![]() Join Date: Jul 2014 Location: Hampton Roads, VA
(Thread Starter) | Neutral : +1 score Well I think the install was pretty straight forward. It did take me 12 hours but I have never done anything like that before. Honestly, the worst part of it was getting some of the heat shields off the manifolds. I also did my downpipe at the time and its not as bad as I thought it would be. I did have a huge breaker bar and swivel sockets. We did not have to pull the exhaust manifold or anything off to get the turbo out we just moved some lines and pulled it out the intake side. Note to others that have never done turbo installs; coolant comes out fast ...very fast. My white shirt is now green. I am being tuned from Ryan at purple drank. I have just my base map on now and its limited at 16 psi. My other mods are in my signature and I will keep up to date on this thread as my tune progresses. Here are some logs from my K04 tune from Ryan(it was not fully finished when I decided to go CS) versus my base map for the CS. I just got revision 2 so I will post them up as I get them. Current mods: CS Turbo AT interals HTP 3.5" intake ETS 3.25" TMIC UR Catted DP UR catless TP Forge v1 BPV Grimmspeed 3 port EBCS 3 bar Map sensor Mods on K04: Everything Minus DP,EBCS,Map Sensor. CS WOT1.csv CS WOT2.csv datalog2.csv datalog3.csv
__________________ 2009 ZZB'd MS3 Black -FUCK CO-SIGNING(YES I AM AN IDIOT but its mine now going to have fun with it) 17x8 anti freeze green Rota boost rims CP-E Stage 2 RMM//// Autotech Interals// ---------------------------------------------------------------------------------------------------- [Sold]2010 MS3 Black CS TURBO and CS shift knob fully weighted HTP 3.5" intake and Battery tray UR catted DP/RP and custom CBE CP-E Stage 2 RMM// ETS 3.25" TMIC// Autotech Interals forge BPV// Grimspeed ebcs// 3bar map"// JBR short shift plate 17x8 anti freeze green Rota boost rims Not installed:Fortune 500 coil overs/ Boost gauge/ AFR gauge/ JBR eyelids/Camber arms/ JBR OCC/ Guardian angel/ Devils own meth stage 2 381 whp/ 396wtq Purple Drank ----------------------------------------------------------------------------------------------------- Last edited by L0k1; 05-25-2015 at 10:04 PM. |
| The Following 12 Users Say Thank You to L0k1 For This Useful Post: | acousticdefbot (05-26-2015), Awal (05-26-2015), Barett@CorkSport (05-26-2015), CaptainCode (05-26-2015), Easter Bunny (05-26-2015), maisonvi (05-26-2015), mazdaspeedmyk (05-29-2015), mxlplx71 (05-25-2015), Raider (05-26-2015), Rich990 (05-27-2015), speedfreak44 (05-25-2015), tbcota25 (06-20-2015) |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score The more reviews the better.
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
![]() Join Date: Dec 2013 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
| Not Ranked : 0 score A few questions... Were all the mods on your sig installed on the k04? If that is a yes then I assume the maf cal didn't change at all? 10% wgdc looks great at just under 16psi with spark advance a little less than the k04 moving almost equivalent volume of air. Very nice Also, I would list the mods in the posting because sigs change and people searching for questions in the future may like to have mods with the logs
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
| The Following 4 Users Say Thank You to speedfreak44 For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score The mods that are new with the install are the ur catted dp, the 3 port and the 3bar. Idk about the maf cal stuff.
