6Likes ![]() |
![]() Join Date: Jan 2015 Location: Lincoln, NE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 93
(Thread Starter) | Not Ranked : 0 score Thanks!
__________________ 07 Black Mica MS3: Built motor- SP63 Pro Series 88mm 9.5CR pistons, Manley H-beam rods, Clevite Main/Rod bearings, ARP main studs, L19 head studs, ACT 6-puck sprung clutch w/ Prolite Flywheel, AP V3, Stratified E85 tune/EBCS, NGK plugs, Autotech internals, Corksport injector seals/short shift plate/shifter bushings/LED kit, Cp-e FMIC/catless down pipe, Damond RMM/TMM, Mazdaspeed CBE, JBR SRI/TIP/recirc hose/BSD/oil pan baffle/EGR delete/51r battery box, Forge V2 BPV, Koni yellows, and Cobb springs, Gold Enkei RPF1 w/ 245/45/17 sport comp 2's |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP | |
Neither did Cp-e's though and some people have to use sealant. They instructions just say to slide them onto the injector and press down firmly.
__________________ 07 Black Mica MS3: Built motor- SP63 Pro Series 88mm 9.5CR pistons, Manley H-beam rods, Clevite Main/Rod bearings, ARP main studs, L19 head studs, ACT 6-puck sprung clutch w/ Prolite Flywheel, AP V3, Stratified E85 tune/EBCS, NGK plugs, Autotech internals, Corksport injector seals/short shift plate/shifter bushings/LED kit, Cp-e FMIC/catless down pipe, Damond RMM/TMM, Mazdaspeed CBE, JBR SRI/TIP/recirc hose/BSD/oil pan baffle/EGR delete/51r battery box, Forge V2 BPV, Koni yellows, and Cobb springs, Gold Enkei RPF1 w/ 245/45/17 sport comp 2's | |
Also, that sealant has caused a few people to nearly destroy heads trying to remove the seals down the road. I would not use sealant.
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
| Not Ranked : 0 score No sealant required, just make sure everything is clean before assembly or you may have a problem. Sent from my iPhone 6 |
| The Following User Says Thank You to littleloogy For This Useful Post: | WetzMS3 (10-01-2015) |
| Not Ranked : 0 score I just installed some Tokay V2 seals (same as Corksport) and I did not use any sealant. I used Corksports instructions during the installation process.
(Thread Starter) | Not Ranked : 0 score Thank you all! I do love the design of these seals way more than Cp-e's so I will trust them with no sealant. Plus I have the warranty from Corksport. And I'd rather save my head than destroy it.. Lol thanks again everyone!
| Approved MSF Vendor ![]() Join Date: May 2015
Rep Power: 93 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score No sealant needed. |
| Injector seal question!!! | nybe0010 | Gen2 MS3 General Discussion | 22 | 05-03-2013 03:26 PM |
| Rear main seal installation question. | MazdaSpeedSix | MazdaSpeed 3 - Engine, Transmission & Driveline | 1 | 11-19-2012 07:54 AM |
| Injector seal how to ?? | jracer | Mazdaspeed3/6 General Discussion | 1 | 11-26-2010 03:26 PM |
| Injector Seal Orientation | aaronc7 | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 06-13-2009 09:05 PM |
