| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
(Thread Starter) | Not Ranked : 0 score We have been working over the past few months to get a few more of the MS6 FMIC kits put together from components we had on the shelf from earlier batches. We are happy to say we have a very limited number of the kits completed and ready to go. This is really it on the end of the kits, we have used up all that we had left to build these. Link to the MS6 FMIC Kit. -Derrick |
| The Following 3 Users Say Thank You to CorkSport For This Useful Post: |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
| Not Ranked : 0 score IM OFF TO THE STREET CORNER TO MAKE SOME DOLLARS. Shit 900 of them.
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() |
| The Following User Says Thank You to ItsNox For This Useful Post: | dagrimey1 (04-07-2016) |
![]() Join Date: Oct 2012 Location: Austin, TX
Rep Power: 282 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 406
| Not Ranked : 0 score 2010+ Mazdaspeed6s... must be a real niche market you guys are targeting ![]() thanks, @CorkSport; now this post won't make sense
__________________ 2008 Mazdaspeed3 GT JBR TRU 3.5 Aluminum WP // Corksport TBE // JBR OCC Stage 2 // AP v3 (Tweaked [by me] E40 Tune) // Autotech Internals // Stratified EBCS // TWM Full Replacement w/ Type R Knob // CP-e Stage 2 RMM // JBR/Damond Full EGR Delete // Synchronic DV // NGK 6510s // FMIC [TR8 w/ JBR Pipes] // CorkSport Adjustable Struts/Lowering Springs // Progress RSB Jet Black Wax (06/24/2017) Better compression than Silaramic (02/20/2016) Last edited by Shwaykid; 10-27-2015 at 10:40 AM. Reason: Ninja website edit |
| The Following User Says Thank You to Shwaykid For This Useful Post: | CorkSport (10-27-2015) |
| The Following User Says Thank You to Easter Bunny For This Useful Post: | dale_gribble (10-27-2015) |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
| Not Ranked : 0 score For shits-n-gigs, @Big Mike;
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
__________________ I hugged rfinkle2 | |
![]() Join Date: Jul 2013 Location: Rosamond, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 70
| Not Ranked : 0 score Is that an air box bolted at the top? |
| looks like it, Ram Air Intake replaces the TMIC area with this kit.
| Not Ranked : 0 score How does the intercooler compare to say a TR6? |
| Approved MSF Vendor ![]() Join Date: Apr 2014
Rep Power: 137 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score YEP
__________________ |
(Thread Starter) | Not Ranked : 0 score We have never done a apples to mangos comparison between them so I cannot say. We do use the same core type as our other FMIC kits. Derrick |
| The Following User Says Thank You to CorkSport For This Useful Post: | WetzMS3 (10-27-2015) |
![]() Join Date: Sep 2012 Location: Phoenix, Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
Groans: 89
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score Didn't the ram air kits have issues with maf cal? Been a while but going front mount has been a consideration.
__________________ 2007 MS6 GT: HTP 3" Full Intake, CS TMIC, AutoTech Internals, APv3, Forge Version 2 BPV(Blue+1 Shim), CP-E Catted DP, Whiteline RSB, CP-E Rear Diff mount, CP-E RMM, CS transmission mount insert, JBR Stage 2 OCC, JBR Boost tubes and recirc hose, Bilsteins B6's all around, Techna-Fit SS clutch and brake lines with ATE fluid, FreekTuned! |
| Not Ranked : 0 score ROFL, after all my trials and tribulations to get where I am this comes out. In my defense, I did ping CS about any kits around a while back with no luck. CS FMIC = 2.25" piping, 630 in^3 volume IC, minimal couplers, accepts Mazda flange BPV. 10/10 would run it if I didn't already dump what I did into this old CP-E kit. I'm not sure about the whole ram air thing, but I'm sure someone could get an SRI in if desired. It would definitely be good to hack the crashbar and drill out holes to get some more air into that massive IC.