__________________ 2009 ZZB'd MS3 Black -FUCK CO-SIGNING(YES I AM AN IDIOT but its mine now going to have fun with it) 17x8 anti freeze green Rota boost rims CP-E Stage 2 RMM//// Autotech Interals// ---------------------------------------------------------------------------------------------------- [Sold]2010 MS3 Black CS TURBO and CS shift knob fully weighted HTP 3.5" intake and Battery tray UR catted DP/RP and custom CBE CP-E Stage 2 RMM// ETS 3.25" TMIC// Autotech Interals forge BPV// Grimspeed ebcs// 3bar map"// JBR short shift plate 17x8 anti freeze green Rota boost rims Not installed:Fortune 500 coil overs/ Boost gauge/ AFR gauge/ JBR eyelids/Camber arms/ JBR OCC/ Guardian angel/ Devils own meth stage 2 381 whp/ 396wtq Purple Drank ----------------------------------------------------------------------------------------------------- Last edited by L0k1; 05-26-2015 at 07:25 AM. |
| The Following 2 Users Say Thank You to L0k1 For This Useful Post: | Awal (05-26-2015), Easter Bunny (05-26-2015) |
__________________ 2009 ZZB'd MS3 Black -FUCK CO-SIGNING(YES I AM AN IDIOT but its mine now going to have fun with it) 17x8 anti freeze green Rota boost rims CP-E Stage 2 RMM//// Autotech Interals// ---------------------------------------------------------------------------------------------------- [Sold]2010 MS3 Black CS TURBO and CS shift knob fully weighted HTP 3.5" intake and Battery tray UR catted DP/RP and custom CBE CP-E Stage 2 RMM// ETS 3.25" TMIC// Autotech Interals forge BPV// Grimspeed ebcs// 3bar map"// JBR short shift plate 17x8 anti freeze green Rota boost rims Not installed:Fortune 500 coil overs/ Boost gauge/ AFR gauge/ JBR eyelids/Camber arms/ JBR OCC/ Guardian angel/ Devils own meth stage 2 381 whp/ 396wtq Purple Drank ----------------------------------------------------------------------------------------------------- | |
![]() Join Date: Aug 2008 Location: Ashburn, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
| Not Ranked : 0 score What's your goal out of this turbo and your tune? The power level and anticipated boost since you picked up a 3bar? Plan to run E and/or meth for additional fueling?
__________________ 2006 Black Mica MS6 - Sold 10/15 |
(Thread Starter) | Not Ranked : 0 score I picked up the 3 bar at the suggestion of my tuner. I do plan to run an E85 mix. For power I want to see how far I can take it while still remaining safe for my engine internals because it is my daily. Now saying that I do have another car I can daily if it came to it but my wife probably be upset with me.
| Not Ranked : 0 score Thanks for posting.
| The Following User Says Thank You to Easter Bunny For This Useful Post: | L0k1 (05-26-2015) |
(Thread Starter) | Not Ranked : 0 score Here is the logs from the revision I got last night. Today is the first day I commuted on the CS. It drove fine. I could hardly tell a difference. When it pulls it on this map it feels very similar to my k04 on 20 psi but I doubt butt dyno is accurate.
| The Following 3 Users Say Thank You to L0k1 For This Useful Post: |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
Very cool. I look forward to seeing how you progress with this air blower. Sent from my iPhone 6 | |
| The Following User Says Thank You to littleloogy For This Useful Post: | L0k1 (05-26-2015) |
![]() Join Date: Oct 2013 Location: Kingston, Ontario
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 706
| Not Ranked : 0 score Thanks for posting up! feels similar to the k04? I know you're just starting to tune it so do you notice an improvement so far? I only playing devils advocate as I pressure you would |
![]() Join Date: Nov 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score Thanks for posting this up, I am itching to get the CS turbo it seems like a good DD turbo for this motor.
