If you have them let me know how they are! Thanks!
Bigdaddypuff is offline   Reply With Quote
 Old 11-17-2013, 08:50 PM   #2
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
What?
The Following 2 Users Say Thank You to helmetface For This Useful Post:
Mauro_Penguin (11-18-2013), phate (11-18-2013)
 Old 11-17-2013, 08:58 PM   #3
I was reading that sometimes after installing them people were having rattling noises. was curious if anyone had that problem with corksport ones before i go ahead and put money down on them.
 Old 11-17-2013, 08:58 PM   #4
Ryguy's Avatar
Posts: 546   (View Stats)
Ryguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the world
Whats the agressive look your're after?
Ryguy is offline   Reply With Quote
 Old 11-17-2013, 09:00 PM   #5
Maybe -2. Nothing to crazy.
 Old 11-17-2013, 09:04 PM   #6
2k4_8's Avatar
Posts: 684   (View Stats)
2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world
Groans: 64
Groaned at 18 Times in 6 Posts
It'll raise the car a bit so unles you're on coils keep that in mind.
COBB AP, CPE STAGE 2 RMM, CS SRI/TIP, AT HPFP INTERNALS, CNT CATTED DP, CP-E TRITON, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS
2k4_8 is offline   Reply With Quote
The Following User Says Thank You to 2k4_8 For This Useful Post:
Bigdaddypuff (11-17-2013)
 Old 11-17-2013, 09:06 PM   #7
Thanks for the heads up, ill keep that in mind.
 Old 11-17-2013, 09:08 PM   #8
2k4_8's Avatar
Groans: 64
It's not a ton iirc maybe .5 to .75 inch, but still
 Old 11-18-2013, 07:24 PM   #9
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
No clunking or rattling on my CS Camber Plates...
CorkSport (11-19-2013)
 Old 11-18-2013, 10:30 PM   #10
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
No clunking or rattling in mine either. However, because they are stiffer and have no rubber insulation as the factory ones do you will hear the suspension noises a bit more. But nothing too crazy or annoying.
If you will look at my list of mods you will see I also had ride comfort in mind (from the NVH perspective) and I can guarantee these camber plates will not affect the cabin comfort significantly.
I think the ride height increases with about 5-7mm.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Camber Plates Bigdaddypuff MazdaSpeed 3/6 - Suspension & Brakes 1 11-12-2013 07:32 PM
Front Camber/Caster Plates nicho1987 MazdaSpeed 3/6 - Suspension & Brakes 66 09-29-2011 05:34 AM
Page generated in 0.29760 seconds with 25 queries
