![]() Join Date: Dec 2012 Location: Venice,FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 438
(Thread Starter) | Neutral : +1 score Ordered some CS chassis and suspension components over the holidays and they arrived earlier in the week. Got the tie bar and TMM insert installed last night but I still need to get the RSB on the car, judging by the reviews I'm saving the best for last. CS TMM INSERT: TMM insert was first, pretty straight forward installation, the only tip I would have is even after you release tension on the drivetrain with a jack before removing the main bolt, it needed to come up a little bit more for the insert/TMM assembling to line up properly again. The pics I took show how the stock TMM insert and the CS insert sit on the lower TMM assembly, but this is not how it goes back together, you press the insert into the upper TMM assembly. The stock TMM insert is flimsy, and mine was actually broken on a car that's less than a year old! CS FRONT LOWER TIE BAR: Got the TMM all back together and the engine bay buttoned up and then threw on the lower tie bar, this is the piece I was actually more interested in as it doesn't seem to have a big following here on MSF so I wanted to shed some light on this and give my impressions. This bar is surprisingly light but still looks and feels much beefier then the main alternative "Traction Bar" on the market, these work by tying the two main control arm pick up points together, which should increase chassis rigidity and keep the front suspension geometry happier under high-load situations. This is pretty damn easy to install, you'll need a good breaker bar with some leverage if you're doing this on jack stands, but it's as simple as loosening two bolts and sliding the brace over them, then re-tightening the bolts. DRIVING IMPRESSIONS: The tie bar makes itself known first, the first slow corner out of my neighborhood I noticed it, the front end has a much more eager character, it wants to pull you through corners and gives you that nice "taut" feeling. The car seems more composed on choppy roads, had a few little rattles in the interior from the RMM that seem to be reduced or gone. One of my biggest pet peeves about this car was the "nervous" feeling that comes through the steering wheel under braking/decel on less than perfect roads, it seems MUCH better! The TMM insert is stealthy at first because it's not like a big RMM upgrade where the car buzzes with a new mount, no new NVH to speak of! If I'm being super OCD there maybe a SLIGHT increase in A/C-on idle vibes(it was ~80 here yesterday in FL) but I'm going to say this is because the battery was just reset and the fuel trims were still settling down. The reduction is drivetrain slack is noticeable, the clunking etc. left over that my RMM didn't take care of seems to be gone, wheel hop is essentially a non-issue now on the street. The best part about the TMM is the shifting though, it just feels better, particularly in high load or RPMs. For $150 combined if you have a modded MS3 you should really consider this mod combo, you feel that the front end of the car can handle the bigger power numbers now, where as before without the bar and insert the car give you that "too much for its own good" feeling, now it's just impressive.
__________________ 2013 MS3 VRM w/Tech -unSure Track RMM//Cobb AP//AT HPFP Internals//HTP 3" Intake//UR Resonated TP//UR CBE//JBR Weighted Shift Knob//JBR Shifter Cage Bushings FlowTuned 2 Gallon E85 blend 307whp/336wtq |
| The Following 8 Users Say Thank You to twenty5psi For This Useful Post: | Digital_Jedi (01-13-2014), IGMO71 (01-11-2014), kritz (01-12-2014), Kyle Undefined (01-11-2014), Mauro_Penguin (01-17-2014), p057 (01-14-2014), SpencerC (01-13-2014), Voltron (03-03-2014) |
![]() Join Date: Dec 2012 Location: NO KY
| Not Ranked : 0 score I have installed the inserts for the TMM and the RMM noticed a big difference. I have been trying to figure out if I want FSB and RSB or Chassis bracing. How did you decide to go with RSB and front lower brace? |
![]() Join Date: Sep 2011 Location: Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
| Not Ranked : 0 score TMM insert I pushed mine into the mount, didn't set it in the car first...was easier that way? I wish CS would explain why the tie bar can't go on the 2010 Canadian MS3.
__________________ - 2010 Mazdaspeed 3 Black Mica - - Cobb AP - Self Tuned - cpe HPFP - cpe DP - CS 3" SRI - cpe TMIC - Forge BPV v2 - Grimmspeed EBCS - Denso ITV22 - - SouthBend Stage 3 Daily Clutch - cpe RMM - CS TMM Insert - TWM SB - CS SSP & SW - CS RSB & Mid Chassis Brace - - CS Brake Pads - Michelin Pilot Super Sport - CS Boost Tubes - CS Fog, DRL and Interior LEDs - Horns - Grounds - 20% Tint - |
(Thread Starter) | Not Ranked : 0 score No, I pushed it into the mount as well, took that pic for comparison.