__________________ 2013 Genpu GT, 245/40 Direzzas, CS SRI+TIP,CS TP+CB, CS TMIC, CS FP Internals, CS 80a RMM, CS BPV, Accessport V3, Tuned by Nishan |
| Not Ranked : 0 score Yeah, still in early stages. Wait until the boost goes up. That is when it gets interesting. |
| The Following User Says Thank You to Raider For This Useful Post: | Barett@CorkSport (05-28-2015) |
| Not Ranked : 0 score Interesting in seeing what is possible when it gets interesting :-) |
| The Following 16 Users Say Thank You to Raider For This Useful Post: | aackthpt (05-29-2015), aaronc7 (05-29-2015), aromig (07-18-2015), Awal (05-29-2015), Code Monkey (05-30-2015), Easter Bunny (05-29-2015), iammike (05-29-2015), ItsNox (06-04-2015), kidlifecrisis (05-31-2015), LatinKraze (05-30-2015), MS3Shadow (06-02-2015), Oni (05-29-2015), rob ms6gt (06-01-2015), sxman (06-02-2015), WA_MS6 (06-06-2015), We're All Thieves (05-30-2015) |
(Thread Starter) | Not Ranked : 0 score That very interesting sentence structure. Also I have not got a revision yet but I may be meeting up with my tuner tomorrow and do some street tuning. I will post back the results.
| The Following User Says Thank You to L0k1 For This Useful Post: | Raider (05-30-2015) |
| Not Ranked : 0 score Hey, how'd you get my picture @Raider;? I was just trying to book mark this thread and use what the OP said earlier. Made sense in my head...... |
| Not Ranked : 0 score Because I could only imagine someone at an 8 posting that. |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score I got a new map today from my tuner. Its raining for the next couple days so I probably will not get you guys any logs right away. I am suppose to be up to 20 psi now.
| The Following 2 Users Say Thank You to L0k1 For This Useful Post: | Awal (06-06-2015), littleloogy (06-02-2015) |
![]() | | #20 | ![]() |
| Not Ranked : 0 score Better invest in some new tires now. Mine are gone now gone from all these 4th gear data logs. Sent from my iPhone 6 |
| The Following 3 Users Say Thank You to littleloogy For This Useful Post: |
![]() | | #21 | ![]() |
![]() Join Date: Aug 2012 Location: Tracy CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 89
| Not Ranked : 0 score I found out the hard way when mine blew out recently. Everything looked good but I guess there was a side wall defect because all of the wiring just came out. Fucking weird. What ate you looking to get?
__________________ Too much for you |
![]() | | #22 | ![]() |
| Not Ranked : 0 score 235's Good Year Eagles F1's FTW. I want to see @L0k1; break his stock tires loose on a 4th gear pull. Sent from my iPhone 6 |
| The Following User Says Thank You to littleloogy For This Useful Post: | skoski17 (06-02-2015) |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Should be nice and sticky kinda jealous
![]() | | #24 | ![]() |
| The Following User Says Thank You to L0k1 For This Useful Post: | littleloogy (06-02-2015) |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well ended up doing some logs today. Also a vdyno shot. Not sure if its fully set up correctly or not.
| The Following User Says Thank You to L0k1 For This Useful Post: | Awal (06-06-2015) |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Smoothing factory 3, CF 1.01 Setting proper temp too helps. |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score as in outside temp?
![]() | | #28 | ![]() |
![]() Join Date: Aug 2012 Location: Stokesdale, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,146
__________________ 2012 Velocity Red Mazdaspeed3 - CP-E Stage 1 RMM - Autotech HPFP Internals - COBB AP v3 - Corksport 3inch Intake - Corksport Turbo - Corksport BPV - - JBR Shift Plate & Shift Weight - JBR Solid Bushings - cp-e Catted TBE - NGK 1 step colder plugs - COBB 3 Port EBCS - - ETS TMIC - Michelin Pilot Super Sport 235/40-18 - JBR OCC Stage 2 - JBR EGR Delete - CorkSport Boost Tubes - - JBR IM and TB gaskets w/ coolant bypass - Damond Motosports PMM - Corksport PMM Bushing Insert - ![]() Tune in progress |
![]() | | #29 | ![]() |
![]() Join Date: Oct 2011 Location: brooklyn, ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 240
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score IDK, I bought them because they were only 78 bucks each and had a decent rating on tire rack. They only have around 1.5k miles on them.
