  • 1 Post By JgamB
 Old 03-06-2014, 05:44 AM   #1
anotherneon's Avatar
Posts: 128   (View Stats)
anotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant future
Groaned at 14 Times in 7 Posts
Default which MM to go with
I have the following parts waiting to be installed (intake,DP,Fuel pump, AP) I know I am going to need a motor mount but am unsure which to go with. Could I get by with just the inserts? I had a 350whp srt-4 in the past with solid mounts and hated the vibration. I dont plan on taking this car to the track or drag racing from light to light, but the occasional WOT will be had. Will I be ok with just the inserts?
anotherneon is offline   Reply With Quote
The Following User Says NO Thank You to anotherneon For This Un-useful Post:
jack_hammer (03-11-2014)
 Old 03-06-2014, 05:50 AM   #2
obijack's Avatar
Posts: 1,830   (View Stats)
No. Just buy a RMM and you will be fine. Buy one from corksport or go VIP and check the forsale section. Many times there will be members selling lightly used RMM's. You don't need the passenger side mount or tranny mount.
2014 Honda Grom-Red
2014 Yamaha Grizzly 350- Blue
 Old 03-06-2014, 05:54 AM   #3
Anthony1982's Avatar
Posts: 139   (View Stats)
Anthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond repute
I used the inserts for awhile. I personally felt i needed more. Save some time and money and go with the JBR. Probably not the 88 though if you dont like a lil vibs.
2011 Silver MS3
JBR-EGR block off/delete, Stage 2 OCC, 3.5 SRI, Short Shifter, PMM/TMM, rear sway bar
Corksport-TP, Axle back, battery box, hood scoop
Auto tech internals, NGK plugs, ETS TMIC, Sure TB/IM TIG
CPE stage 2 RMM, Gaurdian Angel, perm tuning butt plug
AP V2 with RICH TUNE on 93.
Forge V1 BPV-SHIIING!
Anthony1982 is offline   Reply With Quote
 Old 03-06-2014, 06:13 AM   #4
if not the 88 which one do you suggest?
Originally Posted by Blown_Dan View Post
I'm really pleased with my CP-E Stage 2. On an otherwise stock car, it made a huge difference in feel without much added NVH.
thanks, ill take a look.
Last edited by anotherneon; 03-06-2014 at 06:13 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-06-2014, 06:06 AM   #5
Blown_Dan's Avatar
Posts: 118   (View Stats)
Blown_Dan has a reputation beyond reputeBlown_Dan has a reputation beyond reputeBlown_Dan has a reputation beyond reputeBlown_Dan has a reputation beyond reputeBlown_Dan has a reputation beyond reputeBlown_Dan has a reputation beyond reputeBlown_Dan has a reputation beyond reputeBlown_Dan has a reputation beyond reputeBlown_Dan has a reputation beyond reputeBlown_Dan has a reputation beyond reputeBlown_Dan has a reputation beyond repute
Blown_Dan is offline   Reply With Quote
The Following 4 Users Say Thank You to Blown_Dan For This Useful Post:
chaser27 (03-07-2014), InkedInspector (03-06-2014), Nliiitend1 (03-06-2014), Playaj (03-06-2014)
 Old 03-06-2014, 07:08 AM   #6
obijack's Avatar
If you are not interested in a corksport RMM why did you post in their section?
2014 Honda Grom-Red
The Following 2 Users Say Thank You to obijack For This Useful Post:
jack_hammer (03-11-2014), Playaj (03-06-2014)
 Old 03-07-2014, 08:15 AM   #7
I posted in their section to ask about the inserts vs the solid mounts because I was interested. It was the other members who were throwing out the other companies.
Get a set of CS inserts for now, donate, meet with Nator, ride in their mounted cars, then make a decision.
You're asking a personal preference question that is further tainted with vendor bias.
I was looking for a vendor reply, which I got, to help me pick the best insert or mount based on my driving style. I am no longer looking to drag race or beat the hell out of the car on a daily basis, so I wanted to know if I could get by with just the inserts based on my mods.
Last edited by anotherneon; 03-07-2014 at 08:15 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-06-2014, 07:19 AM   #8
the 70 should be good. Stiffen it up, and vibes are un noticable.
2011 Silver MS3
 Old 03-06-2014, 02:09 PM   #9
SpencerC's Avatar
Posts: 2,159   (View Stats)
The inserts work well, I've run them for awhile, but you will probably find yourself wanting more. Most of our customers run the 70duro insert and love it, but those who have a little more power, or just like something stiffer love the 80... no wrong choices!
 Old 03-07-2014, 09:25 AM   #10
darthxar's Avatar
Posts: 560   (View Stats)
darthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the world
I concur, I am lightly modified and love my Corksport RMM with the 70. Better shifting, less hop, and almost no vibes. The only time I notice it is when it's sub zero outside and the urethane stiffens up.
