  • 2 Post By
 Old 03-03-2014, 10:44 AM   #1
twenty5psi's Avatar
Posts: 213   (View Stats)
Basically the same issue I have, it's starting to warm up here so I don't hear it much anymore. If you pull the driver wheel you can clearly see the bar and trans case about a millimeter from contacting each other.
2013 MS3 VRM w/Tech
front bumper insert tooslow10 Exterior 60 11-04-2013 11:01 AM
Front lower grille AKmac11 MazdaSpeed 3/6 - Appearance 2 02-27-2013 11:45 AM
Front Lower Tie Bar Todd98SE CorkSport 3 10-23-2012 05:24 PM
lower front springs only? bmannn 2010 MS3 - Suspension & Brakes 1 04-22-2011 01:19 AM
Page generated in 0.23670 seconds with 22 queries