![]() | | #31 | ![]() |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score I am going to hopefully finish up my tune here in a few minutes guys. I will post logs tonight.
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score Okay guys. I spent the day with Ryan working on my tune. I am on 4 gallons of e85. If someone could turn it into Vdyno please that be great. It was 75 out when I did the logs and I weigh a fat 200 lbs. The car is pulling hard. When he first had me pull on the e85 tune I was taken by surpise in the torque steer. It feels great.
![]() | | #34 | ![]() |
![]() Join Date: Jul 2011 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
| Not Ranked : 0 score Looks funny to me though....is this a comparison of last map vs final map or did I fubar something? Both 4th gear, 1.01 smoothing 3 uncorrected as temp were close enough..
__________________ Speed 6 Gone for 3+ years and still not happy about it 2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP Enki - "High mixes of corn = all the wastegate all the time for great justice." |
![]() | | #35 | ![]() |
![]() Join Date: Sep 2011 Location: France
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
| Not Ranked : 0 score I can't use VD now, but I'm sure you've got very good numbers with this tune ! Did you monitored your IDC ? |
![]() | | #36 | ![]() |
(Thread Starter) | Not Ranked : 0 score This is what ryan sent me 11430259_486574801500903_5040847320118337759_n.jpg
![]() | | #37 | ![]() |
| Neutral : +1 score Impressive! ![]() Can't wait to get mine |
![]() | | #38 | ![]() |
![]() Join Date: Oct 2013 Location: Raleigh, Charlotte NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 812
| Not Ranked : 0 score Did you set the throttle position column of the log to 100 for the entire log before you put it in vdyno?
__________________ 2013 Liquid Silver Metallic MS3 GTX2867 ; Cobb AP v3 ; Cobb Turboback Exhaust ; Cobb EBCS ; Swift Springs ; Koni Yellows ; SPC Camber Arms ; Aquamist HFS-4 WMI ; Relentless Customs PNP IM ; ETS TMIC ; HTP Full 3.5" Intake ; HTP Battery Tray ; CS BPV ; CS Mid-Chassis Brace ; CS TMM Insert ; AT Internals ; JBR 88 Duro RMM ; DM PMM ; JBR OCC ; JBR IM & TB TIGs ; JBR EGR Blockoff Plate ; JBR 0.125 RSB & Tru-Torsion RSB Billet Brackets ; NGK Step Colder Plugs ; Bosch 3 Bar Map ; Block8head Dual Gauge Vent Pod ; Dual Aeroforce Interceptors ; Stoptech SS Brake Lines & Centric Blanks ; EBC Yellowstuff ; MOOG Endlinks TunedbyNishan |
| The Following User Says Thank You to mize13 For This Useful Post: | Awal (06-12-2015) |
![]() | | #39 | ![]() |
![]() Join Date: Aug 2012 Location: Auburn, MI
I'm also curious where you ended up with IDC.
__________________ '12 Velocity Red Mica MS3 Cobb AP V3 // Autotech Fuel Pump Internals // HTP 3" // UR Catted V2 DP // UR Resonated TP // UR Resonated CBE // GrimmSpeed EBCS // CP-E TMIC // GFB Respons BPV // JBR Trilogy 88/80/80 // Corksport Hood Struts // Prosport EVO Boost Gauge w/ block8head vent pod // E30 Freektune Installing Soon : Stratified GA // Bosch 3 Bar Map w/ PNP Harness [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to Oni For This Useful Post: | Awal (06-12-2015) |
![]() | | #40 | ![]() |
| Not Ranked : 0 score Ah I did not. My mistake
| anyone have experience with cpe cbe? | steevieg | Gen2 MS3 General Discussion | 5 | 04-14-2014 07:41 PM |
| Anyone have experience with the CS TIP? | volodya84 | MazdaSpeed 6 - Engine, Transmission & Driveline | 3 | 05-11-2010 08:58 AM |
