  • 1 Post By KiwiFlavor
 Old 04-27-2016, 10:11 PM   #1
tytanium's Avatar
Posts: 137   (View Stats)
tytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant future
Default Issue installing lowering springs...
Tried to install my new corksport lowering springs onto my new Koni yellows and ran into an issue. It appears that the springs are MUCH too short. The instructions say that when I swap the springs they should need to be compressed...I could put the top bolt on without the springs compressing and they would be able to move around and be super loose. These wouldn't even fit on the stock shocks so I know the shocks aren't the issue
I am starting to think that the wrong springs were sent to me.
Anyone else have this issue?
EDIT: here is a photo of what I mean. there would be 0 zero compression needed and the spring would actually be able to move freely on the shock up and down
@CorkSport;
2007 CWP MS3
Powered by Purple Drank @ 22psi // ATP GT2871r // J2 Engineering catless downpipe // Continental Extreme Contact DW 245/40/17 // Rays Gram Lights 57DR 17x9 // // CP-e Nexus catback // resonator delete // Damond Motorsports rmm // GoFastBits bov // Maisonvi piston style shift knob // Cobb shift weight // Street Unit testpipe // Cobb Accessport V3 // JBR shifter bushings // Treadstone TR8L // JBR intercooler piping // Damond Motorsports power steering cooler // Denso 1-step colder plugs // Ramfab 4" intake // coolant bypass // Damond Motorsports egr block-off // Rally Armor mudflaps // Defi boost gauge // 3 bar MAP sensor // 3 port ebcs // Stratified Guardian Angel // JBR short shifter // Hotchkis rear sway bar // Stoptech ss brake lines // Centric premium brake rotors // Powerstop Z23 brake pads // Koni yellow shocks // Corksport springs // MOOG front and rear endlinks
tytanium is offline   Reply With Quote
 Old 04-28-2016, 10:21 AM   #2
tytanium's Avatar
UPDATE: just got a call from corksport letting me know that everything is fine and exactly what to do. Thanks for the good customer service guys, sorry I'm just dumb
2007 CWP MS3
 Old 04-28-2016, 11:23 AM   #3
Gribbs1469's Avatar
Posts: 112   (View Stats)
Gribbs1469 is a name known to allGribbs1469 is a name known to allGribbs1469 is a name known to allGribbs1469 is a name known to allGribbs1469 is a name known to allGribbs1469 is a name known to all
what ended up being the problem?
2007 MS6 FMIC, Garrett turbo, 3" Magna Flow TBE, 4" Intake, HP Fuel pump, COBB AP V3
Gribbs1469 is offline   Reply With Quote
 Old 04-28-2016, 11:34 AM   #4
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
Probably nothing.
It's because the springs are shorter than OEM that makes it "look" like it's free floating on the struts. Once you install and drop the car on the ground, they will be compressed and wont be moving freely.
But then again it could be something else.. Im bored at work and just pulling things out of my butt lol
monkey.bones.007 likes this.
 Old 04-29-2016, 12:41 AM   #5
tytanium's Avatar
Probably nothing.
this is exactly what corksport told me. I was just freaked out since I was following their instructions and it stated that they would need to be compressed before so I just wanted clarification
2007 CWP MS3
The Following User Says Thank You to tytanium For This Useful Post:
KiwiFlavor (04-29-2016)
 Old 04-29-2016, 09:03 AM   #6
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Just be careful every time you raise the car off of its wheels and make sure the front springs are properly seated as you lower it back down.
Also bear in mind that if you're driving along and the front suspension goes into full droop for whatever reason, that you risk the springs becoming unseated...
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
KiwiFlavor (04-29-2016), mxlplx71 (04-29-2016), WetzMS3 (04-29-2016)
 Old 04-29-2016, 10:13 AM   #7
mudawg's Avatar
Posts: 215   (View Stats)
mudawg has a reputation beyond reputemudawg has a reputation beyond reputemudawg has a reputation beyond reputemudawg has a reputation beyond reputemudawg has a reputation beyond reputemudawg has a reputation beyond reputemudawg has a reputation beyond reputemudawg has a reputation beyond reputemudawg has a reputation beyond reputemudawg has a reputation beyond reputemudawg has a reputation beyond repute
Mine would turn even with the weight of the car. Probably from crap roads and bumps so the suspension wasn't fully loaded with weight. I needed up going back to stock. Broke a set of mounts and didn't want it to happen again.
2008.5 Metropolitan Gray Mica MS3
BNR S3,Cobb Catted DP, JBR Alum 3inch Widepath, JBR SS, Damond TMM-PMM-RMM, Koni yellows, Autotech HPFP, APv3, Cobb EBCS, Bosch 3.0 Map, CNT Cbe, & Freektuned.
mudawg is offline   Reply With Quote
Issue installing coilovers AlexanderLEE_MS3 MazdaSpeed 3/6 - Suspension & Brakes 8 03-17-2014 02:25 AM
Page generated in 0.29375 seconds with 24 queries