Double tappin' the Moto
2013 VRM MS3
darthxar is offline   Reply With Quote
The Following User Says Thank You to darthxar For This Useful Post:
SpencerC (03-10-2014)
 Old 03-07-2014, 12:01 PM   #11
How is it when the AC on?
 Old 03-07-2014, 02:34 PM   #12
darthxar's Avatar
I really don't notice the AC at all. I can just barely feel it when the compressor cycles, but I noticed that with the stock mount as well.
2013 VRM MS3
 Old 03-06-2014, 03:18 PM   #13
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
If you want the best balance of comfort and performance, get the cp-e Stage 2 RMM.
It's the bee's knees.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 03-06-2014, 04:15 PM   #14
plak424's Avatar
Posts: 298   (View Stats)
plak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the world
JBR 88 molly. Can't beat it.
Mods: JBR 3" WP, Cobb AP, JBR SSP, JBR 88d RMM, JBR Rear Sway, JBR Camber Arms, Autotech's, UR DP/TP, CS OCC, DO STG1 soon...
plak424 is offline   Reply With Quote
The Following User Says Thank You to plak424 For This Useful Post:
rymanmazda (03-10-2014)
 Old 03-06-2014, 06:37 PM   #15
JgamB's Avatar
Posts: 2,566   (View Stats)
King Scumbag likes this.
 Old 03-07-2014, 09:00 AM   #16
Nliiitend1's Avatar
I didn't even realize which section this thread was in...
Sorry!
2008 MS3 GT
2016 MX-5 Club
 Old 03-07-2014, 04:24 PM   #17
MichaelGear's Avatar
Posts: 216   (View Stats)
MichaelGear is the leader of the worldMichaelGear is the leader of the worldMichaelGear is the leader of the worldMichaelGear is the leader of the worldMichaelGear is the leader of the worldMichaelGear is the leader of the worldMichaelGear is the leader of the worldMichaelGear is the leader of the worldMichaelGear is the leader of the worldMichaelGear is the leader of the worldMichaelGear is the leader of the world
I've had the CS RMM inserts in for about a year now and they're holding up very well; that said, I haven't done any autocross or track days with them to really test their durability. What I will say is that, for the money, the inserts are a good buy and will improve the feel of your car VERY noticeably.
MichaelGear is offline   Reply With Quote
 Old 03-07-2014, 08:35 PM   #18
MacheteJames's Avatar
Posts: 152   (View Stats)
MacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond repute
I've had the inserts, the CS mount with 70 duro inserts, and the same CS mount with the 85 duro insert.
Stock mount with inserts: great while they last, but loosen way up after six months or so.
70 duro: best balance of stiffness and vibes. They feel like fresh inserts, but do so indefinitely. Very little wheel hop with this mount.
85 duro: noticeably stiffer. Vibes are much more noticeable and are borderline obnoxious in temps below freezing, since the poly inserts get stiff in the cold. Turn-in feels so nice with this mount and the motor feels 100% planted. I picked this up because it's the best option for autocrossing.
Best option is the CS mount with both the 70 and 85 duro insert. 70 duro for winter (if it gets cold where you live) and swap to the 85 duro for the rest of the year.
MacheteJames is offline   Reply With Quote
The Following User Says Thank You to MacheteJames For This Useful Post:
 Old 03-10-2014, 11:38 AM   #19
SpencerC's Avatar
@MacheteJames; thanks for the great review! I'd say you nailed it.
I just swapped from inserts after 4 months to the 70 duro Rear Mount and it is a huge improvement. Shifts better, hardly any vibes, hardly any wheel hop. Really the best for a daily driver year round. I do find myself wanting more stiffness on the weekend cruises around the hills, but that's why I'll be swapping in an 80 duro soon for summertime!
 Old 03-11-2014, 06:29 AM   #20
Awesome, thanks guys!
 Old 03-20-2014, 02:45 PM   #21
Jzen16's Avatar
Posts: 166   (View Stats)
Jzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond repute
Groaned at 4 Times in 1 Post
Jbr rmm!!!!
'13 BM w/ tech
Autotech HPFP - Cobb AP v3 - CP-E Catted DP -OBX Cat-back - CS SRI/TIP - UR FMIC - HKS SSQV4 - JBR RMM - Stratified Tuning
Eibach Springs - SPC RCA- Ralliart MF - Mugen Visors - 06-07 STI lip - MZ sides/rear - Glowshift A-Pillar Pod/Gauges - DDM 6k low/3k fog - Lamin-x yellow fog light cover - Bluebatmobile red tail light overlay - CS led kit - BLOX Neochrome shift knob - 20% all around
Jzen16 is offline   Reply With Quote
Page generated in 0.40397 seconds with 30 queries