| The Following 2 Users Say Thank You to dale_gribble For This Useful Post: | Easter Bunny (10-27-2015), WetzMS3 (10-27-2015) |
Do something like this and weld in some 2.5 ID pipe. ![]() Derrick | |
| Not Ranked : 0 score I see tape on the hood of that pu for what was likely the CF hood scoop measurements. I also see more tape on the hood on the drivers side.... Care to tease me a bit?
| The Following User Says Thank You to WetzMS3 For This Useful Post: | ItsNox (10-27-2015) |
Here you go -Derrick | |
| The Following 5 Users Say Thank You to CorkSport For This Useful Post: | BLKSTIG (10-29-2015), Code Monkey (10-27-2015), MS3Shadow (10-27-2015), WAMBUSHHHH! (10-28-2015), WetzMS3 (10-27-2015) |
Groans: 89
| Not Ranked : 0 score @dale_gribble; time to buy this and do a comparison to the ETS tmic and other fmic you have for us MS6 owners everywhere.
![]() Join Date: Mar 2014 Location: Durham, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score Are you guys willing to sell a batch like the older FMIC w/ SRI kits instead of FMIC with ram air?
__________________ 2006 Super Clean BCM MS6 Corksport Intake/TIP - Test Pipe - CS FMIC - Freektune - Autotech HPFP - 18x8 Wheels with Nitto NT05's 235/40/18 - H&R Coilovers - SPC Balljoints - CS RMM - Magnaflow CBE - DM Power Steering Cooler - CAR LED Tails - EBC Yellowstuff w/ Centric Blanks - Xcarlink w/ Bluetooth Module Waiting to be installed: Diff Braces - TMM Insert |
![]() | | #19 | ![]() |
| Not Ranked : 0 score This will be a last run kind of deal, so they will be as they sit for now.
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score We have 4 kits total available, one is a scratch and dent kit which will have a discount on it. -Derrick |
![]() | | #21 | ![]() |
![]() Join Date: Oct 2011 Location: brooklyn, ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 240
| Not Ranked : 0 score Just an fyi you can run an sri with this for if you want. I had the ram air kit originally and went over to an htp 3" with no problem. |
![]() | | #22 | ![]() |
| Not Ranked : 0 score @maddocx240; thanks for the info that gives me something to think about!
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score 3 kits available... |
![]() | | #24 | ![]() |
![]() Join Date: Sep 2014 Location: belmont ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score I cant wait to get this on my car. Order placed last night. I am becoming a corksport junkie |
![]() | | #25 | ![]() |
| Soo about two reminding kits? Sent from my Nexus 6P
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score All gone. Derrick |
![]() | | #27 | ![]() |
![]() Join Date: Aug 2009 Location: Hershey, PA
Rep Power: 265 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score All the kits are gone you say....maybe there is a market and you should make more MS6 FMIC (and other performance) kits...
__________________ '06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs |
| The Following User Says Thank You to MazdaspeedKills For This Useful Post: | dale_gribble (11-17-2015) |
![]() | | #28 | ![]() |
![]() Join Date: May 2012 Location: Greensboro NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 751
Groans: 27
__________________ 06 VRM Speed 6 W/Navi 05 Mazda Family Truckster FREEKTUNED\\Cobb AP\\Autotech Internals\\Eibach Pro Springs\\Sure SRI+TIP\\Street Unit TP\\CPE RMM\AWR 88 Duro TMM\\Forge V1\\JBR Shortcut\\JBR SSB\\CPE & Sure Rear Diff Mounts\\Unicorn Blood (Rotella T6) twitter.com/djern instagram.com/djern facebook.com/djern |
![]() | | #29 | ![]() |
__________________ | |
![]() | | #30 | ![]() |
| Not Ranked : 0 score That sold quick. Funny how fast they sold within two weeks and it was out for like two years and didn't move, lol. Here is the cs kit with a 3inch intake. Just for those of you that were wondering. http:// |
| The Following User Says Thank You to maddocx240 For This Useful Post: | Easter Bunny (12-01-2015) |
![]() | | #31 | ![]() |
| Not Ranked : 0 score Classic supply and demand. Supply dried up, demand went up.
| The Following User Says Thank You to dale_gribble For This Useful Post: | maddocx240 (11-25-2015) |
![]() | | #32 | ![]() |
| Not Ranked : 0 score I figured they'd move quickly, glad I snatched mine up when I did!
