![]() | | #41 | ![]() |
![]() Join Date: Apr 2013 Location: Seattle, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,526
| Not Ranked : 0 score
__________________ SOLD: 2009 Metro Gray Mica Mazdaspeed 3 - CorkSport Stage II SRI - CorkSport High Flow Downpipe -CorkSport TMIC - CorkSport Short Shift Plate - CorkSport Shifter Bushings - CorkSport Rear Motor Mount - CorkSport Passenger Side Motor Mount -Cobb Accessport - CorkSport HPFP Max Flow Fuel Pump Internals - CorkSport LED Kit 1992 Red Mazda Miata - Flyin Miata Swaybars, Hard Dog Hard Bar, Koni Yellow Shocks, Flying Miata Springs, Spec Stage 1 Clutch, E-Code headlights Next?: 2016 Mazda Mx5? 2017 Mazdaspeed 3? [SIGPIC][/SIGPIC] |
![]() | | #42 | ![]() |
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
-Derrick | |
![]() | | #43 | ![]() |
![]() Join Date: Aug 2013 Location: Beaumont
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
| Not Ranked : 0 score Id take one...
__________________ 06 MS6 GTX3076R, Xs power exhaust manifold(suxs), ebay dp(sux), 3" catless exhaust, 4" HTP TIP, Sure shortshift & counterbalance, COBB V3, Autotech HPFP internals, Grimmspeed EBCS, CP-e RMM, Perm PCV plate, JBR EGR delete, JBR BSD, JBR Oil pan baffle plate, Kozmic OCC, rebuilt fuel injectors, safeseal injector seals, Bosch 3 bar MAP, new gaskets(valve cover, throttle body, intake manifold, exhaust manifold, dp), cleaned valves and chambers, CP-E motor mount & rear-diff mount, ATP-INT-003 FMIC, Stratified Guardian Angel set to 24psi, Stoptech rotors, Hawk HPS pads, Forge BPV, home-made strut mounted tower bar, badgeless, special edition 19" anniversary rims. Battery finally relocated to trunk with custom box. New VVT stuff, BC coilovers, new OEM Clutch, fidenza lightweight flywheel, replaced driveshaft again, replaced power steering pump again, busted rear diff side bolts again....FML |
![]() | | #44 | ![]() |
| The Following User Says Thank You to SpencerC For This Useful Post: | TiGraySpeed6 (12-16-2014) |
![]() | | #45 | ![]() |
| Not Ranked : 0 score yes...
![]() | | #46 | ![]() |
![]() Join Date: Jun 2012 Location: Hickory NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
Groans: 106
| Not Ranked : 0 score I feel like there is a market for a intake manifold that will accept a tmic, a lot of guys including me do not want to run a fmic and want to stay with the simplicity of a tmic, but then this limits us on intake manifolds where our only option is a ported manifold from relentless.
__________________ go fast- atp gt2871r,3bar map sensor,3port ebcs,freektune 4" wp intake,,jbr trilogy mount, turbosmart bov,cpe tmic,cpe cbe, UR catless DP, UR catless TP, autotech internals cobb ap v2, aem meth controller and pump, custom meth tank,snow solenoid and aquamist nozzle suspension-c/s springs,c/s midbrace,jbr rsb, 235/40/18 nitto nt55 |
![]() | | #47 | ![]() |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
| Not Ranked : 0 score What purpose is there to get a manifold without the injector bungs? If this is released please have that option with fuel rail.
__________________ 2013 CWP and Stock |
![]() | | #48 | ![]() |
6th port injection + ported manifold
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
| Ecoboost Intake Manifold VS MZR Intake Manifold | theschrum | Ford Focus ST Ecoboost - General Discussion | 39 | 10-28-2013 10:28 PM |
