![]() Join Date: May 2013 Location: Ponce, Puerto Rico
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
(Thread Starter) | Not Ranked : 0 score Well ill be upgrading my turbo to corksport turbo and ive been searching to see what has been the experience when upgrading to cs cams taking into consideration turbo spool time. I’ve been researching and there is so many debate on this, some state that large profile duration cams affect spool time, others state it helps! so im looking for those of you who can share some light here whether when upgrading to cs turbo, doing cams will help in spool time directly or non-directly. Any thoughts or help will be appreciated.
__________________ Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| I can't really offer much in the way of advice re: CS cams or the like, unfortunately. However, the CS turbo is pretty quick to spool and it'll be unlikely to be fully lit before about 3500rpm unless you figure out a way to augment the amount of air flowing through the engine at low RPMs. Basically, we're talking about adding a supercharger, or some other extra means of pumping air in there. Anyway, I think you're probably going to end up spending way more money on cams than they're worth for the nominal amount of spool they will get you. You might want to look into Meth or E85 if it's available in your area instead.
| The Following User Says Thank You to Vansquish For This Useful Post: | cyclist20 (11-05-2019) |
| e-brake light, abs light, dsc light, and traction control light | DarrenMon | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 9 | 04-27-2016 08:44 PM |
| CES: Audi Traffic Light Assist helps you hit every green light | Haltech | Automotive News | 0 | 01-09-2014 02:10 PM |
| Parker light trap in head light housing | bcmps | MazdaSpeed 6 - How-To's | 4 | 11-26-2009 06:52 PM |
| Audi traffic light detection system gets the green-light | Haltech | Automotive News | 1 | 09-21-2008 01:24 PM |
| All-in-One Black Studio Light Kit (includes Light Tent, 2 Lights, and Acrylic Table) $99.99 | Haltech | Hot Deals Section | 0 | 03-26-2008 01:24 AM |