![]() | | #33 | ![]() |
| Not Ranked : 0 score Just received mine in the mail yesterday. Now I just have to get the time to install it. It is sexy though. |
![]() | | #34 | ![]() |
| Not Ranked : 0 score @CorkSport; Could you please link the install guide for this FMIC, I can't find it since it's off your site now. I'm interested in how the core is mounted.
![]() | | #35 | ![]() |
Groans: 33
http://support.corksport.com/instruc...130-10-WEB.pdf
__________________ Mazdaspeed6 -06 Tuned with by Alex@StratifiedCP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2 Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025 Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer 290 AWHP / K04 370 AWHP / GTX3076 @ 23 psi | |
| The Following User Says Thank You to SpeedRebirth For This Useful Post: | Mazdazilla6 (12-07-2015) |
![]() | | #36 | ![]() |
Thanks @SpeedRebirth; for posting up the link. -Derrick | |
| The Following 2 Users Say Thank You to CorkSport For This Useful Post: | Mazdazilla6 (12-09-2015), SpeedRebirth (12-09-2015) |
![]() | | #37 | ![]() |
![]() Join Date: May 2012 Location: Ontario
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 89
| Not Ranked : 0 score @CorkSport; I just bought a MS6 and finding a FMIC is an issue... looks like I need to go custom.
__________________ My car thread: http://www.mazdaspeedforum.org/forum/forum/f542/pwdunmore-s-2012-a-150456/ |
![]() | | #38 | ![]() |
| Not Ranked : 0 score Most folks don't necessarily need an fmic. Why do you need one?
![]() | | #39 | ![]() |
| Not Ranked : 0 score My tuner wasn't sure if the CP-e TMIC could would push north of 400 WHP on my MS6, he recommended I look into FMIC options. Think the BNR S4 pushed to it's max will see the upgraded TMIC as a restriction? The engine is forged and fueling will be enough to max the S4 out. Any suggestions would be appreciated because I know the TMIC is efficient so I don't need to be told about that, that's why I have an upgraded TMIC on my MS3. If I even knew where to source a the CS core I can get piping made...
![]() | | #40 | ![]() |
Groans: 33
| Not Ranked : 0 score @pwdunmore; You should look into the HDI Mazda 6 MPS FMIC kit, i gained 20hp and much better cooling going from cpe tmic to this fmic. Its from australia and is available on ebay and since the AUD is much lower than USD it will be very affordable. 700aud ~500usd
| The Following User Says Thank You to SpeedRebirth For This Useful Post: | pwdunmore (02-28-2016) |
| GI: JBR FMIC Piping Kits | JBR | JAMES BARONE RACING | 853 | 11-13-2015 03:05 PM |
| New JBR FMIC K04 Under Mounted Clocking Kits in Stock!! | JBR | JAMES BARONE RACING | 0 | 04-16-2015 02:01 PM |
| ebay universal fmic kits | contreras | MazdaSpeed 3/6 - Turbo Induction | 5 | 06-19-2012 08:26 PM |
| FMIC piping kits and cores... | Meder | MazdaSpeed 3/6 - Turbo Induction | 15 | 02-17-2012 08:02 AM |
| Interest: PowerLab Kits/ProEFI (Turbo/FMIC/FMS) | ResilientMike | MazdaSpeed 3/6 - Turbo Induction | 9 | 04-22-2008 05:05 AM |