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
| Neutral : -1 score
-Derrick | |
| The Following 3 Users Say Thank You to CorkSport For This Useful Post: |
Thanks though Derrick
__________________ - 2010 Mazdaspeed 3 Black Mica - - Cobb AP - Self Tuned - cpe HPFP - cpe DP - CS 3" SRI - cpe TMIC - Forge BPV v2 - Grimmspeed EBCS - Denso ITV22 - - SouthBend Stage 3 Daily Clutch - cpe RMM - CS TMM Insert - TWM SB - CS SSP & SW - CS RSB & Mid Chassis Brace - - CS Brake Pads - Michelin Pilot Super Sport - CS Boost Tubes - CS Fog, DRL and Interior LEDs - Horns - Grounds - 20% Tint - | |
| Not Ranked : 0 score Ahh ok, good stuff
| The Following User Says Thank You to someguy For This Useful Post: | twenty5psi (01-11-2014) |
| Sideswipe Magnet ![]() Join Date: Aug 2012 Location: Clearwater, FL
Rep Power: 2827 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,163
Groans: 332
| Not Ranked : 0 score Nice review Data! Was looking at the FSB awhile ago, but wasn't too sure if it would make a difference or not.
__________________ I would love to change the world, but they won't give me the source code. // Logic never changes, just the syntax. // To be the best, you've got to beat the best. Black Mica 2008.5 Mazdaspeed 3 GT // Totaled by 18 wheeler // rfinkle2 pump toon 309 HP - 327 TQ // E85 toon 336 HP - 357 TQ // Too many mods to list Emerald Green 2002 Miata Mods: Koyo 37mm Radiator // Tein Street Flex Coilovers // Flyin' Miata Front and Rear Sway Bars // 949 Racing Endlinks up front // 15x8 949racing 6UL Wheels // Toyo R1R tires // Hard Dog Roll Bar Waiting list: Full vinyl wrap Events: EMWNM '13'14 // MME '13'14 // MNM '14 // NATOR FL BBQ '13'14 LynzeCs bottom bitch. I shall call LynzeC my sloot and she will be mine and she shall be my sloot. Come on, sloot. Come on, little sloot. |
| The Following User Says Thank You to Kyle Undefined For This Useful Post: | p057 (01-14-2014) |
| Banned ![]() Join Date: Jan 2014 Location: texas
Rep Power: 0 ![]() ![]() Thanks: 2
| Not Ranked : 0 score When I did the tmm I'd agree with you, my 1st problem was getting liquid wrench (to break the bolt free) then where I had jack and hight, I'd just recommend once you unscrew tmm bolt tale your time and when it comes out it'll 1hold, 2... You don't want option2 lol. But with shortshift, ssb, heavy shift knob, and cs tmm insert completely eliminated my speed3s problem shifting in 2,3 gear during heavy accl and shifting, usto skip gears, that's just a bad memory nowadays |
![]() Join Date: Sep 2013 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score man I wish there was a Gen1 TMM insert. |
| The Following User Says Thank You to The Ridge For This Useful Post: | BruhhWill (01-13-2014) |
![]() Join Date: Jul 2012 Location: South San Diego, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,074
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score Just buy a gen 2 tmm. I got one on here for just shipping cuz another member just wanted to get rid of it then found a new corksport insert for real cheap. Now just got to get off my lazy ass and change mounts. Sent from my KFAPWI using Tapatalk HD
__________________ 2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's to be installed : 3 Port EBCS HTP 3" intake/ MAF/ TIH Autotech internals Corksport Pmm Test pipe SBC Rear Camber Arms |
![]() Join Date: Jun 2011 Location: McMinnville OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
| Not Ranked : 0 score I used it on my Gen1, just had to dremmel it away in a couple spots to make it fit.
__________________ 2009 Mazdaspeed3 GT - Crystal White Pearl ETS tmic / CorkSport intake / Synchronic diverter valve / Cobb short shifter / solid shifter bushings / 385gram titanium shift knob / CorkSport interior LEDs / CorkSport LED fog lights / COBB AP / COBB catless DP/ JBR Mounts / CorkSport rear sway bar / NGK 1 step cooler plugs / Autotech HPFP internals / 30% Tint / Dareman Stubby |
![]() Join Date: Nov 2011 Location: norcal, CA
Groaned at 5 Times in 2 Posts
| Not Ranked : 0 score loving my TMM insert. I actually like the whine too, lets me know whats going on
__________________ 2006 MS6 Titanium - MS v1 CAI, Corksport TIP, Forgev1 BPV, Tien S-tech Springs, JBR SSP, JBR 80 RMM, CS 85 Duro TMM Inserts, JBR solid bushings. ebay test pipe, laminx 6% headlight/fodlight shields. Magnaflow Mufflers, 5k DDM Fogs, BBS RK 18x7.5 +42 18lbs- I Needz teh AP and HPFP |
| Not Ranked : 0 score Hey Twenty5psi, How's the sway bar doing?
__________________ 13' MS3 CS; SR w turbo inlet; RMM insert; TMM insert; CS shift Plate; Eibach Sportline; Koni |
(Thread Starter) | Not Ranked : 0 score Good stuff! Installed it last night, car feels great.
| Not Ranked : 0 score Thats Awesome, been curious to hear how that combination worked out. Hey on another note: I noticed you are running the UR TP and the CBE. You didn't run the DP? There are so many options just trying to figure it out. I have read every post on all the options and have turned myself in so many circles. LOL
__________________ 2013 MS3 VRM w/Tech -unSure Track RMM//Cobb AP//AT HPFP Internals//HTP 3" Intake//UR Resonated TP//UR CBE//JBR Weighted Shift Knob//JBR Shifter Cage Bushings FlowTuned 2 Gallon E85 blend 307whp/336wtq | |
(Thread Starter) | Not Ranked : 0 score @Spencer@CorkSport Having a slight issue with the lower tie bar I believe, have been getting a weird vibration on takeoff in colder temps since the TMM broke in a little bit, checked the torque and whatnot on the TMM and it was fine, on a hunch went down and looked where the tie bar has minimal clearance by the transmission and sure enough it looks like there is some contact that is occuring. I have an old SURE RMM mount(I know I need to get rid of that garbage) do you believe it has shifted the engine to create a clearance issue?
![]() | | #19 | ![]() |
| Not Ranked : 0 score Ok don't do this, a good source said the gen 2 tmm won't fit the gen 1 Sent from my SAMSUNG-SGH-I337 using Tapatalk
| The Following User Says Thank You to Playaj For This Useful Post: | The Ridge (01-14-2014) |
![]() | | #20 | ![]() |
![]() Join Date: Apr 2011 Location: Chesapeake,VA
Rep Power: 901 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 672
| Not Ranked : 0 score that is completely false i am running a pu tmm on my gen 1. You need the complete assembly though. Upper portion, tripod, and the bolt. Reason being mazda switched the thread pitch on the main bolt for the pu tmm. The gen 1 tmm uses a coarse thread bolt where the pu uses a fine thread bolt.
__________________ |
| The Following 3 Users Say Thank You to 2.0t03speed For This Useful Post: |
![]() | | #21 | ![]() |
![]() Join Date: Dec 2009 Location: San Antonio, TX
Rep Power: 5050 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,143
Groans: 146
| Not Ranked : 0 score So, doing the tie bar.... with load or without? I'm thinking without.... but just in case. Thanks |
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score Front suspension was unloaded when I did it, but it really shouldn't matter, it's not like a strut bar where it could effect the suspension geometry unloaded vs. loaded.
| The Following User Says Thank You to twenty5psi For This Useful Post: | pzr2874 (01-14-2014) |
![]() | | #23 | ![]() |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score Just wondering with the tie bar has it improved traction when trying to launch off a stand still etc.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
![]() | | #24 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
If you're still using OEM LCA bushings, those should be the first change you make if the goal is to help traction off the line.
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club | |
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | shaneski (02-04-2014) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score Iv got CS insert and It's Working for me ask the Beamers, mustaschangs, subs, challengers... list go's on, if they liked the back of my car? just saying smoother shifting= smiley face for me for them. CS Thank you for making my Factory insert go from (image below)to the blue (see OP) makes a diff 2 me no more grind or slip 2-3rd just saying CS brings it |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Just ordered a cs rsb and lower tie bar hope to see a nice difference in handling.
![]() | | #27 | ![]() |
![]() Join Date: Apr 2012 Location: irving,tx
| Not Ranked : 0 score What's up with the lower tie bar issue? Incorrect install or just a clearance issue? |
![]() | | #28 | ![]() |
| Not Ranked : 0 score @twenty5psi; any update? EDIT: Found this while searching for some stuff this morning. Looks like it's happened before with certain mounts Front Lower Tie Bar
__________________ Last edited by 2.0t03speed; 03-03-2014 at 04:28 AM. |
| The Following 2 Users Say Thank You to 2.0t03speed For This Useful Post: | Nliiitend1 (03-03-2014), twenty5psi (03-03-2014) |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score Basically the same issue I have, it's starting to warm up here so I don't hear it much anymore. If you pull the driver wheel you can clearly see the bar and trans case about a millimeter from contacting each other.
| front bumper insert | tooslow10 | Exterior | 60 | 11-04-2013 11:01 AM |
| Front lower grille | AKmac11 | MazdaSpeed 3/6 - Appearance | 2 | 02-27-2013 11:45 AM |
| Front Lower Tie Bar | Todd98SE | CorkSport | 3 | 10-23-2012 05:24 PM |
| lower front springs only? | bmannn | 2010 MS3 - Suspension & Brakes | 1 | 04-22-2011 01:19 AM |
